Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Style 230 on 2010 323i?
      02-05-2024, 12:30 PM   #1
matt.zahorec@gmail.com
Drives: BMW E90
Hey there, I know it's been done before but I want to put style 230s on my 2010 323i.
The two options for tire setups I have are: Fronts 225 40 19 Rears 265 30 19.
and Front 225/35/19 Rear 255/30/19
Which would be better to run these on an e90?
Thank you for your help.
      02-05-2024, 01:43 PM   #2
tcphoto
tcphoto's Avatar
Drives: E92 335i 6MT Coupe
The 235/40/19 and 265/35/19 will give you a bit more aggressive look and not so firm ride, hit a couple potholes on a 30 profile tire and see how pleasant it is.
      02-06-2024, 05:59 AM   #3
wrevilo
24
Drives: 2010 E92 335i N55 6MT
Surely a 40 profile at the front is going to be too big?
I run 235/35 at the front and 255/35 at the rear. However, in future I will run 265/30 at the rear.
      02-06-2024, 01:14 PM   #4
vester86
92
Drives: BMW 330D '08
the second option is stock e90 sizes and therefore perfect fitment.
the first option has quite a big difference between front & rear. front is way too big.
what you could do is 235/35/19 which is 1 size wider then stock.
the suggestion tcphoto gives is too big (both wide AND height) so your speedo will be off quite significant and possible rubbing
