RB Turbo or Upgraded turbo question RE: Do yours leak oil?
08-23-2011, 01:03 PM | #23 |
10
Rep 73
Tibra1, I didn't take your message as anytihg other than providing educational discourse on a subject that to the best of my knowledge hasn't been discussed in this way on this forum as of yet. I think it is awesome you have a set-up you like and works well. Thanks for chiming in and helping me out.
08-23-2011, 01:33 PM | #24 |
35
Rep 220
I'm also burning oil but it's reduced since removing my catch. I've installed a new check valve but have seen no difference. Hoping a fix comes soon cause it's embarrassing getting smoke from a car with well over $80000 Canadian invested in it.
08-23-2011, 02:23 PM | #25 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
Same thing here on stock turbos. I have a fully divorced exhaust setup and you can easily see more soot on the left tail pipe. I am burning through about 1 quart every 500 miles which is a lot. It all started after I removed my BSH OCC. I think this would be just a coincidence though.
I uninstalled my Cobb AP and took it to a very trusted SA which I often go to AutoX events with. They kept the car for 4 days and could not replicate the problem. I am starting to believe that this oil consumption only occurs under higher boost.
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
08-23-2011, 02:26 PM | #26 | |
Rep 6,773
www.bmwpartscenter.net |
08-23-2011, 02:37 PM | #27 |
Rep 1,571
1) OCC's definitely are causing an adverse affect on some vehicles with upgraded turbos, and personally I recommend they are not equipped until more is known exactly why. This is not much of a drawback as the way they are being installed and designed these days is certainly flawed anyhow (see PCV saga thread for more info there, there is a ton of info over there). Removal in itself of the OCC units make a drastic change nearly everytime they are pulled, so there's something to be said for that (ie. it is causing unnecessary problems). Although I'd agree the better units only cause a minor restriction, it only takes a minor restriction to defy the gravity draining in turbos which is where I believe the problem manifests itself. There is some likelihood there is a deficiency in the unique PCV system the N54 employs to support this amount of engine load as well, but I'm not ready to conclusively say that quite yet even though there are some indications that suggest as such (ie. oil notoriously dripping from rear induction tube from the check valve on the valve cover).
2) The CHRAs in these turbos (and the original units or all turbos for that matter) were designed to work under a certain range of oil feed pressures, exhaust pressures on the turbine side, and draining ability. Relieving the exhaust backpressure can cause seals to seep more oil and cause smoke/smell/oil consumption. You may say, "well my original units did not have any problem even with open exhaust, why these?". I believe the RBs are more susceptible to said input oil pressure and flow may need to be restricted- especially in those situations where exhaust is very free flowing. Here is why: Lack of exhaust backpressure from the modified turbine housings (something your originals didn't have) PLUS efficient extremely well flowing post turbo exhaust systems can cause an increased disparity in pressure between oil internal CHRA and exhaust at the turbine outside seal (oil stays consistent, exhaust pressure goes toward nil) which allows more oil seepage at low load conditions. The dynamic seals seem to keep the oil in the turbo as they are in boost or high load, as they should. At low load, you have a much larger turbine bore plus a wastegate flapper (which pending on the software can be more or less open and free flowing as another factor) which does not help maintain oil from escaping, compile that with a potential unnecessarily over pressured oil inlet, it can causes seepage. Add in a restrictor (ie. OCC) in the PCV it even makes things worse as the intake channels have to pull through it to get the fresh air from the Induction inlets, which raises crankcase pressures and further affects turbo drains. Also low load drawbacks of OCCs I do not believe were ever tested, as at the time it seemed less important. But their low load impact maybe more than once thought, as feedback suggests significant improvement upon their removal. In summary it is my thoughts that some combination of high oil feed pressure (which can be affected by oil viscosity, engine bearing tolerances, oil pump output, oil temps, etc), slow gravity draining (which can be affected by PCV alterations, overfilled crankcases, oil temps and viscosity, excessive blowby), free'er flowing modified turbine housings and exhaust (caused by modifications that we obviously want to support big horsepower), and possibly some others I can not think of at the moment (ie. even driving behavior or patterns)- appear to on occasion cause some to encounter this condition. To add confusion though, there are some who do everything non-textbook (ie. defy all above) and have no problems at all. So in a nutshell Adam if the OCC removal in itself doesn't remedy your situation, you may need an oil feed restrictor. There is no restrictor on the N54 and the oil feed lines are likely significantly oversized, so it very well could be a next course of action. Oddly enough this doesn't seem to affect all of those who run RBs; but the frequency is becoming to be enough to consider further options. Dzenno is correct in that we just don't want to throw in a restrictor without at least SOME knowledge on how the N54 operates with oil pressure, not to mention many other potential variables- but at this point I am left to believe that the N54 has a very high oil pressure operating range which under certain conditions can cause engineering guidelines to be crossed. There also seem to be those who have "certain conditions met" on OEM turbos that may be crossing some engineering guidelines as well, as it is very often where those with the OE Turbos that otherwise perform properly add a free flowing exhaust only to begin getting smoke/smell/or oil consumption. It's nearly an everyday thread where someone encounters this and that is chalked up to "bad turbos" that were "good" the day before the exhaust mods. I am not so sure that is the case and it is leading me to believe the car was designed at some high threshold of engineering limits. Close enough to the edge to where some have problems and some do not based on a wide array of variables that can make enough difference to put vehicle 1 under and vehicle 2 over. If the theory is correct, then it only makes sense that RBs will have even more of a disparity due to the much enlarged and free'er flowing housings- but if holds true we may also find that a restrictor maybe beneficial for those who encounter the problem with OEM Turbos as well. Rob |
08-23-2011, 03:14 PM | #29 |
Rep 3,730
Great post Rob....I was getting worried there for a minute. I'm one of those OEM guys with a very free flowing exhaust (AR 3" DP's + AE exhaust) who ocasionally gets smoke when idle.
