Autotalent
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > M3 / M4 Photos and Videos
      05-09-2022, 03:31 PM   #23
astris
Drives: M4 ZCP Individual Mintgruen
Originally Posted by M3nmotion18 View Post
Yes! That's me. How do you like the Mosselman Turbo?
Just started the tuning process with Bend. Will take a good amount of time. I'm guessing around 12-15 revisions (their process is very meticulous and in small increments). It's possible too that I'm the first person running the combo of upgraded turbos, EU5, Dorch lift kit, and the new PR Stage 3 brushless LPFP. The LPFP is the unknown as it's truly drop in (no regulator or return) and uses the factory EKP.
Only thing to note so far is that with the turbos and all the fueling upgrades, if feels like there's actually a top end! Really wanted that as I'm coming from a supercharged E92 M3.
      05-11-2022, 11:26 PM   #24
wknd_M
Drives: 18’ MG ZCP F82
This is rare, sweet build so far
astris616.50
      05-17-2022, 01:08 AM   #25
astris
Quick update:
Pump tuning pretty much finished up and first logs with E30 looking good. Tires breaking loose at the top of 3rd and a lot of power left. Will eventually have to limit power as we climb with E85. It's definitely looking like there's potential beyond what the stock rods can handle. All without PI or meth, and factory knock tables.
      05-17-2022, 11:34 PM   #26
M3nmotion18
M3nmotion18's Avatar
Drives: 2018 IR ZCP BM3
2018 BMW M3  [9.71]
2021 MINI COOPER  [10.00]
2023 GENESIS GV60  [10.00]
2017 LEXUS RX350  [10.00]
Definitely a big increase with E85
      05-18-2022, 10:15 PM   #27
astris
Yep. Going to need new tires asap if I want to run anything more than pump and hook in 3rd.
Once all tuning is done I'll probably run it between E35-45 most of the time.
      05-18-2022, 10:38 PM   #28
RugbyBro
RugbyBro's Avatar
7602
Drives: M3
Are you going to stay on the 666s?
Current: F80
Prior: F82, F32
      05-18-2022, 10:53 PM   #29
astris
Reaaallly want to since I'm all about OEM+. Was originally planning 295 Cup Connects, but not sure if those will even hook in 3rd. If I don't stick with the 666m I'll go with either Richland GT4 or Titan7 T-S5 since they are both are exact/similar to 763m and can fit 305s.
      05-18-2022, 11:25 PM   #30
RugbyBro
RugbyBro's Avatar
7602
Drives: M3
I've got the 285 * spec Cup connects in the rear right now (20x10 like your 666s) - very grippy, gonna do some back roads this weekend and another track day in a month to really maximize the grip potential. You can fit the 295s but it'll bulge a little… I'd definitely stay away from any 295s that run wide. I'm only running the 19/20 setup because I can't bring myself to sell the 763s even tho I want to because BMW stock wheels for F8X are pretty undersized in width... the RF GT4s, Titan TS-5s are much more friendly at 9.5/10.5 widths. Apex VS-5RS is another great options with even more sizes than RF or Titan.
If you're looking to hook then it's probably worthwhile down sizing your wheels - more compliance for a better hook and better tire selection as well.
Current: F80
Prior: F82, F32
astris616.50
      05-18-2022, 11:57 PM   #31
M3nmotion18
2018 BMW M3  [9.71]
+1 for Apex VS-5RS.
      05-19-2022, 01:02 PM   #32
astris
LMK how they do! I'm not too worried with 295s on the 666m and I'll likely go with Cup Connects in whatever size I end up with.
The car will be 99% street driven, so definitely sticking with 20s even if that does cost some in traction. Oddly enough, there are a lot of sticky tire options in 20s for the rear, but almost nothing matching for the fronts. 19f/20r has a lot of options.
+1 for Apex VS-5RS.
Oh, these weren't on my radar at all! They only made 18s and 19s. However, looks like they are releasing the VS-5RS in F: 20x9.5 5x120 +22 / R: 20x11 5x120 +44 in August! Same sizes and ET as both the Titan7 and Richland. That setup will accommodate a 265 or 275 front with 305 rear. Will keep them on my radar, but seems they will run a bit more expensive.
