New Ytest
Sign out
Bimmerpost
Login
BMW E39 5-Series Forum | 5Post.com
Go Back   BMW E39 5-Series Forum | 5Post.com > BMW 5-Series (E39) Forums (1995 - 2003) > General E39 Discussions
      11-07-2022, 11:40 PM   #1
GrinchMonster2k
Drives: 2001 BMW 540i
Codes P0120,P0123,P0223
Codes P0120,P0123, P0223 are all Pending and will not erase, and I have disconnected the throttle Pedal sensor and throttle body wire harness with the same codes, Code P01635 will appear after erasing the code, on scanner showing 100% value on (TP) when on live data on scanner, will a reflash of DME reset the Values on (TP), 2001 BMW 540i 6-spd. needing advise on what to do.
      01-10-2024, 07:51 PM   #2
davi_rufete
Drives: X5 2002
Good evening, incredibly, I have the same problem, same code and TP 100% managed to solve it? I'm lost
      01-20-2024, 04:51 AM   #3
davi_rufete
Drives: X5 2002
Problem solved, in my case it was the DME module fried, I changed the DME kit, EWS and key code the car works like a clock
5post
