TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > X6 Engine / Exhaust / Drivetrain Modification
      06-28-2018, 11:58 PM   #23
RichardH
RichardH's Avatar
South Africa
27
Drives: X5M
So turbos and manifolds are in.
Mostly direct fit
Oil feeds perfect fit
Oil return perfect fit
Coolant feed abit of modifications
Also turbo intake fits but the mounting blt needs to modified.
Spool up is incredible!!
Dump valve needs to dump into the atmosphere M5 turbos dont have opening for them
JB4 not working correctly
Now to custom tune
Throttle feels alot lighter
Exhaust note alot deeper
      06-29-2018, 12:17 AM   #24
Dieselunlimited
Drives: X6M
Mostly direct fit
Now to custom tune
Pics?
Current mods before install?
And yeah we need a video!
      06-29-2018, 06:56 AM   #25
RichardH
RichardH's Avatar
South Africa
27
Drives: X5M
Originally Posted by Dieselunlimited View Post
Pics?
JB4
Gutted DPs
KNN Filters
Backend Flash
Video will follow later
9vapors651.50
      06-29-2018, 10:33 AM   #26
frankenm
frankenm's Avatar
96
Drives: 12' X5M, 99 M3
- Need Pics!
What kind of JB4 issues are you having?
2012 X5M - M5 S63TU Turbos/Manifolds, Custom Exhaust, Intake, JB4/BCM, OEM race stripes
1999 323
- M3 Clone - Hardtop - S50 Cams, S52, 3.23 LSD, Koni Sport, 18' E46 M3 Wheels
      06-30-2018, 02:13 AM   #27
RichardH
RichardH's Avatar
South Africa
27
Drives: X5M
Originally Posted by frankenm View Post
- Need Pics!
JB4 keeps saying user adjustments and settings corrupt.
Also getting Lambda error code 2C24
Lambda sensors swopped
Will remove JB4 completely
      09-12-2018, 11:23 AM   #28
Robbie1977
Robbie1977's Avatar
Drives: BMW x6 5.0
2010 X6  [10.00]
I've also just completed this upgrade also,
My wagon is the 5.0 Xdrive and currently I have the following completed.
F10 M5 Headers
F10 M5 Turbos
Straight Race downpipes installed.
ESS tuned
Custom charge pipes made to keep the original diverter valve which currently vent to atmosphere. These will be changed soon to electronic Turbosmart blow off valves.
My friend and I are currently waiting to fabricate a custom intake filter pipes to drop in somewhere behind the hood grills.
A note on the above post, I have the F10 M5 intercoolers and they defo don't fit. They are simply to big and also they have two areas of recirculating the coolant through each intercooler. I suppose either a bypass system or a loop system could be fabricated to make them work but I don't know where they would fit in such a tight space.
      09-30-2018, 08:38 PM   #29
RichardH
RichardH's Avatar
South Africa
27
Drives: X5M
F10 M5 Headers
F10 M5 Turbos
ESS tuned
How's the power increase?
      10-02-2018, 06:37 PM   #30
StatenEye
Drives: X5M F85
2016 BMW X5M  [0.00]
2011 BMW X5M  [9.00]
Mostly direct fit
Now to custom tune
Lmao this is great!
      10-11-2018, 04:08 PM   #31
Robbie1977
Robbie1977's Avatar
Drives: BMW x6 5.0
2010 X6  [10.00]
Definitely a lot better and the turbo response is better than the stock X6 turbos, I have noticed better torque now thats its been ESS tuned. I have Race Downpipes straight though the X pipe to a Akrapovic rear quad exhaust, the turbo whistle is definitely louder.
The next upgrade will be intercoolers, once I find a space in which to install / fit them I should notice an improvement as the F10 M5 intercoolers have a better flow rate. I am thinking that I will try to fit them somehow in front of the oil coolers behind the front bumper. It will require a little finesse to squeeze them in.... but I won't know until I remove my front bumper and look at doing some relocating ??
Once the intercoolers have been fitted I will arrange a dyno to see how the power increase has changed and of course will post some pictures and the dyno chart.
For anyone who is thinking of doing the swap I can only advise that it can be expensive, I was lucky enough to buy a complete F10 M5 that had a damaged engine and the owner did not want to pay to have it repaired so I managed to take the whole car for around 5000 dollars. and I am still selling parts from that car to recuperate some expenses back.
