BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wash, Wax, Detail, Cosmetic Maintenance & Repairs
European Auto Source (EAS)
      06-21-2019, 12:34 PM   #45
M3MPH1S
M3MPH1S's Avatar
Drives: 2010 E92 M3
Originally Posted by lE92l View Post
I had the same thing happen to my 2009 E92 M3. This thread helped guide me on what to do. THANKS TO THE OP
Unfortunately it sits outside for most of its life. I had it under bmw car cover, xpel clear bra on roof, and ceramic coating on xpel. Still with all that the gel coat failed. The good news is I was able to save it. I think my saving grace was the xpel. The clear started to bubble under the xpel. When I started to peal off the xpel the gel coat came off with it.
I got lucky and literally all of the gel coat came off with the xpel. Just came out like in sheets.
I then had a body shop just spray clear over it with the OPs instructions
Question - it looks like there was still splotchy yellowing on the carbon fiber after you removed the gel coat. How did the shop prep the carbon fiber to be cleared over? Did they just clean it with water and a mild detergent? Or did they do some polishing and/or wet sanding?
      06-30-2019, 10:13 AM   #46
DMA
DMA's Avatar
Drives: 16 F80 M3~09 E92M3~03 E46M3
Originally Posted by CHE///MIST3 View Post
Awesome efforts with great results! I am amazed at how the layers just come off like that. when the gel-coat/clearcoat came off, did that take off most of the yellowness with it? I would have thought that most of the yellow would be embedded between the weaves of the carbon fabric, but from the looks of the layers you pulled off, its mostly in the clear coat/gel coat.
GM
Thanks!
Actually all the yellowness was the clear/gel coat itself. As it peeled off all of the yellowness came with it. What you see still on CF is just like a powder residue from the gel coat. That can just be cleaned off.
From the looks of it the carbon fiber was completely unharmed. Now that it has actual clear and not gel coat should last longer too.
I am still debating wether to do Xpel clear bra again but for now just coating it with CarPro Reload once a month. Plus its under bmw cover.
IG:@DMAGARAGE - 2003 E46 M3 | 2009 E92 M3 | 2016 F80 M3
      06-30-2019, 10:19 AM   #47
DMA
DMA's Avatar
What was left was like a powder residue from the gel coat. Not sure what they used to remove it completely but little I took off was coming off with just water.
I would imagine just some grease/wax cleaner used for normal painting prep.
I know for the actual clear application there was I believe two coats then wet sand, two more coats then wet sand. Just like the OP explained. Not sure the total number of coats.
M3MPH1S592.00
      07-07-2019, 07:20 AM   #48
Alexand3r
60
Drives: E92 M3 '12
Well the inevitable happened to me yesterday. All started with a little bubble on the front, over the windshield which I didn't even notice.
Went to the car wash and the pressure washer did it's job. And from then on, things escalated quickly. It peeled like it was hardly attached to the roof...
Under it, there was a ton of yellow dust formed by the gel coat.
I'll finish it of with a razor blade for the tough parts and it goes for a clear coat this week. Will keep you updated!
P.S. Here is also a little video of the peeling process. I just used a plastic(credit card) for the job.
      07-07-2019, 08:25 AM   #49
SoCalRPM
SoCalRPM's Avatar
886
Drives: e92 M3
This is the stuff of nightmares.
      07-11-2019, 02:50 PM   #50
CHE///MIST3
CHE///MIST3's Avatar
Drives: E92 M3 6MT Space/Black
2009 BMW M3  [0.00]
2007 BMW 328i  [0.00]
Looking forward to the results ! It's nice that most of what actually turned yellow is gone....the clearcoat applied over the carbon laminate will enhance the blackness of the carbon weave.
GM
      07-11-2019, 03:25 PM   #51
Alexand3r
60
Drives: E92 M3 '12
GM
Yes, I definitely think that the yellow coloring will disappear now. It was all in the form of dust underneath and in the gel coat itself.
It's in the shop right now for the new clear coat. Will post results in the following days.
      07-17-2019, 10:37 AM   #52
Alexand3r
60
Drives: E92 M3 '12
Sorry for the delay! This is the result. MUCH better than before. The carbon fiber weave pops up much better and is more defined, also the yellowish colour is gone. Really happy with the result. So don't be scared when/if that happens to you, because it's for better.
