Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > "The Ultimate" HPB H8 10-Watt CREE AE's Review
      02-18-2012, 09:29 AM   #1
rollinstone157
Brotographer
rollinstone157's Avatar
Drives: F30 335xi
Hello Ladies and Gentlemen of E90Post!
The other day, I purchased two products from HighPerformanceBulbs.com
1. The New 10-Watt CREE AE's (in the H8 style)
2. Noyka Cosmic White Stage Two [80-Watt] H3 bulbs--which I will review in another thread.
Now, just to get this right off the bat, these will fit:
BMW 1 Series 2008 and up
BMW 3 Series Coupe (E92) 2008 and up (2007 uses the same bulb, but there's a small possibility throw errors, so if you don't mind taking the risk and potentially having to code, buy away!)
BMW 3 Series Sedan/wagon (E90) (with HID option) 2009 and up
BMW 5 Series (E60) 2008 and up
BMW X5 (E70) 2008 and up
BMW X6 2008 and up
NOTE WITH MY METHODOLOGY: For the comparison shots between the halogen and LED bulbs, the exposures were set equal for the two...if that makes sense. Feel free to check my metadata!
Shipping/Customer Service: 10/10
The items shipped quickly (less than 48 hours!) and well-protected. The AE's came in a shockingly well-constructed magnetically sealed box, and it was a very good presentation.
Initial Reactions: Very Positive
My initial thoughts were, "wow, for $80, these things are solid!" All metal body, and no plastic construction like so many other AE's in the price range of these.
Installation Difficulty (from 1-5): 3
Installation, for me, was not easy. Partially because I didn't know what I was doing,and partially because I have large-ish hands. I used the LuxAngelEyes install guide (IMO the best guide out there!). The trick is aligning these properly. If you look at his guide, notice he has a "T" diagram drawn on the bulbs, and he says "line up the T in the hole". To assist with that, I used a silver sharpie and draw a dotted line along the top of the AE's so I could check my alignment, and that certainly helped a lot.
Operating Notes:
1. These do fade on and off with the car--a feature I do think is nice to have! However, there is a flip-side to that.
2. These do not always run at full brightness, like some of the more expensive units out there. HOWEVER, I do not think the fact that these dim a little with the headlights detracts from the product at all. When the headlights come on, they do dim a little bit--but it's harder to notice because the headlight beams and the AE's are a closer match, and it looks very "natural", if you will.
3. This might freak some people out, but if you can code, you can code the cars not to dim the AE's when the headlights come on, but retain the fade-on/fade-off ability (I'm going to do this, just need to order a cable).
4. No errors, and interestingly, no flashing on startup. I was expecting that, and it was a nice suprise. Also, no radio interference, like some units costing 2-3x as much (Not Lux/MTEC...another brand)
Night-Time Performance: 9/10
These look great! The inner ring is a little brighter than the outer ring, but it is completely the fault of the BMW headlights, I do not blame HPB at all. Are the halogens brighter? Of course they are, those 35-Watt H8 bulbs put out a lot of lumens! But I'd say that these are...80% as bright. But I'll let you be the judge.
Direct Sunlight: 7.5-8/10
Washed out, but note that you can't see the halogens either. And part of that has to do with the color of these LEDs (Very white with a hint of a blueish-purpleish...actally a really nice color!), keep in mind!
IMG_4647.jpg by RobStone, on Flickr
IMG_4489.jpg by RobStone, on Flickr
Offset sunlight: 8/10
The inner ring is brighter than the outer ring, as you can see, but it is pretty visible during the day. This will make you mad at the BMW engineers for designing such a poor light delivery system for the AE's.
IMG_4653.jpg by RobStone, on Flickr
IMG_4652.jpg by RobStone, on Flickr
IMG_4651.jpg by RobStone, on Flickr
IMG_4650.jpg by RobStone, on Flickr
Random Shots...
