New 2009 2010 BMW Z4 - ZPOST
      05-21-2018, 11:52 AM   #1
KIRK!
Amateur Philosopher
KIRK!'s Avatar
Drives: 2011 Z4 3.0i, Black
Post YOUR E89 Wheel & Tire Questions and Photos With Specs
Digging through tons of threads is a bummer. Especially when you still don't find an answer to your question. Could someone consolidate all of the wheel and tire spec info into one thread? It would also be handy if everyone would post pics of their Z4s with suspension, wheel and tire specs here in one place for reference?
My question is:
I want to stay with a square setup on my 30is with Eibach Pro springs, but go a little wider and +1. I've had staggered setups on previous cars, and, while it looks great, it sucks to not be able to rotate tires. So I'm thinking 18x8.5 et30 with 245/35 or 235/40 tires. Is there any fitment issue with these? I like that the 235 is slightly taller.
I'd like them to look as flush as possible. Will I need a spacer in the back? If so, what size, and will I need longer lug bolts?
Thanks in advance.
Old specs: 17x8, 225/45R17 with Eibach Pro springs. Pretty boring right now.
      05-26-2018, 07:01 PM   #2
KIRK!
Amateur Philosopher
KIRK!'s Avatar
New Specs: 18x8.5 et30 with 235/40. Still on Eibach Pro springs.
Loving the non-RFTs and staying with meatier sidewalls!
      09-24-2018, 09:07 PM   #3
Ed P
29
Drives: 2016 Z4 Sdrive28i
I have a 2016 28i, with the same wheels and tires as your original set (17x8, 225/45R17).
Your new wheels & tires look fantastic. I’m not planning on new wheels (actually like the stock wheels as is), but I would like to go to 235/45R17, non run-flat. Will they fit the stock wheels? Should I be concerned with the increase in diameter from 25” to 25.3”?
Thanks all!
2016 Z4 Sdrive 28i
Black Sapphire Metallic over Black Kansas Leather
... gone but never forgotten ...
2013 135i M-Sport
Mineral Gray over Oyster Boston Leather
      10-04-2018, 08:39 AM   #4
davis449
Drives: 2014 Audi SQ5
Stock setup with OEM Bridgestone 225/40/18 Front and 255/35/18 Rear RFT's.
19" VMR V703's 225/30/19 Front and 255/35/19 Rear Michelin Pilot Super Sport's.
      10-08-2018, 11:49 AM   #5
Vetracr
32
Drives: 2010 BMW Z4 3.0
My car is a 2010 3.0si 6 speed with 12K miles on the odometer. I've set the car up to handle like a sports car rather than like a touring car. It has an E46 M3 rear suspension and an E90 M3 front suspension, Grountd Control camber plates, Turner strut bar, Koni FSD shocks, H&R sway bars and stock springs. I've upgraded to 330i front brakes with 340x30mm rotors. It rides on TSW Bathurst 18x8.5 front and 18x9.5 rear rims mounted with 245/35-18 front and 265/35-18 rear Firestone 500 (rebranded Bridgestone R003's) tires. I also added an oil cooler for hot Florida weather, oil and water temperature gauges and an oil pressure gauge. I've removed the side and rear badges and painted the side lights and reflectors to clean up the lines of the car.
      10-08-2018, 02:15 PM   #6
Crazy8
Crazy8's Avatar
Drives: 2013 Z4 sdrive35is
Here's some crappy cell photos of my set up. It should be noted that the rear has settled ever so slightly since these photos were taken.
Car: 2013 35is
Suspension: H&R sport springs, E9X front control arms, Turner adjustable rear camber arms, H&R sways, 5mm spacers front, 10mm spacers rear
Wheels: stock style 326 wheels (19 x 8 et29 front, 19 x 9 et 40 rear)
Tires: Michelin Pilot 4s 225/35r19 front, 255/30r19 rear
I eventually want to go to KW V3 and 19" BBS LM-Rs but I've spent WAY too much money on this thing this year.
Current: 2013 Z4 sdrive35is MHD 2+ E50 OTS Tune, Wagner EVO 1 Comp FMIC, ER CP, Tial BOV, VRSF CLDPs, E9X Control Arms, H&R Springs, H&R Sways, Turner Rear Camber Arms, M Performance BBK, BBS CH-R wheels, Stubby, CeramicPro, Late Side-markers, Michelin Pilot 4s
Past: 1995 840ci Calypso Red/grey w/a bunch of modz
      10-12-2018, 01:24 PM   #7
tommylotto
Drives: 2015 BMW Z4 sDrive28i
Here she is with the stock 17" wheels and 225/45R17 Pirelli Cinturato Run Flats:
Here she is with 19" Enkei Tuning Raijin Black Wheels, 19x8 up front and 19x9.5 in the back. 225/35ZR-19 Michelin Pilot Sport 4S XL up front and 255/30ZR-19 Michelin Pilot Sport 4S XL in back. Plus yellow caliper covers
      02-14-2019, 02:01 PM   #8
Crazy8
Crazy8's Avatar
Let's revive this thread. Anyone else care to share their wheel set-up? I'm in the market for an upgrade as I can't keep my stock 326s from bending on these crap L.A. roads.
