11-23-2022, 02:38 PM | #23 | |
Rep 612
Change history here… https://www.dropbox.com/s/8h1vabklgz...0List.pdf?dl=0 Build thread here… https://z4-forum.com/forum/viewtopic.php?t=131886 |
12-30-2022, 06:46 PM | #24 |
19
Rep 125
I replaced the two rear vents. Part Number 64-22-6-909-340. Cost: $43.
Couldn't find any schematics on the web to perform the installation. The stealership did it for me ($345). At first glance, and after a super heavy 24 hours rain here in PNW, it seems that it did the trick. The battery and the rooftop pump compartment is totally dry. I will continue to monitor and report back. |
tranquility3249.50 |
05-05-2023, 04:14 PM | #25 | |
sportscars only
3250
Rep 3,199
So, I skimmed my thread and I don't think I have any visible trim crack issues. The water is coming long that 'waterway' coming down from the top of the trunk to the sides and somehow the water is supposed to fall down at where it meets the rear lights?? (I cannot state what a STUPID design this is, how is it possible to have such a stupid design for water to travel that way???) Anyway, something is wrong because instead of falling out harmlessly, the water is accumulated in the bottom well of the trunk where the battery and other stuff are located. I have tried to alleviate the prb by stuffing cloths where the toolkit is supposed to be in addition to the rear trunk wall (for me, that is where the water is coming from). Besides getting my trunk well wet, water eventually drips down onto the ground and as a result rusted the surrounding area (pls see photo): is this a cause for concern? I experimented stuffing w cloth the side of the 'waterways' before it meets the rear lights and as a result water flowed from the left and right sides of the floor well; before that, the water only came from the rear side. Anyway, what a pita and stupid design. Argh.
The richest one percent of this country owns half our country's wealth, five trillion dollars. One third of that comes from hard work, two thirds comes from inheritance, interest on interest accumulating to widows and idiot sons and what I do, stock and real estate speculation...It's bullsh*t. I create nothing. I own. We make the rules, pal...Now you're not naive enough to think we're living in a democracy, are you buddy?
05-06-2023, 03:34 PM | #26 |
19
Rep 125
The fix passed the PNW winter with flying colors. The trunk and the battery compartment are now dry like the Atacama desert
Even the SA was not aware where these flaps / rear vents are. He had to talk to his foreman. It seems that there are 2 options to get there: either remove the rear bumper or remove the wheel arch liners. Not sure what they did. I can go and ask if you insist P/N: https://www.ecstuning.com/b-genuine-...n/64226909340/ I don't think that it's a design issue. Otherwise there would be thousands of people complaining. It's probably a manufacturing issue and/or the quality of the first rear vent was not closely looked at. My car was produced during March 2009, so the very first batch. Looking at your pictures, holy cow, you better fix this ASAP at your BMW dealership and ask an indie shop to give a closer look at the underbody rust, maybe apply a coater such as Rust Oleum. Good luck. Peace. |
05-06-2023, 04:18 PM | #27 |
Call me "Dr. Bob"
128
Rep 401
Drives: BMW Z4 E89 sDrive 30i
05-06-2023, 05:27 PM | #28 | |
sportscars only
3250
Rep 3,199
I do disagree and would say it's a design defect....the waterway leads to the rear lights, and then who knows where it's channeled? It's just a stupid design, and relying upon some plastic? flaps is just insane. I'm sure the Japanese are smarter than that and don't have this prb, but I thought that Germans were smart too. One would think that they would be esp careful since it's a roadster and all those electronics are back there including the roof pump, lights, various wiring, etc, but they just 'winged it' it seems. I now suspect that's probably why my right rear light died as LED is supposed to last a long time. EDIT: I imagine what they designed is akin to having some layers of sheet metal separating Mike Tyson from the guy he wants to kill. Sure, it'll hold him for a bit but *eventually* those sheet metal WILL fail and that guy will be dead LOL. Vs look at a Miata trunk, for example, it's basically a tub and the metal surrounding is molded so that water will NEVER have a hint of going in there and will just slide off the rear of the car harmlessly. Simple, effective. I have NO idea what BMW was doing, trying to be cute and I see some stupid trim in the trunk and haven't the foggiest clue why it's there because I dunno why water is being guided there in the first place. Argh..... Tx, that's good to know. I hate going to the mechanic for non-regular stuff.
