      05-29-2011, 10:36 AM   #23
drufe
drufe's Avatar
Drives: 2011 135i Coupe
2011 135i Coupe  [1.00]
Installed my new Arc-8s yesterday. Stock suspension and setup with no mods whatsoever to fenders, camber, etc. No rubbing yet and everything seems to clear just fine so I don't expect to get any.
Front: 18x8.5 ET45 Anthracite with Hankook Ventus V12 235/40/18
Rear: 18x9.5 ET62 Anthracite with Hankook Ventus V12 265/35/18
Thanks, Eddy!
      06-01-2011, 03:32 PM   #24
airs
airs's Avatar
Drives: 2009 Space Gray 135i
Anyone have 235/265 Advan AD08's on these wheels with stock suspension? Any rub?
Forge FMIC | Apex ARC-8 w/ Michelin PSS | 261 powder coated w/ Conti DWS | BMW Perf Spoiler | Tint | Black Kidneys
      06-01-2011, 03:51 PM   #25
fourtailpipes
Drives: the ladies crazy
Thanks, Eddy!
copycat!
by the way, rotate the quick release on the front axle of the bike in the background so it's not facing forward.
      06-02-2011, 09:42 PM   #26
gadget12345
gadget12345's Avatar
Drives: 135i
My setup with PSS , 235/40 Front strut rub.
My setup with Pilot Super Sports , 235/40 R18 - Front strut ;
With BMW Performance suspension and factory spec'd front camber of -0.5 degrees - Less than 1/32nd inch clearance - and contact when parked facing downhill (to get a feel for how things look under braking). Not quite full lock either since I'm taking these solo.
Its too tight in my factory friendly setup
So - sadly - the 235's have to get swapped out for 225's - Which stance wise is a bit better for the car overall (slightly lower in front vs rear)
Could not be happier with the look overall - rears are great - Will post full pics tomorrow when we get the replacement front rubber on.
Yr1 E82 CSM - 6MT, Premium Package, Sport Package
BMW - SSK, Perf Exhaust, Perf Suspension, Shadow Grills Inners, Mudflaps, Alarm, Cargo Liner, Grocery Gripper, Aluminum Pedals, Front + Rear Perf Rotors, MSD80 PowerKit, E93 Sway Bar
Misc -Euro Headlight Switch, Warning Triangle, iBrights, LoJack, Wheel Roundels, Tint, Escort 9500i, Hyper Black ARC8's, Pilot Super Sports
      06-02-2011, 09:58 PM   #27
fourtailpipes
Mine's extremely close, but doesn't touch. you should just use a thin spacer in the front. 3mm would do it.
      06-03-2011, 09:40 AM   #28
dcstep
Drives: '09 Cpe Silverstone FR 6MT
2009 M3  [8.40]
Agreed. I'd keep the tires and add a thin spacer.
Dave
      06-03-2011, 10:23 AM   #29
gadget12345
Drives: 135i
Baby's got a new pair of shoes.
Thanks for the thought guys - I looked at the spacer and IMHO it pushed things out a little too aggressively for my look on the car.
Swapped out 235 for 225's on the front - Four reasons overall
1) 235 on my setup (Perf Suspension, -0.5 camber) either rub or are just too close for comfort.
2) As stated - Spacer would have probably worked - but made front too aggressive (for me)
3) Ride height - the 235's when you do the math raise the front a fraction over the rears (something like a 1/4 inch) - the 225's sit the front down a fraction.
4) Tire guy's recommendation (who is in an AC 5 series) - The 235's are very flat on the ARC's and in his opinion the sidewalls can flex in under cornering - He prefers the 225's with give a slight stretch and hence rounding and better performance under turn in.
All opinions mine and his - Your mileage and setups will probably vary
End result - My setups 225/40/R18 on front, 265/25/R18 on rears on Hyper Black ARC-8's
Ride is superb and for a more or less 'factory fit' this would be my recommendation.
      06-03-2011, 10:30 AM   #30
dcstep
2009 M3  [8.40]
Forgive the M3 in the 1 forum, but here's my 18x10" 25 Apex ARC-8 in a square setup and 275-35/18 Dunlop Derizzas:
M3 with new wheels and tires by dcstep, on Flickr
IMG_0267_DxO7D by dcstep, on Flickr
Dave
      06-03-2011, 12:16 PM   #31
drufe
drufe's Avatar
copycat!
Ha! Good eye. I actually don't ride with it like that. This was just the way it wound up after putting the front tire back on after taking it down off my bike rack.
