Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Spacers advice/recommendation
      02-28-2024, 11:27 PM   #1
nikokami
FBE (Fellow Bimmer Enjoyer)
Drives: 2011 BMW 328I Msport
2011 BMW 328i  [0.00]
Need help finding spacers that would work best with my car. I am not planning on lowering it as it came with the msport suspension and it sits at a good height for me. What size spacers do you guys think I should get? links would be appreciated. Photo attached
      02-29-2024, 06:59 AM   #2
Lone_Wolf
Drives: E91 325d@250ps/500nm MT
15mm works for me in my e91 m sport, not linking any shops Im on different side of the world ;-)
      02-29-2024, 03:58 PM   #3
mattanderson
192
Drives: 2007 E92 328i
I run 12mm on my stock 18's at all 4 corners for a nice OEM+ look.
15mm would fit but look less OEM, IMHO.
If you're running stock front camber, I'd say 15mm is a bit too aggressive up front.
      02-29-2024, 06:01 PM   #4
vester86
92
Drives: BMW 330D '08
it ALL depends on the specs of your current rims....
if they are original for an e90 LCI then 10mm front & 15mm rear is a pretty safe bet.
      03-04-2024, 08:45 PM   #5
whyzee125
Drives: Dinan stage 2 335i
I ran 15f/18r on my previous e90. Mine had style 162s so not the same wheels but they looked about equally sunken before the spacers and here's how it looked after.
      03-05-2024, 12:24 AM   #6
petrvales22
Drives: BMW E90 320i N46B20B
I tried 15s an they are good but I’m lowered so in the rear there are some little sratches to wheel arch. OEM wheels rear 255 front 225
      03-13-2024, 01:30 AM   #7
iroblesui
iroblesui's Avatar
Drives: 2010 328i
2010 BMW 328i  [9.50]
I run a 12mm front spacer and no rear spacer, I’m on ST XA coilovers with dinan front camber plates, no rubbing issues at all. 18x9 front wheels 18x9.5 rears with a 235x40 front tire and a 265x35 rear tire
whyzee1251678.50
72GMC81.00
e90, spacers
