Studio RSR
BMW 3-Series (E90 E92) Forum > E90/E92/E93 Marketplace (For Sale / Trade / Wanted) > SPONSORS Classifieds/Groupbuys/Specials Area > Wheels and Tires > New: APEX EC-7 Wheel Released
      01-23-2019, 10:26 AM   #331
Yassssm4
13
Drives: bmw
Looking to get a set of 18x9 31
And saw that it was a profile 2 setup. Was wondering if 3 shows more concave than the 2 profile.Do you have picture of profile 2 and 3 next to each other showing the concave difference
      01-23-2019, 11:53 AM   #332
Expert@ApexWheels
Expert@ApexWheels's Avatar
3530
Drives: M3
Thanks for the post! The Profile 3 is the deepest concavity offered for the EC-7. All profiles have some level of curvature around the center pad/lug hole area.
Here is a comparison between the three profiles:
Here are some photos showing Profile 2 (18x9" ET30) on the front and Profile 3 (18x9.5" ET22) on the rear:
      02-05-2019, 02:13 PM   #333
Expert@ApexWheels
3530
Drives: M3
Strong, light, affordable.
Choose three.
      02-16-2019, 10:00 AM   #334
Isaiah5411
Isaiah5411's Avatar
Drives: 2008 Montego Blue 328i E93
Do you have some pics of the anthracite on a blue car...Montego, Lemans or Estoril?
I really want something other than silver on my Montego Blue now, but... some of the gunmetal/anthracite wheels I've been looking at are a shade or two too dark for my taste. I think I need Titanium.
2008 Montego "330i" /3.0 manifold /AA /Eurobox /PE /Alufelgen CS7 /Macht Schnell /Michelin PSS /XPel
"O thou afflicted, tossed with tempest, and not comforted, behold, I will lay thy stones with fair colours, and lay thy foundations with sapphires." (Isaiah 54:11)
      02-18-2019, 01:05 PM   #335
Expert@ApexWheels
3530
Drives: M3
We don't have a whole lot of photos of this combination, but here are a few that may help:
      02-19-2019, 04:28 PM   #336
Isaiah5411
Isaiah5411's Avatar
Thanks! Those look lighter in color than in most pics I've seen. I'm sure it's all about the lighting. I do like the EC-7s.
      03-14-2019, 10:34 AM   #337
matthewjmoser
56
Drives: 2011 328xi
took advantage of the group buy picked up some EC-7's in 18x9 +31 18x9.5 +43 for my e90 lci xi on h & r coilovers. will be running some 235/40 front 265/35 rear size tires. will post pictures once they arrive and i get them mounted.
      11-18-2019, 12:48 PM   #338
f10m-tech
f10m-tech's Avatar
Drives: 335is
Hello,
I'm debating with myself on 2 choices for my e92 2013 335is:
EC-7 // Front: 18x9" ET31 with 235/40-18 // Rear: 18x9.5" ET22 with 245/40-18
or
Apex ARC-8 Front 19x8.5 ET35 with 235/35-19 // Rear: 19x9.5 ET33 with 265/30/19
The car is completely stock with no suspension modes and looking for primarily street use...
Between the 2 options what you will be the best choice and what issues i might be facing in reference to:
1 rubbing
2 techo accuracy
      11-18-2019, 01:38 PM   #339
Expert@ApexWheels
3530
Drives: M3
Originally Posted by f10m-tech View Post
Hello,
or
The car is completely stock with no suspension modes and looking for primarily street use with light track usage nothing to aggressive.
1 rubbing
2 techo accuracy
Thanks for the message!
I think the tire size you mentioned is a bit narrow for the 18x9.5" ET22. 255/35-18 tires would probably be the better choice. Because of the aggressive offset of this setup, you will likely need to roll your rear fenders to make this setup work without rubbing. 245s may let you fit the rear wheels without rubbing but the tire would be over-stretched at that point.