Appreciate 3
R-3551.00
chocstraw495.50
jvictormp881.00
      07-17-2019, 03:50 PM   #53
CHE///MIST3
2009 BMW M3  [0.00]
That looks phenomenal. There appears to be plenty of depth. Can you describe approximately what they did? Number of coats, sanding in between, etc ?
Enjoy the new roof!
GM
      07-18-2019, 02:04 PM   #54
Alexand3r
60
Drives: E92 M3 '12
As far as I know 3, but I'm not entirely sure about that.
I just know that the first layer just soaked into the carbon fiber and merely left any on the surface. I think they sanded the second one and then put the final layer. Again, not 100% sure, but I at maximum there is a fourth one.
      07-27-2019, 04:39 PM   #55
yoslow
yoslow's Avatar
56
Drives: SSII E92 M3
amazing looks brand new!
      08-03-2019, 07:01 PM   #56
E92friendly
Drives: E9x m3 sexiness
I then had a body shop just spray clear over it with the OPs instructions.
[B]At body shop before they started to work on it. Lines on roof are just from the blue tape I put on it for trip there.
GM
Honestly the yellow resin doesn't really catch between the weave as long as it's prepped right and likely using scuff pads would clean it all up. Wet sanding helped to in preparation.
      03-31-2020, 02:42 PM   #57
NeverL8
NeverL8's Avatar
523
Drives: Slow
Looks really good guys! Anyone put clear xpell film over their new cf roofs?
      03-31-2020, 04:36 PM   #58
Cbozz
Cbozz's Avatar
Drives: M3
that looks very nice!
Evolve, Eisenmann, Strasse, StopTech, Active Autowerke
      04-22-2020, 12:17 AM   #59
jvictormp
jvictormp's Avatar
Brazil
881
Drives: 2008 M3 E92 6MT
Great!!!
Did you/they need to take off the windshield? Cause I've got a bubble over the windshield too.
      04-25-2020, 01:20 PM   #60
suprtofy
31
Drives: 2004 BMW M3
I’ve purchased an e92 M3 with the carbon roof already spray painted gloss black.. i know I can’t just use a paint stripper because of the high risk it damages the carbon. Anyone had to deal with a painted carbon roof before ? Any help is appreciated !
      04-29-2020, 01:24 PM   #61
E92friendly
Great!!!
They were able to rope the glass seals avoiding removal
jvictormp881.00
      04-29-2020, 01:25 PM   #62
E92friendly
Originally Posted by suprtofy View Post
I've purchased an e92 M3 with the carbon roof already spray painted gloss black.. i know I can't just use a paint stripper because of the high risk it damages the carbon. Anyone had to deal with a painted carbon roof before ? Any help is appreciated !
I dont know what to tell ya other than have it replaced. Because it is painted it would be very difficult to judge how close you are to the carbon when stripping it. It would be very very hard and twice the time to remove carefully
      05-24-2020, 10:21 AM   #63
PYE46M3
Drives: E46 M3, E92 M3
man this stuff is scary to read.
so a tiny rock chip in the roof can cause the gel coat to start to peel off?
is there any benefit to clear coat a roof in excellent condition to add more protection to the gel coat.
2005 Phoenix Yellow E46 M3 6MT Coupe
2007 Imola Red Z4 M Coupe
2013 Interlagos Blue E92 M3 6MT ZCP CF roof
      05-29-2020, 01:00 PM   #64
E92friendly
As far as I know I don't recall rocks able to start chipping the gel coat. It's the resin that's between the gel and carbon that becomes weak from the sun rays and causing a peeling point on the roof. Not rocks. When you start to see a yellow tint that's no bueno it's the resin becoming weak.
      06-09-2020, 03:05 PM   #65
Rackeu
Drives: 2013 M6
Use compressed air to help peel the roof
I tried using a credit card and a plastic razor blade, it worked just fine but it was taking a long time. I then used compressed air behind a tab of skin to "push" up under the sheet and was able to get it all off very easily in very large sheets. See below.
This link is aspirational and it does not work this easily BUT: using compressed air under the edge while teasing a peel lifts it off in large sheets and works very well.
      06-19-2020, 06:19 PM   #66
Mpow-wow
76
Drives: 2008 e92 M3 2008 X3
I just pressure washed my roof and the old polyurethane coating came of so easy! Now to get someone to re-clear it. 👍🏻
m3post
