11-25-2019, 11:35 AM | #1 |
40
Rep 65
Turbo Coolant hose replacement
I had a really slow leak from 2 out of 4 of my turbo coolant hoses, also my factory heat wraps were destroyed inside from the slow leak, and tore at the buttons.
I upgraded to high temp silicone. Instead of the oetiker clamps I used fuel injection hose clamps which worked perfectly. I refused to get the OEM heat wrap, so instead I used some DEI wrap. Hose: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Clamps: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Heat Wrap: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Last edited by wallyman424; 11-25-2019 at 03:02 PM.. |
Ickdeep5720.50 Jasoneo539.00 rockyfeller117.50 M5_Brandoe237.50 SSJAR26.50 M5Rick60060.50 1320racer135.00 Mdriv3r148.50 |
11-28-2019, 05:43 AM | #2 |
Rep 606
Drives: 2000 M5, 2001 M5, 2013 M5 6MT
Nice work!
Try to remember to check back if you get a leak or especially if you don't after a year or so. |
11-28-2019, 08:46 AM | #3 |
Rep 1,107
Very nice thanks for posting. I think it's a much better repair than what bmw was doing. Also good call on the fuel injection line clamps, they are the right ones to use. I don't know why people use the worm style clamps on these hoses, they literally cut into the hose as you tighten them. This should be a nice long term fix. Happy holidays!
'13 Black Sapphire Metallic - BPM Stage 1 Tune - RPI Exhaust - KW HAS Kit - 12mm spacers all around- Carbon Fiber front lip - High Kick Trunk Spoiler - Rear Roof Spoiler - IND Kidney and Fender Grills - 20% Tint all around 50% Front Windshield - PPF
11-30-2019, 01:25 PM | #5 |
BMW M5
9
Rep 28
Is there oil or coolant coming thru these lines? because that type of hose in their description says
“Silicone hose is NOT compatible with fuel or oil; however, it is compatible with water and anti-freeze such as coolant.” |
11-30-2019, 04:52 PM | #7 |
BMW M5
9
Rep 28
thank you ! will get these ordered as well... i’m sure no one needs 5 ft or hosing, this same company selling the same one but shorter to save money here is the link
HPS 3/8" ID Black high Temp Reinforced Silicone Heater Hose, Max Working Pressure 80 psi, Max Temperature Rating: 350F, Bend Radius: 1-1/2" https://www.amazon.com/dp/B01DIPN1AO..._xkV4DbZ5HVP4F 👍🏼 |
12-05-2019, 05:23 AM | #8 |
Rep 648
I upgraded to high temp silicone. Instead of the oetiker clamps I used fuel injection hose clamps which worked perfectly. I refused to get the OEM heat wrap, so instead I used some DEI wrap. Hose: https://www.amazon.com/gp/product/B0...UTF8&psc=1 Clamps: https://www.amazon.com/gp/product/B0...UTF8&psc=1 Heat Wrap: https://www.amazon.com/gp/product/B0...UTF8&psc=1 Appears the above Amazon link for the clamp is incorrect. Should be a 15-17mm clamp rather than a 14-16mm. I ordered everything as described. However, we're having a hard time (actually impossible) to slide the clamp over the hose while connected to the turbo line. Will have to use regular clamps until I get the correct ones. |
12-05-2019, 07:02 AM | #9 | |
40
Rep 65
12-05-2019, 07:56 AM | #11 |
Rep 648
I don't know. That's crazy. I tried that as well. In fact I loosened them just about all the way off the threads and it still didn't work. I gave it a rest and will try again later.
12-05-2019, 08:24 AM | #12 |
40
Rep 65
Try this, put the clamps closer to the middle of the hose slide the hose over the tube end first and then slide the clamp over the hump. That's how I did it. It probably won't go if you have the clamp at the end of the hose and try to slide it over that way.
03-02-2020, 03:49 PM | #19 |
Rep 4,209
Drives: '13 F10 M5 | '15 F15 X5
No draining required but make sure the engine is cold before doing it.
03-03-2020, 11:32 AM | #21 |
Rep 606
The system is self bleeding although you will want to fill and keep an eye on the level after the first start and keep filling the reservoir so you don't run it dry for too long. The electric water pumps have a preservation mode and will just turn off if they speed up in RPM too much (ie, sucking air not liquid) so it's hard to damage anything.
1320racer135.00 |
03-04-2020, 11:38 AM | #22 |
378
Rep 319
I love posts like this. Especially when OEM design fails. Fix it better.
Ill be doing this "when" I get a leak. Maybe just proactively do it. Cheap enough. |