A more direct 18" fitment would look like this:
Front: 18x8.5" ET35 or ET38 with 235/40-18 tires
Rear: 18x9.5" ET43 with 265/35-18 tires
245/40-18 front tires can be used.
275/35-18 rear tires may require rolled fenders and/or negative camber depending on ride height.
Your other option, the 19-inch setup looks like it should fit just fine. We typically recommend 18" wheels where possible for performance but in terms of fitment and speed sensor data you should be fine!
If you'd like more info, please check out our fitment guide.
Please let us know if you have any other questions!
Thanks
-Tom
      11-18-2019, 02:44 PM   #340
f10m-tech
f10m-tech's Avatar
Drives: 335is
PM you back
      11-18-2019, 03:07 PM   #341
Expert@ApexWheels
3530
Drives: M3
PM you back
Replied
-Tom
      12-03-2019, 02:07 PM   #342
f10m-tech
f10m-tech's Avatar
Drives: 335is
Just got the wheel installed with:
Front: 18x8.5" ET35 245/40-18 tires
And everything is great but there is still a bit of gap in the rear fender that I would like to try to close.
Can you suggest spacer size based on customers with a similar setup?
maybe: 12mm or less than that?
Also the 5mm spacers are safe to install considering the leftover from the hub is not much the rim to lay down?
      12-04-2019, 04:13 PM   #343
Expert@ApexWheels
3530
Drives: M3
Pm incoming!
      12-11-2019, 12:58 PM   #344
Expert@ApexWheels
3530
Drives: M3
Have enough torque to move a small town? No problem! Our EC-7 wheels look stellar AND help you put the power down.
335D equipped with our E90 LCI fitment EC-7 wheels.
      06-25-2023, 08:22 AM   #345
fleetfoot
fleetfoot's Avatar
Drives: 2017 M2, 2013 E92 328i
E92 with Eibach springs and 18x9 square
The Apex fitment guide said that 18x9" square setup would work, but I was slightly nervous since I also have Eibach springs. But it all worked out perfectly with a 1 finger gap all around and no rubbing. I do have M3 control arms, so I'm running -1.5 degrees of camber up front. I'm happy, although there's a part of me that wishes I had waited (the 6+ month backorder) for the anthracite color instead.
2017 F87 M2: MGM, 6MT, AA Tune, Eibach Pro-Kit, Fabspeed Catted Downpipe, Evolution Racewerks FMIC+Chargepipe, Autosolutions SSK, CDV Delete, Vorshlag Plates, PFC-08 pads, Apex EC-7 18x9.5"
2013 E92 328i M-Sport: BSM, 6MT, 3IM+AA Tune, BMW PE, M3 control arms, Eibach Pro-Kit, Bilstein B8, BMW SSK, CDV Delete, Apex EC-7 18x9"
      06-26-2023, 12:39 PM   #346
Expert@ApexWheels
3530
Drives: M3
The wheels look great! Glad to see you picked up a set. Sorry to hear about the backorder, but I think the race silver provides a nice contrast in your case. Enjoy the wheels!
-Tom
      07-18-2023, 06:26 PM   #347
andrew_b
9
Drives: 2007 E93 N54
-Tom
Is this thread still alive? If so what’s the ETA on Flowformed ARC-8s in 17x9 ET30, Tom??
And if there are any secret stashes of EC-7 in that size let me know
2007 E93 N54
      07-19-2023, 12:51 PM   #348
Expert@ApexWheels
3530
Drives: M3
https://www.apexraceparts.com/store/...c-8-wheel.html
Some are in stock, some aren't. I'd expect the hyper colors to be back in stock in September, the NOV eta is super conservative. Anthracite and Bronze are in stock.
We never produced the flow formed EC-7 in 17" diameter fitments so no chance of those in this size.
-Tom
      07-23-2023, 06:57 PM   #349
andrew_b
9
-Tom
Thanks Tom! Talking to some of the team there now about the choices!
2007 E93 N54
18x10, 18x9, 18x9.5, apex, ec-7
