TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > I know I have a problem
      03-27-2024, 09:01 AM   #1
jbellk75rt
127
Drives: 2010 328i xdrive
BMW brake fluid..........
FCP and Bimmerworld both have BMW brake fluid listed as low viscosity for a great price butttttt the bottle says high performance and not low viscosity. Is it really low viscosity or should I spend the extra $$ on ATE or Motul? This is just for a daily driver.
      03-27-2024, 09:22 AM   #2
Efthreeoh
General
Drives: The E90 + Z4 Coupe & Z3 R'ster
Just get DOT 4 fluid. Stop stressing.
      03-27-2024, 09:37 AM   #3
jbellk75rt
127
I wasn't like this before I bought a BMW.
Appreciate 4
      03-27-2024, 01:22 PM   #4
slupie
Drives: 07 328iT, Montego Blau
I used Pentosin DOT 4 LV Low Viscosity Brake Fluid, Advance Auto Parts by me used to carry it in stock.
      03-27-2024, 01:36 PM   #5
gbalthrop
Drives: 2007 328xi E91
It's OK to "buy a BMW". Just DON'T "buy the BS" you may often see on Forums & "Web Lore".
With MOST Fluids, how often they are changed is more important than "Genuine BMW", as long as the fluid (oil, brake, AT, coolant, P/S) is CORRECT Type and a reasonable spec.
Now if you are driving a "Race Car" on the Track, that's another matter. "ONE Size Fits All" does NOT apply.
George
Appreciate 3
BRG_N54296.50
Efthreeoh17316.50
      03-27-2024, 03:10 PM   #6
Red Raider2
Red Raider2's Avatar
Drives: 2007 BMW 328i
I bought mine from Amazon
Pentosin 1405116 CHF 11S Long-Life
      03-27-2024, 04:19 PM   #7
gbalthrop
Uhhhh -- That's Power Steering (Hydraulic) Fluid, NOT Brake Fluid.
Appreciate 3
      03-27-2024, 04:48 PM   #8
Red Raider2
Originally Posted by gbalthrop View Post
Uhhhh — That's Power Steering (Hydraulic) Fluid, NOT Brake Fluid.
Oops!! That is embarrassing
      03-27-2024, 06:12 PM   #9
jbellk75rt
127
If you want embarrassing I could tell you how long it took me to disconnect the PCV hose behind the valve cover today. At least I didn't break it.
Appreciate 3
      03-27-2024, 06:14 PM   #10
Red Raider2
Oh yeah, that is the hardest connector I have ever had to deal with!
Appreciate 4
      03-27-2024, 08:40 PM   #11
Efthreeoh
General
BMWitis. It's like OCD, but with a BMW...
Appreciate 3
      03-27-2024, 08:49 PM   #12
mattanderson
192
Drives: 2007 E92 328i
. . . you drove a Hyundai to get here tonight, I drove an $8,000 BMW; that's my name.
      03-28-2024, 01:25 PM   #13
mainbearing
Drives: BMW 328i
I think either one will work. I use Valvoline, flushed every 2 years, and it is normal viscosity.
But if you are OCD then Pentosin DOT 4 LV, $14.80/L:
https://www.rockauto.com/en/moreinfo...42508&pt=11389
      03-28-2024, 07:51 PM   #14
Brian86
Brian86's Avatar
638
Drives: e36 M3, e91 325xi, N50 Xterra
Just go to the parts store and get the Valvoline DOT 3/4.
It's fine. Don't even need to pay for shipping or wait.
Sometimes a bolt is just a bolt.
      03-28-2024, 09:00 PM   #15
TheMidnightNarwhal
TheMidnightNarwhal's Avatar
2659
Drives: 11' 335is DCT
Yes your suspicion is correct, the fluid you see on FCP is the non LV one from BMW. I don't see where they mention LV. It seems they don't carry the LV BMW for some reason, can't find it anywhere. The part number is 83132184843, actually I think there's a lot of part numbers for it.
Had this dilemma of fluid to use a while ago to. Realised car specs for LV instead of normal DOT 4. I believe it has to do with better function with ABS/DSC system. I used to shop by brake fluid temp but since mine is also just a daily although I do drive and push it, I switched to LV because why not and it's not that expensive. I either buy it from dealer if I need it ASAP or actaully prefer to get Pentosin DOT 4 LV when I order parts online.
      03-30-2024, 08:14 AM   #16
Efthreeoh
General
On the agenda this spring is brake fluid changes for my 3 BMWs. At 27 years old the Z3 also was due for a brake hose refresh. I bought three (3) quarts of DOT 4 LV Pentosin off of Amazon. Two of the cans arrived all dented up. I guess it was stock from some store that couldn't sell the dented cans.
      03-30-2024, 10:24 AM   #17
StradaRedlands
StradaRedlands's Avatar
Drives: 2006 BMW 330i MT
2006 BMW 330i  [8.21]
2009 BMW 328i Touri ...  [7.90]
2013 BMW X5 35i  [7.63]
2011 BMW 528i  [8.75]
2006 Mazda3  [5.50]
Efthreeoh17316.50
      03-30-2024, 10:28 AM   #18
Efthreeoh
General
      03-30-2024, 12:46 PM   #19
gbalthrop
... I bought three (3) quarts of DOT 4 LV Pentosin off of Amazon. Two of the cans arrived all dented up. I guess it was stock from some store that couldn't sell the dented cans.
Fork-Lift drivers aren't required to be "LICENSED"/ Insured.
George
Efthreeoh17316.50