Worth while?? The M5 turbos have a better reputation and life span in my opinion compared to the X6 turbos which was one of the main reasons for me wanting to make the swap, and everything is pretty much bolt off bolt on apart from my custom charge pipes to accommodate my electronic Turbosmart BOV's. I guess the only downfall now is the slight smell of petrol due to the race downpipes overall..
Hope this helps any forum members and feel free to PM guys if you need any help with your install.
      11-08-2018, 10:09 PM   #32
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
I'd like to see your charge pipes setup. I've tried venting to atmosphere before and would get a CEL the moment they had to actuate. In the meantime I bought a set of DV+'s but I've yet to install them.
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's
'97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's
      11-16-2018, 11:02 AM   #33
Robbie1977
Robbie1977's Avatar
Drives: BMW x6 5.0
2010 X6  [10.00]
m5james
a couple of pics taken when installed. sorry for the poor quality but you get the point. No CEL's or any problems
      11-21-2018, 03:40 PM   #34
greddy91
83
Drives: 2010 X5M
Whoa.... who did that work? Did they build a jig for it? Do those Diverters vent to atmosphere now?
      12-11-2018, 03:44 AM   #35
MadDoc-V8
MadDoc-V8's Avatar
Drives: X5M E70
Hello m5james,
Greetings from Germany ;-)
I would also like to install a M5 F10 exhaust manifold in my X5M E70 and have questions about this ;-)
Do the exhaust manifolds of the M5 F10 fit 1: 1 plug and play?
Or does something have to be changed?
greeting
Alexander
      12-11-2018, 04:35 AM   #36
0-60Motorsports
0-60Motorsports's Avatar
Bahrain
792
Drives: BMW M3 JB 04 Coupe
Would love to know if we can install F10 M5 intercoolers on the X5M. That would be a good help for the car in our 50c Plus temps
Current Mods:
2004 E46 M3cs JB/CSL
2010 E70 X5M AW/BLACK
2011 VW Golf R DSG White/Black
IG: @060Motorsports
      12-20-2018, 03:36 PM   #37
greddy91
83
Drives: 2010 X5M
Originally Posted by MadDoc-V8 View Post
Hello m5james,
greeting
Alexander
I think it was concluded that the F10 M5 turbos and mannys mated up with no issues, but tuning is definitely required.
Some thread here advised they swapped left and right o2 connections and saw functionality with no tuning, but there is no way in hell I would count on that.
This has been talked about a bunch here. Insert dick comment about using search, but really I'm just too lazy to also do that and link you.
      01-08-2019, 10:52 AM   #38
Robbie1977
Robbie1977's Avatar
Drives: BMW x6 5.0
2010 X6  [10.00]
Me and my friend did the work, and yes at the minute the diverters vent to atmosphere but I am currently installing some turbo smart vent to atmosphere electric blow off valves.
      01-08-2019, 10:53 AM   #39
Robbie1977
Robbie1977's Avatar
Drives: BMW x6 5.0
2010 X6  [10.00]
Hello m5james,
greeting
Alexander
Straight swap PnP
      01-08-2019, 10:55 AM   #40
Robbie1977
Robbie1977's Avatar
Drives: BMW x6 5.0
2010 X6  [10.00]
Not in the factory location, I am currently fabricating some longer charge pipes so that my F10 M5 intercoolers can be located nearer to the side vents behind the from bumper.
      01-08-2019, 11:03 AM   #41
Robbie1977
Robbie1977's Avatar
Drives: BMW x6 5.0
2010 X6  [10.00]
Agreed, I went for an ESS tune. After spending a little time explaining my set up to the guys over at ESS they took care of my needs. I took the car out for a test drive after I completed manifold and M5 turbo swap. The car pulled hard a lot harder than standard and for longer. The torque is fantastic..... I think I should see a little more once I've completed the M5 intercooler and twin direct cone air filters swap as airflow should be freely moving rather than stacking in our smaller standard intercoolers.
      01-08-2019, 11:07 AM   #42
0-60Motorsports
Bahrain
792
Awesome please post pics
Current Mods:
IG: @060Motorsports
      01-08-2019, 03:59 PM   #43
frankenm
frankenm's Avatar
96
When I reached out to ESS regarding this they rejected me, even mentioned this build and got nowehere.
1999 323
      01-16-2019, 02:31 PM   #44
Robbie1977
Robbie1977's Avatar
Drives: BMW x6 5.0
2010 X6  [10.00]
Interesting?? I reached out to AJ at ESS.... Didn't have any problems
xbimmers
