What did you do to your car today?
03-28-2024, 09:08 AM | #24267 | |
Rep 3,008
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
Karlos20945152.00 |
03-28-2024, 10:16 AM | #24268 | |
eBay Special
3066
Rep 3,028
Drives: E90 330xi
Common sense is a flower that does not bloom in everyone's garden
03-28-2024, 07:23 PM | #24269 | |
127
Rep 104
StradaRedlands4946.00 |
03-28-2024, 07:30 PM | #24270 |
127
Rep 104
Today I put the newly gasketed VC back on. Not too bad. On the reinstall one of the two PCV caps inside the VC came off so had to pull the VC off again and JB'd the cap back on. Am waiting overnight for the JB to fully cure before starting the car and checking for leaks. My wife asks why I spend so much time cleaning the engine compartment. She doesn't understand, I'm removing fingerprints from the scene of the crime.
Seattlesquash897.50 |
03-28-2024, 07:31 PM | #24271 | |
Rep 3,008
On mine, it's only misting a little, so I'm just going to leave it for now. Still monitoring the football gasket, but it seems to be fine! |
jbellk75rt127.00 |
03-28-2024, 09:39 PM | #24272 |
Rep 1,539
so few $$ question, what would be my best best for this code?
did a swap, the code wasn't there, now it's there. What I did not plug back ? abs sensor? (transfer case is connected, both harness) will get into it tomorrow morning. |
03-28-2024, 10:04 PM | #24273 |
Rep 3,008
ABS sensor would be my first guess, but there are a few other choices for sure!
oVeRdOsE.2716.00 |
03-29-2024, 11:38 AM | #24274 | |
127
Rep 104
I did mine off the car. Trying my technique on the car could very well break the sensor neck. Not good. |
03-29-2024, 11:47 AM | #24275 |
127
Rep 104
Started my car this morning (let it sit overnight to let JB cure) and I got the triangle of death, 4WD, brake, service and steering lights on the dash. The good news, no leaks after my VC gasket replacement. After a bit of research I did the ole lock to lock with the steering wheel and all the lights went off except the steering light. What the heck? Then I realized that was the reset the clock light after disconnecting the battery. My favorite tool during the whole process? The extendable reach lighted magnetic parts retriever.
StradaRedlands4946.00 Seattlesquash897.50 |
03-29-2024, 07:41 PM | #24277 |
Rep 3,860
Drives: 330i, 135i
I washed and oiled my K n N filter in my e90.. Also clraned the Maf sensor. Forgot to take photos. 😌
StradaRedlands4946.00 Konrad528821.00 |
03-29-2024, 07:53 PM | #24278 |
Rep 3,008
oVeRdOsE.2716.00 Konrad528821.00 |
03-29-2024, 07:54 PM | #24279 | |
192
Rep 156
I think I found a pair of working OEM DISA valves!
Based on this old post I found (https://www.e90post.com/forums/showp...postcount=21): Quote:
03-29-2024, 08:59 PM | #24280 | |
Rep 1,539
OBD get me nothing, all good. ISTA I dont have any ABS code. Strange stuff, I flash some option via MHD for my tune, and the ABS light went off, but still have 4x4 error. On jack stand all 4 wheels are rolling... EDIT Just remind me , if alignment is off, I will have a code , I had this issue in the past because I hit a pot hole. Now, Ive just droped the car, 90% sure this is the issue. Ive planned a appointment already next week, we'll see ! Last edited by oVeRdOsE.; 03-29-2024 at 09:33 PM.. |
03-29-2024, 09:54 PM | #24281 |
Rep 3,860
Drives: 330i, 135i
03-29-2024, 10:51 PM | #24282 | |
Rep 3,008
oVeRdOsE.2716.00 |
03-30-2024, 08:09 AM | #24283 |
Rep 1,539
03-30-2024, 02:50 PM | #24284 |
131
Rep 194
Finally got around to a bunch of work I was putting off...replaced the oil pan gasket, did the water pump and thermostat with some coolant hoses/flush while I was there, along with engine and transmission mounts. And of course, a fresh oil change.
2020 BMW X3M Competition
2006 BMW 325i (E90) 2006 Pontiac GTO |
03-30-2024, 03:36 PM | #24285 | |
Rep 3,008
03-31-2024, 05:54 AM | #24286 |
Rep 1,539
03-31-2024, 03:29 PM | #24287 |
260
Rep 114
Proper wash and qd.
Saw a milion swirls after winter so one step polish is needed |
03-31-2024, 09:00 PM | #24288 |
192
Rep 156
Looks great!
I finished retrofitting the 3-stage intake manifold, along with a preventative starter replacement while I was in there. Coded to 330i tune using Bimmerlabs and car feels awesome! |
