04-25-2020, 11:44 PM | #23 | |
10
Rep 31
NitroBiz147.50 |
04-26-2020, 01:56 AM | #24 | ||||
148
Rep 384
04-27-2020, 08:18 AM | #25 |
286
Rep 305
To think about how deep that etching goes through the clearcoat try and visualize looking at it from a cutaway perspective. If the trough of those etchings goes RIGHT to the top of the basecoat the only way you'll be able to get it removed completely is to remove nearly all of the clear around it. You dont want to do that. Some scratches and etchings are permanent tattoos your car will wear for life. Once you spread a few layers of ceramic on top only you will know they still exist on the car, but go too deep with the correcting pad and burn the paint and now everyone will know the person who detailed the car done screwed up (you). Case in point, I have removed every single swirl and light cc scratch on my melbourne red e92 and what remains is probably less than 10 little cc nicks/scratches and 2 bird poop ethcings that wouldn't come out with what I consider a very thorough and slow correction process. These are only visible with your eyes 12" from the paint and letting a light roll over the surface. If I told any of you to find all of them without getting on your knees in the direct sun, you couldn't. Although I hate the phrase "good enough" the next stop is "sh*t I went too far".
I also don't think you have to do a 3 step polishing process. In a process that's already going to take a ton of time, using something like a Sonax Perfect Finish will combine at least the last two steps into one. Don't get brand loyal in this hobby. When I got started I was all in on brand x, but I've learned that every manufacturer has their strengths and so now my detailing cabinet is what I consider an all star roster, the best at each position. |
04-27-2020, 11:33 AM | #26 | |
148
Rep 384
04-27-2020, 12:02 PM | #27 | ||
Rep 942
This is a good one step process that should remove most of the imperfections in your paint without getting too aggressive and finish down to a nice polish all at once. It may not remove everything, but you may want to leave well enough alone after a while and be happy with 95% great paint. |
04-27-2020, 12:45 PM | #28 |
286
Rep 305
That's right. You have a few options with Perfect Finish (PF). You can:
1) use it for both compound AND polishing with a finishing pad if the paint condition is decent (least amount of correction, 1 pad, 1 liquid abrasive) 2) You could also use the PF on a one step MF pad (lake country makes these, and the Uro white and black mf pads would also work here) but final level of polish might not be as high here (again 1 step, 1 pad, 1 abrasive) *This is for those who want an improved paint condition and are just going to apply a sealant or wax, i.e what I did to my wife's car because she doesn't really care about the last 10% and couldn't have it sitting in the garage for a full week of deep correction** 3) You can use PF on a MF cutting pad for the compound stage and then use it again on a finishing MF pad for the polishing phase (middle amount of correction, 2 steps, 2 different pads, 1 liquid abrasive). **I would probably start here unless the car was a garage queen all its life** 4) The most amount of correction in two steps (if you want to go this far) would be something like m205 or Cutmax from Sonax (love the cutmax, no dusting) on a mf cutting pad, and then follow it up with the Perfect Finish on a mf finishing pad. (two steps, two pads, two different levels of liquid abrasive) In any of these "recipes" you have to decide the condition of your paint and what it would call for. As almost everyone else has stated, start with the lowest amount of cut and overall work involved and move up. Tape off an area maybe 1x1 that is representative of the overall average paint condition of the car. Since you know you're going to be running the PF as a final step in any of these recipes (at least I think you should) I would buy that and (2) MF cutting pads and (2) finishing pads. Work your way down my numbered list till you reach what looks acceptable to you. If you think you might need to go all the way to 4, just grab a 250ml bottle of the heavy cut solution of your choice at the time of order of the other things, just to have so you don't have to wait around for it if your test panel shows that Level 3 wasn't enough and you need to go up to that level 4. It's also always good to keep this in the cabinet in case you need to polish out an "oh sh*t" accident as most of the best heavy cuts will remove somewhere around 1500 grit sandpaper marring. Level 5 is a wet sand, but lets not go there yet. Hit us up if you get through the car and think this is needed in spots. In either case there is almost no situation where I think you would have to use 3 different liquid abrasives with the technology available today. It's not even about achieving a better result, it's just wasted time and money. Last edited by slowdown_dan; 04-27-2020 at 01:11 PM.. |
04-28-2020, 11:17 PM | #29 |
148
Rep 384
So this happened when I couldn't just leave it be. The past two nights I've been using Griot's Complete Compound by hand and tonight I went out and bought Meguiars 105 and used my G9 with the white pad and within a few seconds I saw the spot. Is there anything I can do? Did I completely fuck up?
