New 2009 2010 BMW Z4 - ZPOST
      12-06-2023, 04:57 AM   #23
spoiderbaby
Drives: BMW z4 e89 3.0
Just to confirm
to open the Boot \ trunk using this PIN 12 - I need to supply 12 volts to it with a length or wire ?
If so does it need to be connected constantly or just a momentary connection ?
Your post doesn't mention
      12-06-2023, 05:01 AM   #24
RobbiZ4
Call me "Dr. Bob"
RobbiZ4's Avatar
128
Drives: BMW Z4 E89 sDrive 30i
      12-06-2023, 07:56 AM   #25
spoiderbaby
Vielen Dank
      12-18-2023, 06:42 AM   #26
spoiderbaby
Update to the saga
So I tried so hard to access the fuse box so I can trick pin 12 and pop my boot lid. But heaven only now what kind of being could contort themselves enough to even complete this task..
I have just dropped off my stricken z4 ( 27 miles of BONG! ) half built, to a local BMW specialist who have promised to have a good look at it.
Maybe they will fix things..
One question which I have not been able to find an answer to:
How do you put the roof in maintenance mode if the roof doesn't move ?
      12-18-2023, 07:39 AM   #27
RobbiZ4
Call me "Dr. Bob"
RobbiZ4's Avatar
128
To be honest, you should not even think about touching anything else in the roof. If this simple task isn't yours, others would be much more complicated with a huge potential of damaging additional things in the roof.
Jmy2ct
RobbiZ4
      12-18-2023, 07:44 AM   #28
spoiderbaby
.. a task beyond ..
How do you get the roof into the maintenance mode if the roof wont move ?
      12-18-2023, 11:41 AM   #29
RobbiZ4
Call me "Dr. Bob"
RobbiZ4's Avatar
128
.. a task beyond ..
There doesn't exist any!
No emergency close, no emergency opening with standard tools and knowledges.
      12-19-2023, 09:33 AM   #30
javis20
13
Drives: 2011 Z4 3.0i Silver
Opening the boot is the easy part. The pin 12 trick or get someone with ISTA to do it. Once your in the trunk you will need to get to the CTM module and pull pins and temporarily wire in your new switch to trick the convertible top into working. This will allow you to put it into service position. Then you can replace the (2) microswitches, which is relatively easy. However, I agree with Robbi and think all this may be above your pay grade. So go to option 2.
Option 2: Many times these microswitches are somewhat intermittent. You may drive it a few days or weeks and magically it will start working again. Then quick take it into the garage, put it into service position and replace the microswitches, which is the easy part. My microswitch came back to life a few times before permanently failing.
Option 3 - Take it to an indy garage and give them some of this sites info on how to repair. More than likely they have never done this before. You don't want them racking up several unnecessary hours for this repair.
      12-19-2023, 09:40 AM   #31
RobbiZ4
Call me "Dr. Bob"
RobbiZ4's Avatar
128
Originally Posted by javis20 View Post
However, I agree with Robbi and think all this may be above your pay grade. So go to option 3.
Full ACK.
      03-06-2024, 09:30 AM   #32
spoiderbaby
Sorry to drag up and old post...
...so the saga continues
The garage I left my z4 at back in December last year - still have it !!
They are saying they can not get to the switch which is faulty AND BMW have told them the only way is to destroy the roof lining !!
Is this right ?
Apparently BMW just replace the roof lining when doing this repair !!
They are now trying what Jarvis suggested - trick the CTM with the replacement switch though I think.
      03-06-2024, 01:19 PM   #33
RobbiZ4
Call me "Dr. Bob"
RobbiZ4's Avatar
128
OMG!
What is the error message causing this decision?
I'm pretty sure, that each of the two switches IN the roof shell is ok and needs no replacement. Only the wires TO these switches will break after 6-10 years.
Each E89 roof can be repaired in half a day. What the hell are they trying to do over 3 months?
Is this right ?
That is absolute nonsense, because both headliners are clipped into the roof shells. You can even unclip them by hand without destroying the clips.
Have a look at it:
https://www.realoem.com/bmw/enUS/sho...diagId=54_0397
Be cautious, this shitty piece of paper costs about 700€ (seven-hundred-euros)!
