10-26-2012, 01:26 PM | #1145 |
14
Rep 45
10-26-2012, 01:55 PM | #1146 |
Rep 145
Drives: F30 320ed
MDRIVE
Today I switched on the MDRIVE to aktiv in the HU folders.
Got rather excited at first as it appears that you can customise: DSC (off, DTC, DSC) STEERING (comfort, sport, sport+) THROTTLE (comfort, sport, sport+) You can have any combination of the above. However I couldn't get any changes to register. Anyone? |
10-26-2012, 02:27 PM | #1147 |
14
Rep 45
That's what it says in the cheat sheet, as well, you shouldn't have gotten excited, hehe:
Shows M Drive menu in iDrive, cannot seem to select settings, needs testing. Would be nice indeed if anyone tested it further, though. |
10-26-2012, 02:48 PM | #1148 | |
Rep 145
Drives: F30 320ed
10-26-2012, 05:25 PM | #1149 |
14
Rep 45
Update for high beam assistant:
The F10 code for auto highbeam assistant is FLA_AUTO_AKTIV in the FRM module. The F30 has no FRM module, so I searched in the FEM_BODY for "FLA_" and I found FLA_AKTIVIERUNG, which has Kommentar: "Fernlicht Assistent:0 - FLA (oder KAFAS) nicht verbaut1 - FLA (oder KAFAS) verbaut; Aktivierung bei Lichtschalter in Stellung A (Auto) moglish 2 - FLA (oder KAFAS) verbaut; Aktivierung bei Lichtschalter in Stellung A (Auto) ODER 2 moglich" There are 3 values for it: LDS_IN_A_oder_2, nicht_aktiv, LDS_in_A (was the default one, I changed it to oder_2 one). Then I went in the HU_CIC and found HIGH_BEAM_ASSISTANT (Kommentar: Light Settings High Beam Assistant (Fernlichtassistent) and changed it to aktiv. Now i have a checkbox under setings-lights named Highbeam Assistant. Still no high beam assistant auto start, the checkbox does nothing. Anyone that has more knowledge than me can give his oppinion on my findings, please? |
Luxury85.50 |
10-26-2012, 08:31 PM | #1150 |
Rep 4
link request
Greetings from Indonesia!!
I was wondering if anyone would be kind enough to share the download links to e-sys software and data files? Since i am nubie with zero post, had to trouble u by sending them to my email address, sudyawi@gmail.com Many thanks and hope i can contribute more in the future. Awi |
10-26-2012, 08:48 PM | #1151 | |
General
10447
Rep 40,805
10-26-2012, 11:56 PM | #1152 |
Rep 1,544
10-27-2012, 12:23 AM | #1154 | |
Rep 145
Drives: F30 320ed
I can't see it being a hardware thing. |
10-27-2012, 04:47 AM | #1156 | |
14
Rep 45
I DO have high beam assistant, I just want it to auto start when starting the car. |
10-27-2012, 08:49 AM | #1157 | |
General
10447
Rep 40,805
For reasons unknown, on newer firmware it was changed from "aktiv" to "automatik". With "automatik", FLA automatically turns on when switching on the lights (manually) or if they automatically come on. However, High Beam Assistant is not active when starting the car in the dark (i.e. when the lights automatically turn on with the engine). Maybe on the F30 it can still be set to "aktiv".
10-27-2012, 11:33 AM | #1158 | ||
14
Rep 45
On the F30 there is no FRM module, nor a FLA_AUTO_AKTIV anywhere else, just the FEM_BODY/3060(i think?)/FLA_AKTIVIERUNG which only has LDS_IN_A_oder_2, nicht_aktiv, LDS_in_A as values (I wrote a few posts above its Kommentar which I can not really translate). Quote:
10-27-2012, 01:21 PM | #1159 |
Rep 802
Sorry .. finally decided I would give this "coding" thing a try.
I disabled my wifi connection - I then connected the cable to my ethernet port, then to the car (car off), nothing, couldn't get a connection. Tried again (this time w/ the car on). Still nothing. Tried to run "ZGW_Search.exe". Get an error (given I don't have a connection). Any thoughts??? What am I doing wrong?
2020 X5 M50i | 2015 X3 28i xLine | Retired 2013 335i M Sport
10-27-2012, 01:24 PM | #1160 | |
General
10447
Rep 40,805
Where did you get your ENET cable? Is you LAN Adapter settings set for Auto IP etc.? What is the laptop OS?
10-27-2012, 01:30 PM | #1161 | |
Rep 802
I bought the cable off of another forum user (Raspartan) Not sure how to check LAN Adaper settings? Please advise and I will check. Running Windows 7
10-27-2012, 01:37 PM | #1162 | |
General
10447
Rep 40,805
http://windows.microsoft.com/en-US/w...CP-IP-settings Make sure IP and DNS are set to Auto. Win7 32-Bit or 64-Bit?
10-27-2012, 01:43 PM | #1163 | |
Rep 802
64 bit
10-27-2012, 01:47 PM | #1164 |
General
10447
Rep 40,805
Let's start there. ZGW_Search.exe will not run on 64-Bit OS. Right-click on it, go to properties, and set it to run in the XP SP2 Compatibility mode.
Launch ZGW_Search.exe, and give it a few minutes to populate. ZGW_Search.exe though is an informational tool only, and is not needed at all for E-Sys to fucntion. So, regardless of ZGW_Search.exe working or not, launch E-Sys, and see if you can connect to the car.
10-27-2012, 02:06 PM | #1165 | |
Rep 802
Got ZGW_Search to work. Tried running E-Sys, and was able to connect. Now only problem is, I don't see F30 as a Target option?? lol You must be getting annoyed by now (apologies, but new at this). lol
10-27-2012, 02:07 PM | #1166 |
General
10447
Rep 40,805
F020 psdzdata covers the F20 1-series and F30 3-series.