04-29-2020, 08:43 AM | #30 |
286
Rep 305
To my point in a previous post: "Although I hate the phrase "good enough" the next stop is "sh*t I went too far"."
Did you keep the polisher moving? It looks like heat transferred from the center of the pad on a static polisher right into the paint. There's really nothing you can do to FIX it. It's burned paint. Do an IPA wipe (I prefer Gyeon Prep) but whatever you have laying around and clean out any of the polish out of that spot and get something on it to protect it, because you're not going to be able to correct that area, really ever again. I don't want to rub it in, but there's a reason most people here have mentioned starting off easy and working your way up. Going from hand compound to a machine is a big step. Polishing by hand with a heavy cut compound vs machine polishing with a light cut = huge difference (with the machine doing alot more "work"), and it sounds like you jumped straight to machine polishing with a heavy cut compound. To be fair, if you keep the pad moving and the clear hasn't been corrected before these clears can typically stand up to a heavy cut with a heavy cut pad but then again every car's paint is different, especially when they are as old as they are now. How yours was treated in the last ten years vs mine or any others is the difference maker and is why pro detailers will tell you that correcting paint without a paint depth gauge is flying blind. I dont own one either, so I fly blind very carefully. |
04-29-2020, 11:26 AM | #31 | |
148
Rep 384
04-29-2020, 12:10 PM | #32 |
Rep 1,881
im suprised a white foam pad cut that hard. i think it was a combination of sanding, cutting, compounding by hand, and the fact that it was a damaged section from bird poop.
As others have said, now is the time to stop, and apply a ceramic coating to protect.
I am never able to post pictures on forums, all my pics are on IG @baye30 https://www.instagram.com/baye30/
Current Garage - [2011 E90 M3 ZCP] [2005 E53 X5 3.0 Sport] [1988 E30 325IS 24V] |
04-29-2020, 07:02 PM | #33 |
148
Rep 384
Like Han Solo said....'I think you're right' LOL! Now I have to distract myself so I don't think about it.
05-16-2020, 09:42 PM | #34 | |
148
Rep 384
05-24-2020, 09:48 AM | #35 |
Rep 659
agree with many of the posts by butte2butte in this thread.... Sonax perfect finish is an excellent product (the DA version is EX 04-06). Use it with sonax yellow DA pad (has hole in the middle to cool the pad and avoid burning).... This will get about 75% of the imperfections out without overly thinning your clear coat. If you want something more aggressive, go with Sonax Cut and Finish on sonax yellow Pad to get more imperfections out. Sonax makes a super aggressive red pad that will cut much more than the yellow pad but I wouldn't use it on a newer car like this.
You can spend months chasing imperfections with various products, pads, sand paper. In the end, it really depends on how much you want to thin out your clear coat and how many residual imperfections you can live with. Personally, im a EX-04/06 kinda guy. Gets 75% of the imperfections out and I'll live with the rest of the flaws knowing that i still have some clear coat left. There's really no reason to chase every swirl mark on a 7+ year old car that will NEVER have perfect paint due to rock chips on almost every panel which are much more noticeable.
2005 Phoenix Yellow E46 M3 6MT Coupe
2007 Imola Red Z4 M Coupe 2013 Interlagos Blue E92 M3 6MT ZCP CF roof |
NitroBiz147.50 |
05-06-2022, 08:26 AM | #37 | |
Rep 1,925
Its proven, tons of videos, and designed for a beginner. Don't get ahead of your ski's. Then as I get more advanced I'll play around with different products. I made the investment of $200 into my own tools. If I can learn myself, so much better then forking out $$$$ every time I need a paint polish or correction.
Current: 17 OG M2 / R8 Performance
Past Performance Cars: 01 M3, 05 M3, 06 M5, 08 M6, 08 M3, 11 M3, 13 M3, 15 M3, 911 C4S, 911 GTS, 17 M2,R8 V8, R8 RWS |
12-10-2023, 02:56 PM | #38 |
126
Rep 164
^Its a fantastic investment and with all the videos on youtube, I don't see a reason not to learn to do paint correction yourself. I think many people see it as tedious, like "I gotta use this DA on this car two times, plus apply a sealant". At least thats what I've gotten out of my friends who have seen my car before and after, and then asked me how long it took.
As far as products go, I have always been a Meguiars user not having used anything else. My local Autozone had Griots compound in the yellow bottle that I bought after I ran out of Megiuars M105. That was enough for me to completely switch over to Griots products and their BOSS system. For me the working time of Griots is far better and less dusting than Megs. |