      05-19-2022, 06:43 PM   #33
RugbyBro
RugbyBro's Avatar
7602
Drives: M3
Haha very brave with the 20s around our neck of the woods. My rears will probably be a little bent by the time I replace my tires. But yah, that 20x9in front is super limiting Cup2s will make a massive difference in the driving experience tho. If you do get into a 19/20 setup, there are some noticeable benefits on the street - more settled front end, better contact patch, and better tire selection.
Current: F80
Prior: F82, F32
      05-28-2022, 03:55 PM   #34
astris
Small Update: Tuning is going great. Up to E60 now with lots of fueling headroom still left.
Back in the shop in about a week for Mosselman oil thermostat, and brake pads and fluid. Also picked up the billet Paradigm Engineering oil filter cap to match the billet Mosselman thermostat housing with titanium hardware.
      06-02-2022, 12:24 PM   #35
_jenks_
_jenks_'s Avatar
England
39
Drives: BMW F80 M3 / Alfa GT Junior
2016 BMW F80 M3  [0.00]
beautiful colour
astris616.50
      06-03-2022, 06:24 AM   #36
heitzke
heitzke's Avatar
1153
Drives: '15 M4 base, '04 Cobra
Lookin good as always! Can't wait to see the finished product!
Mosselman-powered M4 - 698/714 | 2.9 Whipple 2004 Cobra - 690/645 | Instagram
astris616.50
      06-03-2022, 08:42 PM   #37
astris
Thanks! And same. Haha. Waiting for my Wagner front mount to arrive, then it's install time for:
Wagner front mount
Front pads and sensors
Rear pads and sensors
Brake fluid flush
Paradigm cap
…and maybe SPL toe links with lockouts. 🤔 (traction is a problem)
Tuning should wrap up around the same time. Then on the dyno and maybe some photos with a real camera. Figure in the next month or so.
New stickier/wider tires in August and possibly wheels (need more wide!). That should mostly wrap up the build. Riiight.
      06-12-2022, 12:13 PM   #38
papasmurf_m3
papasmurf_m3's Avatar
Drives: YMB F80 M3
Gorgeous car, great build!
Mint green is one of my favorite colors.
60-130 mph 6.72 secs
1/2 mile trap speed 158 mph
ecutek - bend calibration pro tune - flex fuel - mpe - stock turbos - oem+
astris616.50
      06-21-2022, 01:49 AM   #39
astris
Quick test. MDM on and cutting throttle while the poor 285 PS4S spinning 3rd/4th.
Not too shabby for no PI, no meth, no traction, and all the computer nannies. With any traction seems like 5s will be no problem.
      06-22-2022, 07:41 PM   #40
VRForged
VRForged's Avatar
Drives: F80 M3
Wow! Can't say I've been a big fan of mint colored cars but I also can't say I've seen a Mint F82... this color is gorgeous! The black & carbon accent it quite well, loving it & can't wait for more pics.
astris616.50
      06-24-2022, 05:50 PM   #41
astris
Last minute pick up for install next week. Shout out to Golan@Autotalent for the great price and getting these here in time!
      07-06-2022, 11:45 PM   #42
astris
Added some functional engine jewelry - Mosselman billet oil thermostat with titanium hardware and Paradigm Engineering billet oil cap.
Also new brake pads, sensors, Stoptech stainless brake lines, Motul brake fluid, and SPL aluminum/titanium rear toe links with eccentric lockouts.
Up next week - alignment and Wagner front mount heat exchanger.
icegrill2078.00
      07-07-2022, 02:51 AM   #43
Dang3r
Schmollbraten
Dang3r's Avatar
Germany
12512
Drives: M4CPC // HP4 Comp.
You should go to ask Mosselman for sponsorship
Exquisit color, saw last time a G82 into same. But man, your car value must have went more then the double price for just the car. Did your insurance are covering your expensive mods or the car ready modified into full manner?
Citizen of ///M - Town, where too much is just right
Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox
      07-09-2022, 01:11 PM   #44
astris
Thanks! I think I got a pretty fair deal on the price of the car considering the market. It only had a few mods when I purchased it. As for insurance, it's just a regular, stock M4 to them.
f80post
