TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Engine Oil Filter Housing Cap Exploded and ruined my car...HELP!!
      03-28-2024, 03:55 PM   #23
The Nightman
Cometh
The Nightman's Avatar
1090
Drives: Boy's Soul
      03-29-2024, 06:40 AM   #24
Efthreeoh
General
Drives: The E90 + Z4 Coupe & Z3 R'ster
Originally Posted by crashoverride View Post
The shop report is close to three months old.....????
I think that just means the scan found the safety inspection date as past due. I don't think it is that date of the shop report.
I wonder if someone used a set of big-ass Channel Locks on the cap during a previous oil change.
      03-29-2024, 08:22 AM   #25
M-technik-3
Drives: E30 M3, E36 M3, 328iT, 335i
1995 M3  [9.00]
2007 E91  [7.25]
1988 M3  [9.50]
What, I thought that was the proper tool for the job? It work on my Chevy.
      04-02-2024, 01:11 PM   #26
charleskeyz
charleskeyz's Avatar
Drives: 2011 BMW 328i Xdrive N51 SULEV
Same exact thing just happened to me. I think I put the filter on incorrectly, now that I see how the pressure flows in the relief valve. It was only my second oil change and the temp dropped outside here in Denver so I kinda rushed it. Huge mistake. Thankfully I knew to turn the car off as soon as I heard the loud pop sound.
Then I flat bedded it to a high end shop and went to the dealership to get a genuine filter housing cap. My cap looked like the same exact brand as the one in this post.
Shop properly cleaned my engine so the alternator didn’t fail.
Leaving the shop car ran like a champ. Now a few weeks later I’m throwing codes. I’ll make a new thread with all the details, since it sounds like this isn’t a very common problem.
      04-02-2024, 01:44 PM   #27
Efthreeoh
General
The world is going to hell in a hand basket. Good Lord.
      04-02-2024, 03:26 PM   #28
mainbearing
Drives: BMW 328i
Charleskeyz had a Uro cap.
Now it really makes me want to preventatively swap out my factory cap with a new genuine cap, regardless.
      04-03-2024, 01:29 AM   #29
Bims328i
DIYer
Bims328i's Avatar
Drives: 2008 328i E90 SULEV
Man this is wild. I've just had bad luck with any aftermarket parts. even the upper coolant expansion line by rein. Fit well when ordered. Down the road needed a new expansion tank, bought genuine. Upon trying to attach the rein upper hose it was just a floppy connection which was fixed by about 6" of plumbers tape on the outlet port on the expansion tank.
I just had to apply an even larger piece as I had the line removed last weekend.
More often than not I have learned the aftermarket parts for these cars are kind of trash.
      04-03-2024, 06:46 AM   #30
Leucosticte
Leucosticte's Avatar
205
Drives: 2007 BMW 328xi E92 6mt swap
2007 BMW 328xi  [0.00]
It depends, performance parts are usually good (I try to read reviews of them before I buy them).
Buying a URO oil cap is crazy though considering the BMW one isn't even expensive.
      04-03-2024, 07:12 AM   #31
Cal122
181
Drives: 2006 325i 2011 328i xDrive
Same! I ended up having to remove all of the rein hoses as part of my cooling system overhaul and replace with genuine.
Bims328i270.50