I've noticed lots of issues with this free flowing setup, stock and otherwise. I wonder if switching back to the OEM exhaust (keeping the aftermarket downpipes) might help aleviate the issue. I know the cats would mask it, but like you said, there will be more backpressue.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
08-23-2011, 03:19 PM | #30 |
Rep 5,876
08-23-2011, 03:25 PM | #31 |
Rep 3,460
I have 55k, stock turbos obviously, fully bolted, meth for over 45k, never once did I have to add a drop of oil. I also have been using a catch can for most of those miles, various ones in fact and never had any issues with smoke.
08-23-2011, 03:25 PM | #32 |
Rep 1,432
08-23-2011, 03:27 PM | #33 |
Rep 4,635
Nice to see your back
Follow my BMW instagram @CARMODIFICATION Let me know you are from bimmerpost and i'll follow back
08-23-2011, 03:29 PM | #34 |
Rep 6,773
+1 except I have 20K Miles n no meth
08-23-2011, 03:31 PM | #35 | |
Rep 5,876
extra power is intoxicating that's for sure...we just have to figure out what's causing the oil consumption/smell/slight smoke on some RB installs |
08-23-2011, 04:04 PM | #36 | |
Rep 3,460
Personally, as more and more people upgrade to reworked stock type turbos, more of these problems will be voiced on the forums. If i ever ditch the stock turbos, it wont be for reworked ones, it will be for a single or something like gt25/28 twins, but that wont be for a long time, if ever. We already had a debate way back in that pvc saga thread, and my opinion still stands, that small restriction is laughable and not the cause, but do your own thing and believe what you want. If rob states that it might be an oiling issue and lack of a restrictor, then a proper feed line should be provided with the upgrade. Btw I also don't believe this, but I also don't have any experience on the matter. When I upgraded my last car with a gt35r, I ran off the shelf oil feed/return lines and never had any issues with smoke or oil consumption. |
08-23-2011, 04:07 PM | #37 | |
ايلي ٣٣٥ هاهاها
88
Rep 1,448
08-23-2011, 04:13 PM | #38 |
Rep 3,460
08-23-2011, 04:21 PM | #39 | |
ايلي ٣٣٥ هاهاها
88
Rep 1,448
I'm already running these turbos for a while now, car running strong at 14 PSI with a custom ESS flash tune. tough, I'm consuming quarter oil every 700 miles or something. PS: TD04L got the same size as a garrett GT28.
08-23-2011, 04:23 PM | #40 | |
Rep 6,631
Hard to imagine the turbos going out at 22k miles but funnier things have happened.
E90 LCI N54 6AT
08-23-2011, 04:58 PM | #41 | |
Rep 5,876
08-23-2011, 05:03 PM | #43 |
Rep 1,571
Look like TD04L-13Ts, slightly smaller than RBs in wheel size. Good upgrade, but if going full upgrade route would likely use something else. He maybe able to benefit from this discussion though, regarding oil consumption.
08-23-2011, 05:15 PM | #44 | |
ايلي ٣٣٥ هاهاها
88
Rep 1,448
not yet, I do NOT trust any piggyback to test these turbos more then 15 PSI even with RACE GAS and meth, I'm waiting for ESS flash or ATR by cobb. Something to be added, THESE turbos DO NOT die on high RPMS, remember, they're TD04L and not TD04.
ar design, oil burning, oil catch can, rb turbos, turbos |
