What did you do to your car today?
10-08-2011, 11:04 PM | #23 |
Rep 659
Started it, shifted into reverse, moved 2 feet backwards and turned it off so I could drive the lawnmower out of the garage.
10-09-2011, 12:23 AM | #26 |
Rep 680
Drives: 2012 328i E92
Drove it, Waiting for my strut bar from Ecstuning to come in.
Seattlesquash897.50 Jritz33.50 |
10-09-2011, 12:26 AM | #27 |
Rep 8,693
Drives: 06 330i
changed oil, aligned exhaust, and drove it in the rain to wash it.
10-09-2011, 01:20 AM | #30 |
Rep 1,084
Drives: 2013 BMW F10 550 Xdrive Msport
Came home from a 10 day trip to Florida, got home from the airport, threw my bags in the house and then immediately went out to my car, vacuumed the whole car, while I ran it for a half hour or so with the windows open and then armor alled the whole car. Then, took it out for a drive to brush the rust off the brakes and fill it up with premium. AFTER that, I went home and unpacked... Missed my Beamer while on vacation!
10-09-2011, 01:22 AM | #31 | |
Rep 6,773
10-09-2011, 02:52 AM | #33 |
29
Rep 219
Drives: 14 BMW 335xi M-Sport EBII
Technically it was yesterday but I attempted the paddle shifter retrofits and broke the shit out of my steering column and now i get an orange "brake" light, my left hand blinker doesn't cancel, and the paddle shifers still don't work.
*grumble* |
10-09-2011, 02:56 AM | #34 | |
141
Rep 2,217
Washed and Waxed... also bought some replacement tail light bulbs from E92-Lighting...
yesterday i installed my LED interior set... what an annoying thing to get perfect (the dome lights). Once i found out the exact problem, i created a DIY 'fix-it' for people having issues in the future. This should take some hassle off of E92-lighting.com for sure ^__^ Quote:
10-09-2011, 09:54 AM | #36 | |
203
Rep 288
The job is fairly easy. Check out this vid if you want to see how to do it. Tips: In the photo below, position the window so that the green clip is lined up with the hole you just above the motor. To remove the top-most torx screw from the window regulator motor, you're going to have remove the middle and bottom window regulator nuts and only loosen the top one. I didn't go behind the window like it's done in the video to unclip the green bracket from the window; I went at it from the front. PM me if you require additional information. |
10-09-2011, 10:08 AM | #38 |
Came to the N55 Darkside
1112
Rep 12,740
10-09-2011, 10:19 AM | #39 |
Bavarian Fever
34
Rep 1,108
Complete outside detail. Car is looking like brand new!
| ESS n52 Tune | BMW Performance Intake/Exhaust | LUX H8 v3 AE | GP Thunder 8500K fogs/corners | LED: signals/interior | V1 hardwired | debadge | AC pedals | Performance shift knob/boot | CF e-brake | Aero lip | m3 side skirts/spoiler | MB kidneys | Strut brace | Painted reflectors | Painted Calipers/Hubs | 35% 3M tint | Smoked tails | CF Roundels | 19" Miro 942 | Conti DWS | H&R Springs for xi | Bilstein Shocks| Nxt: Alpine Subs/Amps
10-09-2011, 10:41 AM | #40 |
2111
Rep 13,877
Drives: E92 M3 & F80 M3 & G82 M4
So far, took it home from my girlfriend's house. Next, a nice clean up from the bugs I killed last night. Then, pictures!
10-09-2011, 06:57 PM | #41 |
1112
Rep 12,740
10-15-2011, 05:44 PM | #44 |
203
Rep 288
I went the cheap route and purchased replacement angel eye bulbs for $9 a pair instead of purchasing those $40 angel eye housings from the stealership.
The factory housing doesn't allow you to take the bulb out. So I drilled a hole right where the bulb housing guide would be. End result Some of you would say, why not purchase LED's? Well, next spring I plan on purchasing the OSSdesigns. No sense in purchasing the OSSdesigns now since winter is right around the corner. |
Seattlesquash897.50 StradaRedlands4947.50 |