05-07-2023, 12:15 AM | #29 |
Call me "Dr. Bob"
128
Rep 401
05-07-2023, 03:37 AM | #30 |
37
Rep 121
I'm glad there's a solution for this. Something to keep an eye on. In my Mercedes GLE, I have a recall to correct a leak in the rear... the solution is to drill a hole to let the water out rather than correct the water from getting in...
02-25-2024, 10:58 AM | #32 |
Rep 1
I have same issue on my X3 E83, could not find the leak...
As my driveway slopes slightly I temporarily solved the water leak by parking the car the opposite direction to the way I usually park.... I now park slightly 'nose up' and no more water comes in ... bizarre! Still need to work out why it leaks though...! |
02-25-2024, 12:12 PM | #33 | |
Rep 612
03-01-2024, 06:12 PM | #34 | |
sportscars only
3250
Rep 3,199
Anyway, can you please explain what you meant by 'body in white'? I'm confused. I can't visually determine if replace those seals would do the trick. So far I think that the water is coming in from the rear panel of the trunk: is the trunk floor lower than where the seals are...if the seals are lower, I would assume that replacing them would have no effect? Tx again.
03-02-2024, 04:41 PM | #35 |
Rep 612
Body in white means the basic shell of the car..in this case the design of this was given to an external agency since the E89 was a niche product..
03-02-2024, 07:36 PM | #36 |
sportscars only
3250
Rep 3,199
I'm really slow, does just that mean all the external body panels of the car? Why is this significant vs having it done in-house, not sure what Robb was getting at? Tx.
03-03-2024, 02:11 AM | #37 |
Call me "Dr. Bob"
128
Rep 401
Side info, because you are constantly bashing BMW. All the problems with your old car could have been avoided if the owner had taken care of them in time. Every detail has two points of view. Last edited by RobbiZ4; 03-03-2024 at 04:45 AM.. |
03-03-2024, 02:57 AM | #38 | |
Rep 612
03-03-2024, 05:55 AM | #39 |
sportscars only
3250
Rep 3,199
BMW is still responsible in the end, no? Subcontracting doesn't absolve the hirer of liability. Anyway, I don't think I neglected anything to deserve this leak due to a design flaw. The bashing is well deserved.
03-03-2024, 06:08 AM | #40 |
Call me "Dr. Bob"
128
Rep 401
Ok, you win and I'll keep calm now.
Good luck.
03-04-2024, 08:00 AM | #41 |
Rep 33
I have been watching your posts, and keeping an eye on my trunk too!
Have you tried to dry it out completely, besides rags, also a shop vac works well. Then, get out a garden hose and really soak it good... focusing on the trunk, then start looking for the ingress point. There are so many electrical components located in that area, you need to figure out the source. Once you have it nailed down, hopefully its a quick fix... then you can get out and enjoy the car! |
03-04-2024, 02:46 PM | #42 | |
Rep 612
As cars age the weaknesses / flaws steadily emerge..especially with use and time.. Every design has its issues..some are common to the manufacturer eg injectors gaskets, plastics cracking…somethings are type specific….eg adaptive dampers, roof system The issue facing a non technically competent / able person is how to handle this..I use a network of Indy’s plus now with a decent garage and time quite a few jobs myself.. It is what it is..the problem is folks just don’t know , how can they know what could unfold.. It’s not helpful but it’s just an observation..FWIW Personally I anticipate some problems with preemptive work, I have some spares ready to go.eg cam cover, spare injector, HPFP, switches and sensors for the roof..other things I take as they happen..eg my CIC just died..scrambling now to fix it..
03-04-2024, 05:31 PM | #43 | |
sportscars only
3250
Rep 3,199
The engine is great, but the surrounding parts like the HPFP, LPFP, OFH, injectors, etc are not so good. The hydraulic pump is no stilts, so presumably they even anticipated water getting it, which is just crazy and just not a good design. I don't see how difficult it is to have a proper flow of water to keep separate from the electronics. Anyway...
03-05-2024, 02:39 PM | #44 |
Rep 33
I decided to accomplish some of the things posted here... Preventative Maintenance goes a long way.
I replaced the salmon-colored fuses in the trunk, which can go bad. After my Carly arrived, it told me my battery was in bad shape... even though it would crank the car with no problem. Battery replaced, Carly registered it, and now I feel better for all the little electrons running around within the zed4. I also placed a plastic bag around the CT hyd motor, so if water does get inside the trunk, the motor will stay dry. I looked for any previous stains, rust, etc... all looked good. We inherit the risk when we purchase these cars, and we all know... every car has its problems, but cruising down the highway with the top down... kind of makes it worth while. |
RobbiZ4127.50 |