IMG_4670.jpg by RobStone, on Flickr
IMG_4668.jpg by RobStone, on Flickr
IMG_4663.jpg by RobStone, on Flickr
IMG_4660.jpg by RobStone, on Flickr
IMG_4654.jpg by RobStone, on Flickr
IN CONCLUSION: Are these as good as the LUX H8 V3's, or the MTEC H8's? I don't know--but probably not. However, are they better than the $50 eBay special? You bet. Are they better than those cheap R-Dash products (and their counterparts marked up at 3x the price?) For sure! Might they even be better than the mid-range AE's, like the City Vision lights? They very well could be. Basically, for $80, these are absolutely incredible. A must buy for modders on a budget, IMO!
      02-18-2012, 09:30 AM   #2
rollinstone157
Brotographer
Drives: F30 335xi
This is part two of the review, and perhaps shows that I do not have "The Ultimate" ability to ultimately title my threads!
But without further ado, my review of the Noyka Cosmic White Stage 2 [80-Watt] H3 bulbs.
I used these bulbs in place of the factory 55-watt H3 bulbs. And I know somebody is going to read this and be like OMGBBQWHATWEREYOUTHINKING?!?!? The corner bulbs only stay on for 30 seconds at the longest, and most of the time, they are only on for a few seconds at a time. I didn't want to sacrifice light output, but I wanted to get a nice White color, so these seemed like a great product to try. After testing, I have determined that this do not pose a threat to my car's wiring, or headlights. They don't put that much additional strain on the car, the connectors are handling the heat fine, the wiring is handling the heat fine, and frankly, they don't generate that much more heat after only 30 seconds. Factory wiring is designed to handle stuff like this. Mind you, I wouldn't use these bulbs if they were going to be on for long periods of time (i.e.
Packaging/Initial Reactions: 10/10 and Very Positive
If you have ever ordered Noyka bulbs before, you'll know that they come in a very nice, hard plastic package. Easy to open, and well designed, kudos to the Noyka team! Now the bulbs...these are not like most other "color matched" bulbs. These are not just colored glass bulbs, but rather, they have a metallic tint to them. This reminds me a lot of the high-end PIAA bulbs, both in appearance and function.
Light Color: 10/10
I was shocked at how well thse match the Factory Xenons. Literally, the color match is perfect. And these illuminate an area slightly larger than the 55-watt bulbs, but with the benefit of the beautiful color.
Overall: 10/10
I will monitor these bulbs for the next month and check thoroughly for any signs of stress on the electrical system, but I honestly am 99.95% certain that I won't find anything worth noting.
Some shots...
IMG_4488.jpg by RobStone, on Flickr
IMG_4480.jpg by RobStone, on Flickr
IMG_4479.jpg by RobStone, on Flickr
IMG_4478.jpg by RobStone, on Flickr
Sorry, I need to redo the new cornering light shot--I screwed up installation on the bulb, so the light output was distorted, and I accidentally jostled the tripod on that shot.
UPDATE: Here's the headlights head-on. You can see how well everything matches!
IMG_4673.jpg by RobStone, on Flickr
      02-18-2012, 09:30 AM   #3
rollinstone157
Brotographer
Drives: F30 335xi
Reserved 2
      02-18-2012, 11:09 AM   #4
dwells
ಠ_ಠ
dwells's Avatar
Drives: Monaco Blue 335i coupe
Thanks for testing these out for us. Someone with LUX ought to go meet up with you for a comparison photo shoot.
| 335i coupe | Monaco Blue | JB4 G5 ISO | Style 313M | Huper 40% tint | Aero lip | CSL trunk spoiler | M3 sideskirts
| Paint-matched grilles | Painted reflectors | GP Thunder II angel eyes | Smoked LED sidemarkers | Self-coded |
      02-18-2012, 11:49 AM   #5
messi
15
Drives: 2009 E92 335i MSport Coupe 6AT
pics dude
      02-18-2012, 04:59 PM   #6
rollinstone157
Brotographer
Drives: F30 335xi
Originally Posted by messi View Post
pics dude
Sorry dude, life cought up with me today...I'll try and get them up tomorrow though.