      06-03-2011, 12:18 PM   #32
drufe
drufe's Avatar
My setup is extremely close as well, but doesn't touch either. I'm going to be removing and inspecting the tires this weekend to be sure. I might end up going with a 3mm spacer in front if I notice any rubbing. Is there a spacer that you recommend?
      06-03-2011, 01:42 PM   #33
ucbsupafly
Drives: 2008 BMW 135i
Originally Posted by rem3 View Post
Hello , you need front wheel spacer for KW?
Thanks .
No, no spacers in the front with the KWs. No rubbing. I am running -1.8 camber.
      06-03-2011, 01:59 PM   #34
fourtailpipes
doesnt really matter... a spacer is a spacer. with a spacer as thin as 3mm it's almost a guarantee to be difficult to remove from the hub if it gets seized on there (which it will), so it would be a smart idea to cut a couple little notches in the backside of the spacer around the edge to be able to fit a flat-head screw-driver in there to pry it off later. some spacers come with these cutouts already.
edit: i assume it goes without saying that you should select a spacer with the correct chamfer to make them properly hubcentric. i've never seen one on the market that wasn't chamfered, but i'm sure they exist. h&r, macht schnell, and probably 100 other brands make spacers for this car that im sure would all be fine. don't forget extended bolts too.
      06-03-2011, 02:21 PM   #35
BimmerJim
BimmerJim's Avatar
Drives: 2012 M3 Coupe
Dave
M3s are always welcome in the 1 Forum
2012 M3 Coupe Le Mans Blue Metallic
2012 135i LeMans Blue Metallic, M Sport, DCT (Retired)
2011 528i SGM, Loaded (Retired)
"M-the most powerful Letter in the World"!
      06-03-2011, 03:56 PM   #36
fourtailpipes
technically, the 235s are less than 1/10th of an inch taller than the 265s, which results in less than 1/20th of an inch in increased ride height. based on the proximity of the rollouts of the two sizes (differing by only 0.37%), i'd guess that they're a LOT less than 1/20th inch apart in height... this is probably just a rounding difference. for all intents and purposes, they're the same diameter.
      06-03-2011, 04:35 PM   #37
romainz
France
Drives: 135i & CaymanS
Love it
      06-03-2011, 05:20 PM   #38
fourtailpipes
your car looks great, by the way!
      06-04-2011, 01:33 AM   #39
pnguyen1028
Drives: 09 Alpine White 135i; 6 Speed
No fender modifications. Check sig for other info.
My fronts are very... very close to the strut. Pretty scary, but it's been alright so far. It looks EXACTY like gadget12345's picture in the previous posts. Is this normal?
No alignment pin mod or anything. I only rub slightly in the fronts on unexpectedly large dips when I'm going at a good speed. Also at full lock, I hear a scraping type of noise... havn't taken the time to figure out what it is yet. Will need to find a second person to drive around in circles at full lock while I inspect!
Exterior Mods: BMW performance side skirts, BMW performance carbon fiber spoiler, Black kidney grills, iCarbon front lip, debadged
Wheels/Suspension: Lowered on eibach pro-kit with koni FSD shocks. Running the Anthracite APEX Arc-8's with 235/265 Michelin Pilot Super Sports.
      06-04-2011, 01:36 AM   #40
drufe
drufe's Avatar
Thanks man! And thanks for the good info on the spacers.
      06-08-2011, 01:05 AM   #41
bellducci6
bellducci6's Avatar
Drives: 2009 135i
Thanks, Eddy!
do the tires grip well? because i am planning to autocross with the same setup as yours
      06-08-2011, 12:30 PM   #42
drufe
drufe's Avatar
I haven't had a chance to really push them yet but I've done some spirited driving on the street and they seem to hold pretty well. I've been very happy with them so far. You might want to see what some of the other guys have to say that have tracked these as they'll probably have some better info for you.
      10-11-2011, 11:19 PM   #43
BadM4
BadM4's Avatar
Drives: 2018 IND TANZANITE COMP M4
my new wheels and tires i love my wheels 235 40 fronts and 285 35 rears i have so much space in the rear for a bigger tire too its sick
2018 Individual Tanzanite Blue M4
      10-12-2011, 12:02 AM   #44
xxfocus11xx
xbox live= Focus11
xxfocus11xx's Avatar
Drives: 2009 BMW 135i
drufe- your wheels look sick
18x8.5, 18x9.5, apex, arc-8, wheels
