New 2009 2010 BMW Z4 - ZPOST
      03-24-2024, 04:21 PM   #1
Rah-Vee
Drives: BMW Z4 09 30i, 2016 C450 AMG
Drivers side lid not unlocking from top down position.
Not sure what happened but now after fixing everything else when attempting to put the top back up the drivers side top latch that holds the rear lid is not unlocking which the passenger side is functioning. I can hear sounds of mechanics whirring but it will not unlock the driver side. Attached pic of what I the result is. No error codes from this malfunction which leads me to believe that maybe its a failed electronic latch.
      03-25-2024, 07:02 AM   #2
javis20
13
Drives: 2011 Z4 3.0i Silver
What exactly were you fixing before this happened?
      03-25-2024, 07:33 AM   #3
Rah-Vee
I was fixing a leaking in the hydraulic line that goes from the trunk to the passenger pump in the roof -
https://e89.zpost.com/forums/showthread.php?t=2090301
      03-25-2024, 08:36 AM   #4
dhlairbusb4@cs.com
Drives: bmw z4
Two things...
Did you check to see if the coupler you installed is a one way flow... in other words does it flow both directions?
Could there be air in the line, possibly induced during the install? You might need to bleed it out, to allow the fluid to do its hydro thing!
Keep us posted, plz.
      03-25-2024, 02:58 PM   #5
RobbiZ4
Call me "Dr. Bob"
RobbiZ4's Avatar
128
Drives: BMW Z4 E89 sDrive 30i
OMG,
This situation is typically for hydraulic rams, which operate with different speeds on both sides. Maybe a result of "roof violence", defect of the hydraulic pump after massive water ingress and so on.
Which hose did you repair with this coupler?
On your pics it's one into the roof shell, isn't it?
      03-26-2024, 09:21 AM   #6
Rah-Vee
Hi Robbi,
Yes, this would be one of the lines that goes into the roof shell on the passenger side. There was a leak which I caused while unbundling cables to redo microswitch wiring. I was able to purchase and install the coupler and it fixed the leak. I cycled through closing and opening several times as the system charged itself up. After I thought all was good I went for a fun drive with the top down.
When I got back to my garage I decided to close the top and that's when I noticed the driver side lid not unlocking. The system continues to whirry and push but cannot move because the drivers side is locked. Im trying to find a way to release the drivers side locking mechanism so I can manually open to get at the mechanics.
I believe the pic below is the lid locking mechanism on the drivers side which I need to find a way to release in order to allow the lid to open:
      03-26-2024, 05:23 PM   #7
RobbiZ4
Call me "Dr. Bob"
RobbiZ4's Avatar
128
B21153.00
      03-27-2024, 07:04 AM   #8
javis20
13
Rah_Vee, If you do this, take a video of the process.
      03-27-2024, 11:46 AM   #9
Rah-Vee
I will definitely make a video to share. But it looks like it may take a while as I've called and searched online for the part# 83-30-0-496-598 and it seems there aren't any in the US. It will take a month before I receive it if I order from Germany. I'm still searching but if I decide to do that I will probably order 5 and post in classifieds for others.
      03-27-2024, 01:10 PM   #10
RobbiZ4
Call me "Dr. Bob"
RobbiZ4's Avatar
128
Why not just try it with a 5mm rod? Takes less than a month.
It's not a standard everyday tool for everyone, so I wouldn't try to order a whole lot of them.
https://www.ecstuning.com/b-genuine-...l/83300496598/
      03-27-2024, 02:31 PM   #11
Rah-Vee
The end of it looks like its an Allen or maybe hex key. I'm not sure a 5MM rod would work, it must engage a screw of some sort. I will try to find more info to make my own tool if possible.
      03-27-2024, 03:33 PM   #12
RobbiZ4
Call me "Dr. Bob"
RobbiZ4's Avatar
128
It was built and tested by me. On the photo you'll see my solution, rod & grip to push.
It's just to push the pivot joint. No screw no hex, no torx.
B21153.00
      03-30-2024, 11:01 AM   #13
Rah-Vee
Its has been fixed. I was able to create RobbiZ4 tool from my local hardware store but I could not figure out how to get to unlock the mechanism with it.
But while inspecting to find what im doing wrong I happened to see this-
So instead I wedged a long screwdriver in the slot and then lined it up through the opening where it is supposed to be screwed into -
Once I did that I engaged the top to go up and it finally released the lid.
After releasing I found that there was an E-clip which came off that holds a pin in place at that joint. After finding one at the local hardware store I pushed the pin in that location and put in the E-Clip and all is well. I opened and closed the top about 20 times to ensure everything is working!
Thanks to everyone for all the suggestions and help as it brought me through the course of fixing my top.
B21153.00
zpost