      02-18-2012, 05:28 PM   #7
ChasVS
ChasVS's Avatar
Drives: 2012 MB ML350 Bluetec
I've installed one of these on my 07 335 E92 and have no code errors. I can't tell the difference in the daytime between the 10 watt HPB bulb and the LED 6 Watt Angel Eye Bulbs by City Vision Lighting. Love the look of the City Vision 6 Watt LEDs which ran around $120.
My speeding isn't the problem. It's the Slow Folks ahead of me that cause accidents!
      02-19-2012, 11:52 AM   #8
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Drives: C6 Z06, 09 335i, 10 335xi
Cool, I still didn't put mine in. Too much procrastination.
      02-20-2012, 06:03 PM   #9
rollinstone157
Brotographer
Drives: F30 335xi
And the photos are up!!
      02-20-2012, 06:08 PM   #10
rollinstone157
Brotographer
Drives: F30 335xi
I would be completely down for that, I just need someone to contact me! If anyone sees this and lives either in/around the 07901 [Summit, NJ] area with the LUX's installed (preferably in the E90 LCI), please get in touch!!
      02-20-2012, 11:45 PM   #11
samchoi604
60
Drives: black on black
Thanks for posting up the photos man.. they do look good. Don't worry, at certain angles, you wouldn't be able to see the outer ring of my LUX v3 either way.
      02-20-2012, 11:49 PM   #12
GmoBmw
GmoBmw's Avatar
34
Drives: 2007 335i
They Look really good.
2007 BMW 335I- JB4 G5,DCI,VRSF DPs,NT555r Drag Radials Daily Driver
      02-21-2012, 12:51 AM   #13
mapleridge
Drives: E90 N52 AT
looks good for $80. How do these differ with the ones that wouldn't fully fit in the housing?
      02-21-2012, 01:43 PM   #14
These are for H8 Angel Eyes. The others were for H7 I believe.
      02-21-2012, 02:33 PM   #15
rollinstone157
Brotographer
Drives: F30 335xi
Thanks! I think so too. If you go in to this purchase saying "I know I won't really be able to see this in direct afternoon sunlight" then you'll love them!
Yeah, so I hear. I'm just curious if the design of the LUX H8 V3's give slightly more even lighting. I haven't seen them in person yet (seriously, someone who lives near me with them, get in touch with me!)
The ones that had fitment issues were for the E90/91 Pre-LCI's with xenon headlights, and those were special BMW bulbs, I believe a 10 watt halogen bulb in a funky base with a custom reflector...strange design. But hey, whatever works!
      02-22-2012, 08:30 PM   #16
Eric335
Eric335's Avatar
Drives: 2007 E92 SG 335i 6MT
2007 BMW 335i  [7.66]
nice review! thanks for the help with my AE decision a while back as well
OP is kind and very helpful! good 2 see a comparison!
      02-22-2012, 09:51 PM   #17
rollinstone157
Brotographer
Drives: F30 335xi
Thanks for the kind words Eric! It was a pleasure working with you, you're enjoying your Alpine AEs I hope?
      02-24-2012, 06:55 AM   #18
Eric335
Eric335's Avatar
yup! im thinking about switching out to the 6000k to see what it looks like, or if its brighter
      02-24-2012, 12:56 PM   #19
4300K-5000K will be the brightest output of white. Put 6000K or higher might be easier seen in the daytime as they contrast better in direct sunlight whereas the white colors get washed out.
      02-24-2012, 02:21 PM   #20
Eric335
Eric335's Avatar
interesting.... thanks
      02-24-2012, 07:31 PM   #21
No problem. That is why alot of these aftermarket LED systems dont do to well in the daytime. As you can see on the late model BMW the stock angel eyes are an LED with a sort of purple hue, makes seeing them in daytime a little easier. However, there is an inherent flaw in the AE design too. I was actually thinking of wrapping some reflective type on the fiber optics so it doesnt lose light transferring to the outer rings; it should work in theory but how much I just dont know.
      02-25-2012, 11:22 AM   #22
Eric335
Eric335's Avatar
+1 Very interested! I posted in a previous thread of mine about an idea of some reflective mirrors inside the housing to redirect light to the fiber optics. Your idea seems even better. Id be very interested in the results!!!
angel eyes, cree, highperformancebulbs.com, review
