01-23-2023, 07:37 AM | #1 |
16
Rep 79
Mice eat through wires in engine bay. Help please!
Supposed to be going on a 4 hour drive. Went to start the car and got a message saying "Outside temperature -40" and the engine light is on. Checked under the bonnet/hood and it looks like some mice/rats have cut through some wires at the top back of the engine.
What are these wires for? The problem is the other side of the wires goes into the engine black plastic bit so I can't pull them enough to join them together. The other side of the wires plug into the airflow box thing. View post on imgur.com |
01-23-2023, 08:44 AM | #2 |
1208
Rep 2,920
You don't say if the car runs ok. Probably not many people will know offhand and would have to trace them to where they go and see what they connect to. As you likely realize, "engine black plastic bit" is not terribly helpful.
01-23-2023, 08:47 AM | #3 |
1208
Rep 2,920
Also, since the engine light is on you can probably get a clue what the wires are by having the stored error codes read. In the US most auto parts stores will do it for you.
01-23-2023, 10:55 AM | #5 |
Rep 16,166
They don't just feed on wire insulation, they nest. You can see signs of that in the picture. If you have it garaged you're more likely to have them nest than if you park on the street. After having one do a job on my car I put one of these in my garage. It catches on average a mouse every month.
https://www.amazon.com/dp/B09NKZ2G1J...NsaWNrPXRydWU= |
01-23-2023, 12:42 PM | #6 |
Rep 567
That's terrible to hear. Hopefully it's a simple fix with resoldering the wires. As suggested I'd have the code(s) read to get an idea.
This has happened to me on my WRX. A baby rat was trying to make a nest around my battery. How did I know? Got in the car to drive and he jumped out from under the hood and cowl area and tried to escape by climbing up the windshield but kept slipping down. Went back down and in after running across the windshield. Didn't see but I assume he ran away from underneath. Anyway, peppermint oil is a deterrent apparently so went and bought some at Target. So far so good, but not sure if it's the peppermint or the trauma of what it went through that's kept it away. Regardless, I'm popping my hood to check before every drive and spraying it down once I return. Excellent. |
01-23-2023, 01:57 PM | #7 |
Rep 16,166
Mint does deter rodents. I have it planted around the perimeter of my garden and it has greatly reduced my crop losses. The trouble with mice is you'd have to dip the car in mint oil to keep them away from all of it. The one that ate my wiring made his nest near the fuel filler pipe behind the wheel well liner. It took me forever to track it down.
01-23-2023, 11:45 PM | #9 | |
Rep 6
I'm going to investigate. Rat |
01-24-2023, 02:26 AM | #10 |
2JZ-GTE
3070
Rep 4,016
Sorry to hear that. I have traps set all around my car and every once a while somebody gets caught.
01-24-2023, 04:21 AM | #11 |
1007
Rep 2,244
Drives: 2007 328i / 2014 M235i
Based on the -40 reading it’s probably your outside temperature sensor.
Was the car stored outside for long periods of time? |
01-24-2023, 09:17 AM | #12 |
80
Rep 180
I live in a rat infested city and park outside, so I know the struggle. I’ve already had to drop the lower engine cover once this year to clean out an absurd amount of leaves, trash, rat poop, etc. I sprayed diluted peppermint oil on both the lower cover and hood pad and have been checking at least once a week.
01-26-2023, 10:06 PM | #13 |
Rep 501
I put old fashioned mouse traps inside each wheel, just under the rotor, and I have been catching mice like crazy -- sometimes every day. This gets them before they even get into the engine bay, but I have a backup trap in the engine bay as well.
01-27-2023, 06:20 AM | #15 |
1007
Rep 2,244
01-27-2023, 06:21 AM | #16 | |
1007
Rep 2,244
01-27-2023, 07:39 AM | #17 |
Rep 16,166
To be precise it chewed the insulation on the wiring from the fuel tank leak diagnosis module. This caused the conductors to corrode and eventually break. Rodents don't eat wire, they eat the insulation, which is made with soy. Once the copper is exposed to the air it will corrode. It doesn't help that manufacturers use wire of the smallest possible gauge and thinnest possible insulation, to save weight.
01-27-2023, 09:58 AM | #18 | |
1007
Rep 2,244
01-27-2023, 03:48 PM | #19 | |
Rep 16,166
Honda and Toyota don't make wire. Neither does BMW. Most manufacturers use wire with soy based insulation, BMW among them. Soy may not be the problem, mice will chew on anything, but there seems to be more damage from mice since soy insulation started to be used in cars.
01-27-2023, 05:30 PM | #20 | |
1007
Rep 2,244
01-27-2023, 09:16 PM | #21 |
Rep 16,166
01-28-2023, 08:34 AM | #22 |
Rep 1,245
I keep my F34 in my garage, but the mice got to my Honda one day. Caused all sorts of problems - lost power steering, every idiot light was lit, and a whole lot more.
Had it towed to my trusty local independent and he fixed it for about $200. Told me mice are a common problem and had no idea how to keep them out of the engine bay. |
