Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > 225/40 All Around..any Issues?
      09-28-2007, 01:39 PM   #1
SMOKE EM IF U GOT EM!!
SMOKE EM IF U GOT EM!!'s Avatar
Drives: 06' E90 330, 20' F97 X3m
2006 330i SPORT  [7.34]
Anyone running 225/40 18 all around on sp rims, if so, any probs? Just wanna check before I switch rims, and get new tires. Thanks.
LIVE FAST..DRIVE FASTER!!
      09-28-2007, 01:51 PM   #2
mmm def
mmm def's Avatar
144
Drives: 21 330, 19 ND2 RF, 11 RX350
I would like to know as well..anybody have pics of this?
      09-28-2007, 02:43 PM   #3
Ray
Member
Ray's Avatar
306
Drives: three series
Aside from increasing the size, not too many owners will deviate from the original size.
The rear of the car will rotate more so during a turn than the 255/35-18 size.
      09-28-2007, 03:58 PM   #4
Thanks for the reply. Aside from the additional rotation, is it sufficient enough of an increase to noticeably affect the speedo, or traction system?
The reason I ask, i am set on a particular tire, for light winter use, and they dont offer oem rear size.
Or different situation, just up a size to 225/45 255/40 18....is that feasable?
      09-28-2007, 04:20 PM   #5
octaveshift
Checkraising with air....
octaveshift's Avatar
Drives: '07 335xi
It shouldn't be an issue- I think several people are running this setup without any problems.
An interesting thought, however... when the width of the rim changes, say 8" -> 8.5" but the tire size stays consistent, say: 225/40... I would assume the total diameters (ride height) of the wheels and rims would have to be different, right? (Because the tire would be more stretched on the 8.5" rim.)
I wonder if this will cause an issue on an AWD system???
      09-28-2007, 05:23 PM   #6
The specs on the 225 I'm lookin @ reveal that it will fit on up to a 9 in. rim. Whether or not it too stretched is personal opinion i guess. I will just have to wait and see.
But I dont know if a stretched out tire would effect the x drive. I dont think it would. Anyone else?
      09-28-2007, 05:35 PM   #7
Ray
Member
Ray's Avatar
306
I wouldn't alter the height of the vehicle, but instead, find a different make or model.
Since the front and rear wheels are different in width, you have to consider the tire's outcome when installed.
      09-28-2007, 05:50 PM   #8
samsamwu
Drives: bmw
for some 225/40/18 tires specs i looked
they recommend a rim width between 7.5-9.0
and the rears are 8.5 so there should be no problem at all
      09-28-2007, 07:43 PM   #9
VMRWheels
VMRWheels's Avatar
2040
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
A 225 on a 8.5 isn't that much of a stretch, so the difference in height between the front and rear wheels using a 225 all around is negligible.
If this is for a winter tire I think there would be no problems, you aren't going to be driving aggressively in the winter anyways. Right?
      09-28-2007, 08:53 PM   #10
Its not for a full blown winter setup, just an all season performance tire, and its most likely never really gonna be in snow. Just freshly cleaned roads.
Its just gonna be w no spare and no runflats. Gotta figure something out.
      09-29-2007, 12:04 AM   #11
mmm def
mmm def's Avatar
144
Just get one of those mobility kits or AAA and you're golden.
      09-29-2007, 04:10 AM   #12
kevE90
Drives: F8x
+1
I got into reading some of the TireRack articles a whiles ago. The height difference for the 225/40 on the 8.0 and 8.5 is negligible. Something to do with the belts in the tires.
I definitely plan to do this with stock 18. All seasons, or maybe go all out with the winters since hypothetically it will be my second set.
      09-29-2007, 09:12 PM   #13
octaveshift
Drives: '07 335xi
Originally Posted by kevE90zsp View Post
+1
Thanks for this- I dug around on TR's site, and found it:
"Because tires have flexible sidewalls, a single tire size will fit on a variety of rim widths. A tire's rim width range identifies the narrowest to the widest rim widths that the tire is designed to fit. The width of the rim will influence the width of the tire. A tire mounted on a narrow rim would be "narrower" than if the same size tire was mounted on a wide rim. NOTE: Because the overall diameter of a steel belted radial is determined by the steel belts, there is little, if any, change to the overall diameter of the tire due to differences in rim width."
http://www.tirerack.com/tires/tiretech/tirespecskey.jsp
      09-30-2007, 03:39 AM   #14
kevE90
Drives: F8x
That's the one. Thanks for finding it.
      10-01-2007, 08:58 AM   #15
Gary@TireRack
Moderator
Gary@TireRack's Avatar
Drives: Formerly 1995 M3
Many have been going to 225/40R18 all around on the OE wheels for winter tires.
Winter
http://www.tirerack.com/a.jsp?a=AH8&...nter/index.jsp
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp
Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum.
      02-26-2024, 10:28 AM   #16
P4veLow7X
Drives: 2008 Bmw 335i E93
Hi guys ! I have a 2008 335i e93 with 225/40r/18 all around.
Obviously, the rear should be on 255 but I had a deal on some 225.
Although the car drive perfectly it look silly !
Can I put 25-30mm spacer on the rear ? Will it help ?
Thanks for you help.