      05-08-2019, 01:39 AM   #9
Go351
22
Drives: 2016 M4 Coupe Sakhir Orange
to run flat or not to run flats...
Hi all.
I'm thinking of going with non run flats when I replace my tires next week.
Can I assume those of you who have done this, simply purchase the pump and goo pack from bmw?
I have never used one of these and am interested in your experience. Can I rely on this setup with no spare at home?
Lastly, is the result better or worse in the end. I. E. Handling on stock suspension?
Thanks
      05-08-2019, 10:42 AM   #10
paris1
Drives: 2013 35i Space Grey over Coral
Jesus; don't buy the kit from BMW! There are much cheaper alternatives on Amazon (https://www.amazon.com/Slime-50123-F.../dp/B0732F1YZX) which I'm sure are available to you in OZ. I have this set up in the trunk of my wife's DD Z4, but have never had to use it. Non run-flats will transform the ride of your car and offer better handling and/or wear (depending on the specific tire you use). AND they're a helluva lot cheaper. I just put a new set of Bridgestone Potenza S-04 Pole Positions on her car for under $800 US ($1140 Australian) installed.
      05-09-2019, 08:27 PM   #11
Eltee
Drives: 2011 Z4 35i
Due for a new set of 18" tires and probably will do the Pilot Sports.
Maybe it's time to upgrade wheels too.
Have always really liked the style 326 wheels but do not want to go to a 19" wheel. Anyone know of an 18 inch wheel that is similar to the 326s? (I assume the 326 is not made in an 18)
      05-09-2019, 08:43 PM   #12
Eltee
Drives: 2011 Z4 35i
I agree with Paris1. Get the Slime from Amazon or WalMart.
Another thing to consider is Michelin gives you a 3 year road hazard warranty. They'll come out and change your flat or tow you up to 150 miles for no charge. I feel pretty comfortable with the Slime kit and the backup Mich warranty.
      05-10-2019, 08:57 AM   #13
Go351
22
Thanks paris1.
Yep. Picked up a slime kit today. 60 bucks on sale. It's a bit bigger than the bmw kit but less than half the price. Pretty happy with that. Tyres tomorrow.
      05-18-2019, 01:16 PM   #14
Zed4USA
Drives: 2014 BMW Z4 sDrive28i
Hey tommylotto,
Is it possible to see a full side view from further back (across the street)? I've been thinking about black wheels and caliper covers and would like to see how it looks from some short distance. Thank you!
      05-18-2019, 01:18 PM   #15
Zed4USA
Hey Kirk, it looks like you swapped out the front kidney grilles. Is that the glossy black or matte black?
It also looks liked like you de-badged. Did you use the fishing wire method, and did you de-badge the rear also?
      05-18-2019, 01:31 PM   #16
Zed4USA
* Front alloy wheels: 18" x 8.0" offset 29 weight 11.93 kg (oem 36116782905) 26.3lbs, rear alloy wheels: 18" x 8.5" offset 40 weight 11.92 kg (oem 36116782906) 26.3lbs
* Star-spoke wheels (style 276)
* Front 225/40-18 and summer tires includes: run-flat, rear 255/35-18 and summer tires includes: run-flat
On the day I bought her:
      05-22-2019, 12:43 PM   #17
Tibs
Drives: 2014 Z4
2014 Z4 35i M Sport
Wheels: Apex EC-7 18x9 E31
Tires: Federal SS595 Front: 255/35/18 Rear: 265/35/18
The front does just barely fit the 265 without any rub on a stock suspension, so I'll be going to a square setup with those.
      07-31-2019, 04:08 PM   #18
Webless
Drives: Z4 E89 35i
Hi Guys,
I have a 2010 35i E89 and need to find some replacement alloys due to failing weld repair.
I am considering these, taken from the new G29. Is there any way of establishing if these would fit as a straight swap? I already have 19" wheels.
Thanks
Steve
https://www.ebay.co.uk/itm/19-inch-S....c100903.m5276
      07-31-2019, 06:11 PM   #19
cdmulders
cdmulders's Avatar
327
Drives: 2013 535xi
G29 wheels will not directly fit an E89. Both the bore diameter and wheel bolt holes are different. Check out this link for a comparison and scroll to the bottom to see the specs for E89 and G29.
2013 535xi, Carbon Black, beige interior, M Sport package, HUD, DDC & ARS, ACS springs, Kelleners wheels
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension
2000 528i, Cosmo Black, beige interior, Sport package (retired)
      08-01-2019, 03:29 AM   #20
Webless
Drives: Z4 E89 35i
Ah ok, I see, thank you..
      08-01-2019, 06:27 AM   #21
Webless
Drives: Z4 E89 35i
I have tyre pressure monitoring - is there more than one configuration for Z4's?
If your vehicle has an existing TPMS, it will either function Directly from TPMS Tyre Valves, or Indirectly from the vehicle's AB
      08-10-2019, 01:41 AM   #22
Asbjorn
Asbjorn's Avatar
China
90
Drives: Z4 N54 DCT (VTT GC lites)
Nice setup!
Here's 9J ET30 with 245 slicks which is possible with some 2-3deg camber up front. Ideally you would run 255/35R18 instead of 245/40 with this square setup. 245/40 is a bit too tall up front.
Im on stock springs up front and eibach pro rear.
jts1981212.50
zpost
