M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Engine, Exhaust, Drivetrain Modifications
      01-15-2024, 11:31 PM   #23
Minacious
The Dovahkiin
Minacious's Avatar
312
Drives: LCI M6 GC, other stuff.
Absolutely beautiful!
Well damn, I thought I was done spending money on the M6. I am a bit conflicted on whether I should grab a set or not. My intakes and charge pipes are titanium and I fear these might clash being right up against the intakes, though, my engine cover is in carbon fiber so they could tie in there.
Decisions, decisions.
Hell, I'm just happy to see a replacement for those bland stock inlets. Any improvement to flow/sound, no matter how minuscule, is a plus.
Ed
CG Artist, Set Painter and Sci-Fi Nerd.
“The problem with the world is that the intelligent people are full of doubts, while the stupid ones are full of confidence.” - Charles Bukowski
      01-18-2024, 01:27 PM   #24
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
Do it
https://x-ph.com/sale/
Phone number 702-494-9435
      01-31-2024, 10:51 AM   #25
TinCanSailor
Fueled by Recycled Dinosaurs!
TinCanSailor's Avatar
630
Drives: F06 M6
Mine arrived today.sadly my left pcv broke when I separated it from the old inlet. I have 2 new pcv valves coming from FCP next day so I should be up and running again tomorrow.
2015 F06 M6 Silverstone Metallic II, Individual Full Leather, B&O, Night Vis, CCB, RKAutowerks (CP Rods/Pistons, DI Cams, CF Intakes, Coated DP's & Billet Diff Brace), InfinityAuto Turbo Inlets, Mishi Oil Cooler, JB4, XHP S3, BM S3
      01-31-2024, 01:34 PM   #26
TinCanSailor
630
Drives: F06 M6
Got the turbo inlet pipes installed. Waiting for the pcv valves to arrive tomorrow.
      01-31-2024, 01:38 PM   #27
TinCanSailor
630
Drives: F06 M6
Do any of you have suggestions for some nice pre cut tubing that will complement the CF air intake and turbo inlet pieces?
      01-31-2024, 05:31 PM   #28
m5rosco
211
Drives: 2016 F10 M5
I got mine fitted at the weekend and I've done a little review......
https://f10.m5post.com/forums/showthread.php?t=2079148
      01-31-2024, 06:20 PM   #29
mike@x-ph.com
Congrats
      01-31-2024, 07:09 PM   #30
TinCanSailor
630
Drives: F06 M6
Originally Posted by mike@x-ph.com View Post
Congrats
Do yall carry this item?
I have had great customer support from X-PH.com as well so if IND or ATK does not have what you need hit up Mike!
      02-01-2024, 11:22 AM   #31
mike@x-ph.com
We do
      02-01-2024, 04:57 PM   #32
TinCanSailor
630
Drives: F06 M6
Spent the afternoon in and out of the garage removing my pcv. Alves and waiting for ups. They finally came through around 3 pm so I didn’t have to wait too long for the fcp order.
While I had things off I decided to polish the engine cover bridge/mount, turbo heat shield, turbo coolant lines and the DME faces. Gave the naked engine a lil pop to help dress things up with the turbo inlets.
The pcv valves went in with ease and honestly I should have planned for this. I took the car out for a short ride to make sure nothing shifted out of the hose clamps. I didn’t push the car so can’t say anything about performance but the turbos had a bit more presence audibly.
I would really like to find some nice hose/tubing to connect the inlets to the air in takes so please shoot me some recommendations.
      02-01-2024, 05:01 PM   #33
m5rosco
211
Drives: 2016 F10 M5
Looking good!! Getting the rest of the Infinity kit would solve your unsightly hose issue!!!
      02-01-2024, 10:22 PM   #34
TinCanSailor
630
Drives: F06 M6
Agreed but I have plans for that space that the air boxes used to occupy.
      02-03-2024, 02:47 AM   #35
Mr. M6
Mr. M6's Avatar
149
Drives: M6
2014 BMW M6 F06  [9.25]
i think one of your pcv valve not fitted correctly, you should hear click sound, be sure not to leak.
look at right and left side.
      02-03-2024, 05:47 AM   #36
Blaxwil
Blaxwil's Avatar
627
Drives: 2015 M5
Eagle Eyes. I did the exact same thing when I replaced my PCV’s. Will cause a CEL over time but easy fix.
      02-03-2024, 09:56 AM   #37
TinCanSailor
630
Drives: F06 M6
Appreciate that yall. I do recall that side giving me a fight. I was in low light and only eye glass I had were my sunglasses.
I go back out to check it out soon.
Thank you both!
      02-03-2024, 12:00 PM   #38
m5rosco
211
Drives: 2016 F10 M5
Ooooohhhh!!! What are you planning?
      02-03-2024, 12:43 PM   #39
TinCanSailor
630
Drives: F06 M6
Meth tank on one side where the old air boxes sat and interchiller coolant tank on the other side.
m5rosco210.50
      02-03-2024, 01:34 PM   #40
m5rosco
211
Drives: 2016 F10 M5
Cool!! (Literally!!!)
Keep us posted!! I look forward to seeing more of this!
      02-04-2024, 01:43 AM   #41
Mr. M6
Mr. M6's Avatar
149
Drives: M6
Thank you both!
for me it was same on that side, not fitting correctly, so i shaved little from the inlet then PCV fitted correctly, you can try.
i informed infinity design about that and they are working to correct the stock
      02-04-2024, 10:12 AM   #42
TinCanSailor
630
Drives: F06 M6
To make sure I am tracking this right, you shaved the end of the pcv tube that mates up to the IAD piece?
      02-04-2024, 12:36 PM   #43
TinCanSailor
630
Drives: F06 M6
I went after the end of the pcv valve with a small file. I didn’t take much off but I was able to get it to lock down. I could probably shave a little more off to make it easier to lock down.
I appreciate the eagle eyes and the tips!
      02-04-2024, 06:10 PM   #44
TinCanSailor
630
Drives: F06 M6
Took the car out for a lil bit of a joy ride. Sounds great but got DTMF on a rolling start to WOT.
m5post
