04-02-2019, 07:06 PM | #1 |
Rep 20
F30 wheel and tire setup
Hey i am looking to purchase a set of FAST FC04 in 18".
They are offered in 18x8 et 30 or 40, and 18x9 et 30 or 40 I am looking to run a square setup with either 245/40/18 or 255/40/18 for a 2013 f30 335i xdrive. The tires i will be using is mp4s and i am looking for a flush fit. I prefer running the 255 with 18x9 but it am worried about rubbing in the front, if this is possible, would offset of 30 or 40 be more flush? If i do go with the 245, is there any benefit of me going 18x8 et30 over 18x9 et 30 or 40? Any help would be greatly appreciated. Thanks |
04-03-2019, 08:47 AM | #2 |
Rep 4,373
https://f30.bimmerpost.com/forums/sh...ht=437m+square
his wheels are 19x9 +29 with 255/35/19. if you used 18x9 +30 with 255/40/18 square, the position of your wheels/tires would be just 1mm further in than his, basically the same place. it is poking a little bit, but if you like what you see, get 18x9 +30 with 255/40/18 square. 18x9, +40 square with 255/40/18 should fit as well however the inside of the front wheel/tire will be close to the spring perch and strut and may even touch depending on the tire https://f30.bimmerpost.com/forums/sh...lo08816&page=2 you could also do +30 front, +40 rear, but then no rotation front to back 18x8 245/40/18 with either +30 or +40 offset fits without issue. obviously, the +40 will be 10mm more tucked than +30. Last edited by alohasurftoad; 04-03-2019 at 09:28 AM.. |
245, 255, 335i, f30, flush, offset, rim, summer tires, tires 18s, wheel |