      03-07-2024, 04:38 AM   #34
Hedders
Drives: BMW E89 3.0i
I hope nobody minds if I tack on to the end of this as my issues are quite similar. I have been reading up on this a bit before asking questions.
car is a 2012 E89
Error code '0692 microswitch, right rear end closed'. Roof still works but 'stutters' and almost constant red lights and bongs while driving now.
The boot area is bone dry and always has been as far as I can see.
I have examined the wiring around the dodgy bend behind the headrest and all of that looks brand new too.
Salmon relays ordered but not arrived yet.
I am not a qualified engineer type so is there anything else I should be thinking about doing myself?
Also, Robby mentioned on another Z4 forum that I can not for the life me get registered on that you can turn off the annoying bongs! Anyone know how??
cheers,
Hedders.
      03-07-2024, 05:22 AM   #35
RobbiZ4
Call me "Dr. Bob"
RobbiZ4's Avatar
128
That's not a wiring problem!
Task #3:
⌛E89: Retractable Hardtop (roof) Maintenance (and additional) tasks
https://z4-forum.com/forum/viewtopic.php?t=130932
You can pull the fuse of the amplifier to stop the bongs. But better to get these two microswitches replaced.
      03-07-2024, 06:35 AM   #36
Hedders
Thanks Robbi!
I figured I will replace the two relays as I can do that myself and, if (as we all probably suspect) that doesn't fix anything I will get the switches done by someone who knows what they are playing at.
In the mean time i would like to silence the alarm. Could you please give me a little guidance on 'pulling the fuse from the amplifier'?
I assume this is not the amplifier that also plays my music?
Where is this fuse please?
Hedders.
      03-07-2024, 06:54 AM   #37
RobbiZ4
Call me "Dr. Bob"
RobbiZ4's Avatar
128
Thanks Robbi!
Of course, it is.
https://z4-forum.com/forum/viewtopic...73319#p1973319
      03-07-2024, 07:06 AM   #38
Hedders
Bloody typical!
Thanks very much Robbi
RobbiZ4127.50
      03-11-2024, 01:47 PM   #39
spoiderbaby
So the garage I took my z4 to have admitted defeat and I am going to pick it up this week sometime.
Spoke to Mike at the Zed Shed in Warrington - booked it in this something I should have done last year...
Also I found someone who recommended the Zed Shed to me he was able to stop the BONG by jamming a drawing pin down the side of the roof open button - apparently if the button is depressed it doesn't BONG. If this works its much easier than pulling the audio system fuse from the 'impossible to get to fuse box'
Thoughts ?
      03-11-2024, 02:33 PM   #40
RobbiZ4
Call me "Dr. Bob"
RobbiZ4's Avatar
128
So the garage I took my z4 to have admitted defeat and I ...than pulling the audio system fuse from the 'impossible to get to fuse box'
Thoughts ?
Removing 3 screws and pulling down the panel? It takes 2 minutes, if not less.
      03-12-2024, 03:10 AM   #41
spoiderbaby
Yeah right.. I couldn't even get fuse box thing to come down on its crazy hinge thingy. There is obviously something I am not doing right.
However like I said instead of pulling the audio fuse - apparently jamming a drawing pin into the roof down switch might silence the BONG. A lot easier than pulling out the fuse ( as a temporary measure ).. no?
      03-15-2024, 04:19 AM   #42
Hedders
Thoughts ?
It's not just me then!! I struggled for a few minutes trying to pull the fuse box 'down and out'. I unclipped some of the wires that seemed to be stopping it from moving but that thing would still not come out far enough for me to do anything with it. Feels like i am just going to rip wires out or something.
Good luck with your issues!
      03-15-2024, 04:24 AM   #43
spoiderbaby
lol yeah it seems there is a bit of 'smoke and mirrors' involved when working on these cars.
I am going to pick up my Z4 in about an hour from the garage which has had it for 3 months. Going to try the drawing pin idea ( to stop the constant BONG ) because next Monday I have 134 mile journey to the Z4 safe haven - Zed Shed Warrington
      03-15-2024, 07:03 AM   #44
spoiderbaby
Jamming the roof down button makes no difference to the chimes !!! BAH!
Now my rear quaters have gone down and they wont go back up - so now along with water in the boot I am going to have a puddle in the car too !!
zpost
