05-06-2024, 09:23 PM | #1 |
Rep 104
Horn problem
Realized for a while, that sometimes I press my horn it doesn't make a sound after a cold start.
Wonder do I have to take the airbag out of the steering wheel to grease the connections behind it? Does it have a have a connector behind that my need to put in the grease like the dielectric grease? Does anyone have this issue?
F30 335i xdrive
05-08-2024, 05:45 AM | #2 |
Rep 3,908
If you google it, you will see quite a few threads or even videos about it. Typically the problem is with one of the two or both horns under the hood, not with the steering wheel switch.
I don't use mine often, but every time I have used it it has sounded a bit "homosexual"... so I also wonder if maybe one of the horns is not out... Some people report it all goes back to normal after a few seconds continuous honking (happy neighbours).
"Large increases in cost with questionable increases in performance can be tolerated only in cars and women."
Dom147102.50 |
05-08-2024, 07:49 AM | #3 |
Rep 16,188
Corrosion of the connectors on the horns is a possibility. It can be enough to keep the horns from sounding at first but after a while the current can push through the corrosion. Clean them with contact cleaner, dielectric grease should prevent it from reoccurring.
05-08-2024, 10:41 AM | #4 |
Rep 3,908
Where are the horns and how accessible are they…?
05-08-2024, 09:21 PM | #6 | |
Rep 104
F30 335i xdrive
05-09-2024, 12:52 PM | #8 |
164
Rep 248
Drives: 1989 325i & 2014 335i
Skyhigh1923.00 |
