08-17-2009, 06:38 PM | #24 |
Rep 20
This setup looks sick. I was thinking about doing the same setup but with RD Sport springs instead of the H&R's. I have the OEM 19's as well. Do you think there is a chance there would be any rubbing issues?
08-18-2009, 01:06 PM | #25 |
518
Rep 3,612
you shouldn't have any issues, but its hard to guarantee that since once in a while we will hear about rubbing issues on certain cars even though we have run the same set up dozens of times without any issues
08-18-2009, 02:23 PM | #26 | |
Rep 20
Once I get this setup installed. I'll post up some pics. Thanks |
08-23-2009, 12:18 AM | #28 |
Mthusiast
Rep 69
Drives: e46 m3
sweet pics, didn't think the spacers would make that much of a difference it's def an improvement.
08-27-2009, 01:42 PM | #29 |
518
Rep 3,612
Year/model BMW:
2009 M3 Wheels/offset: Front: 19x8.5 OEM M3, ET29 Rear: 19x9.5 OEM M3, ET23 Tire size: Front:Michelin PS2 245/35-19 Rear: Michelin PS2 265/35-19 Suspension: Stock springs equipped w/ EDC Spacer size: Front: 15mm Rear: 12mm |
09-01-2009, 02:31 PM | #30 |
17
Rep 226
Drives: e90 m3 melbourne Red Metallic
I am deciding on 15/12mm spacer set up or the 18/15mm set up.
I got 2008 M3 sedan with stock optional 19inch rims. think to drop with some eibach pro springs. would the 18/15mm set up sit more flush to the fenders? and have more aggressive look ? 15/12mm have sleek smart look but what do you guys think at EAS? do you have any pics with eibach springs 18/15mm set up? thanks
e90 m3 melbourne red metallic, "One and Only" e90 sedan Amuse Ericsson full exhaust(new model)with custom spec, Afe intake with stock box,piano black trim, blackline tail, HRE P40 9x19,10.5x19
09-01-2009, 03:18 PM | #31 | |
257
Rep 4,048
09-27-2009, 04:27 PM | #32 |
20
Rep 273
Drives: 2009 IB M3 Coupe
Just went "bulldog" yesterday with a set of MS from the EAS crew. Looks awesome. Will try to get a few pics when we get some good weather here in the NE.
The picture tutorial was spot on. Took less than an hour.
2009 M3 coupe,interlagos blue,6mt,loaded,19" hre comp 97s,powerchip,h&r springs,hamann front splitter,eisenmann race exhaust
Delivered 7/10/09 |
10-06-2009, 11:51 AM | #33 |
8268
Rep 18,855
Drives: BMW
Year/model BMW:
2008 M3 Wheels/offset: Front: 19x8.5 OEM M3, ET29 Rear: 19x9.5 OEM M3, ET23 Tire size: Front:Michelin PS2 245/35-19 Rear: Michelin PS2 265/35-19 Suspension: RD Sport Springs equipped w/ EDC Spacer size: Front: 12mm Rear: 10mm
10-06-2009, 12:45 PM | #34 |
309
Rep 3,635
Drives: R56 Cooper S
Year/model BMW:
2008 e93 M3 Wheels/offset: Front: 19x8.5 OEM M3, ET29 Rear: 19x9.5 OEM M3, ET23 Tire size: Front:Michelin PS2 245/35-19 Rear: Michelin PS2 265/35-19 Suspension: Stock Spacer size: Front: 12mm Rear: 12mm |
10-13-2009, 11:37 AM | #35 |
8268
Rep 18,855
Drives: BMW
2008 M3 Sedan with 10/15 MS Spacer Combo
Before:
After: Year/model BMW: 2008 M3 Sedan Wheels/offset: Front: 18x8.5 OEM M3, ET29 Rear: 18x9.5 OEM M3, ET23 Tire size: Front:Michelin PS2 245/40-18 Rear: Michelin PS2 265/40-18 Suspension: Stock Spacer size: Front: 15mm Rear: 10mm
10-16-2009, 09:55 PM | #36 |
Rep 6,107
Here is mine 12/15 setup that I got from Tom ! Spacers fit great ! I had H&R before and it was a night mare ...
Also it was a good time to clean my wheels |
10-26-2009, 11:59 AM | #38 |
309
Rep 3,635
Copied from TOOMANYCARS
Year/model BMW: 2009 M3 Wheels/offset: Front: 19x8.5 OEM M3, ET29 Rear: 19x9.5 OEM M3, ET23 Tire size: Front:Michelin PS2 245/35-19 Rear: Michelin PS2 265/35-19 Suspension: Stock springs equipped w/ EDC Spacer size: Front: 12mm Rear: 10mm |
10-26-2009, 04:03 PM | #39 |
518
Rep 3,612
Year/model BMW:
2010 M3 Wheels/offset: Front: 19x8.5 OEM M3, ET29 Rear: 19x9.5 OEM M3, ET23 Tire size: Front:Michelin PS2 245/35-19 Rear: Michelin PS2 265/35-19 Suspension: Stock springs equipped w/ EDC Spacer size: Front: 15mm Rear: 12mm Before: After: |
11-06-2009, 08:03 PM | #40 |
29
Rep 35
Hello, M3 Fighter Pilots!!
I DIYed the spacer. Front: +18mm Rear: +15mm This is DIY for 5 Series (E60), and this is DIY for M3 Coupe (E92). Thanks Tom G. and eas staffs.
11-06-2009, 08:22 PM | #41 |
Rep 221
Changed my setup to 15/10 F&R respectively.
Year/model BMW: 2009 M3 Wheels/offset: Front: 19x8.5 OEM M3, ET29 Rear: 19x9.5 OEM M3, ET23 Tire size: Front: Michelin PS2 245/35-19 Rear: Michelin PS2 265/35-19 Suspension: Stock springs equipped w/ EDC Spacer size: Front: 15mm Rear: 10mm
Everything is work in progress.
11-13-2009, 10:00 AM | #42 |
Rep 443
Brandon
Want mine posted? I running stock 19's with 255 fronts and 275 rears with a 12 mm front RE with MS black lugs from you guys, and a 5mm rear MS from you guys with H&R sport plus from you as well. |
11-13-2009, 12:41 PM | #44 |
Rep 443
Year/model BMW:
2008 E90 M3 Wheels/offset: Front: 19x8.5 OEM M3, ET29 Rear: 19x9.5 OEM M3, ET23 Tire size: Front: Bridgestone Blizzak LM-25 255/35-19 Rear: Bridgestone Blizzak LM-25 275/35-19 Suspension: H&R Sport Plus equipped w/ EDC Spacer size: Front: 12mm Rear: 5mm Camber: -1.4 Front -1.7 Rear |
