BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 Marketplace > SPONSORS Classifieds/Groupbuys/Specials Area > Engine | Drivetrain | Exhaust
      09-29-2010, 06:53 PM   #1
Ryan@IND
Ryan@IND's Avatar
Drives: ACR
✚WHEELSTO | Macht Schnell Performance Pulley for E9X M3 - Special
The power pulley is one of the most inexpensive modifications that you can do that will give your car a few extra ponies. Actually, what is really does is free up some of the power lost when the engine is used to power some of the accessories such as the AC and water pump.
Machined from 6061-T6 aerospace aluminum, Macht Schnell Performance Underdrive Pulleys are strong as well as lightweight to limit parasitic drag from the accessories within a moderate level for maximum performance on or off the track. After machining and engraving, pulleys are then T3 hard anodized for additional strength, anti-corrosion & wear resistance.
Our DualDrive design replaces the Crank Accessory & Power Steering Pulleys, resulting in a 9-14 HP and 7-9ft. lbs TQ gain from reduction in power required to turn accessories and an increase in accessories lifespan due to lower speed. All factory harmonics/balancing are undisturbed.
Macht Schnell Performance Underdrive Pulleys have no negative effect on accessory operation and come fully equipped with new belts.
Macht Schnell Performance Underdrive Pulleys Features:
- DualDrive design allows maximum performance, with minor affect on accessory speed
- Proper cooling temperatures are retained at proper levels on or off the track
- Maintains proper alternator speed, allowing sustained levels to sensitive control modules
- Machined from 6061-T6 aerospace aluminum
- T3 Hard-Anodized for maximum strength and corrosion/wear resistance
- No affects to crankshaft dampening or harmonics
- Simple bolt-on installation
You can now purchase this amazing product at our online store:
http://www.wstoshop.com/servlet/the-...-pulley/Detail
Make sure to use coupon code: newsite5 upon check out to get additional 5% off + FREE Shipping
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMFACEBOOKFLICKR
      08-27-2011, 06:21 PM   #2
lukester
Germany
313
Drives: BMW M3
do these pulleys underdrive the water pump, too?
      09-07-2011, 12:40 AM   #3
Ryan@IND
Ryan@IND's Avatar
Drives: ACR
the macht Schnell dual pulley drive design replaces the Crank Accessory & Power Steering Pulleys and has no effect on the accessories.
      01-24-2012, 06:43 PM   #4
YouW1n
Taiwan
Drives: 2014 F06 M6 Gran Coupe
Please pm best price!
macht schnell, pulley, wheelsto
m3post
