02-22-2018, 03:27 PM | #23 | |
Rep 870
Drives: 2006 BMW Z4M Roadster
Anyway, here is a cool video of the rod bearings being assembled in an S54. Wouldn't it be cool to have that pneumatic dual torque wrench? It's also interesting that unless they didn't show the step, there are no multiple torque tightening procedures during initial assembly. Just crank it down to a specific torque, but they are doing both bolts at the same time. That's probably the difference. 3 minute mark is where the rod bearings are tightened. Timing set at around 5:20. Valve shims at 6:40. Note no assembly lube is used on the floor...just oil. Lots of good material in the video: https://www.youtube.com/watch?time_c...&v=ZjFVV5HXU0Q Salty
2006 BMW Z4M Interlagos Blue/Black
Aux Port|LED Interior|LED Strip Trunk|Underseat First Aid Box|Stubby Antenna|Intravee II|BMW Oil Change Kit|Top Down Side Panels|Vibra Technics Engine Mounts|Rogue Trans Mounts|Engine Mount Bolts Upgrade|RS Windblocker|Euro Front Plate|M5 Illum Shift Knob|Supersprint Powerloop Exhaust|Gruppe-M Intake|RPI Scoop|Black Grills|19x8.5 ET35 F 19x9.5 ET22 R Sportline 8s PSS| Besian Vanos|CDV Delete |
02-22-2018, 07:19 PM | #25 |
Dog Listener
707
Rep 7,850
Yes, the S65 (and S85 from which the S65 is derived if I recall) has this issue. No lead in those S65 bearings either, so there's no warning flags. (Note, I'm not sure if the no lead is all or just replacement bearings.)
02-22-2018, 07:51 PM | #26 | |
Rep 528
Drives: E86 Z4MC; E92 M3
E46 M3 Coupe 6MT Jet Black/Cinnamon GONE
E85 Z4M Roadster Imola Red/Black GONE E90 M3 Sedan 6MT Jerez Black/Fox Red GONE E86 Z4M Coupe Interlagos Blue/Black E92 M3 Coupe 6MT Interlagos Blue/Fox Red - Build Thread |
02-22-2018, 09:35 PM | #27 |
salty cowboys fan
6218
Rep 3,429
Should figure out what Porsche does with the GT3. I think I remember hearing their engineer say that they run a ton of oil pressure in the new 4.0
Edit — just watched that video again, it’s actually the opposite. They run low oil pressure, have bigger main bearings, and sounds like they have oil coming out of holes in the con rod journals? Can’t remember if ours does that. Watch vid below @ 11:40 Double edit — yeah ours does too. Maybe GT3 eats bearings too lol
shes home! '22 M4 Comp xDrive
02-25-2018, 11:45 AM | #28 |
115
Rep 232
Great thread... I will be adding to this conversation soon, next weekend I will be doing my oil change. I have been using Liqui Molly 10w60 with Liqui Molly Nos2. We will see what comes back from the lab.. Sitting at 29K
02-25-2018, 12:54 PM | #29 |
#buildnotbought
11057
Rep 4,924
Sounds to me that he describes that the rodbearings are fed by oil which is pumped through drilled passages in the crank.... Like every automotive engine has had for the last 50 years?
Z4 3.0i | ESS TS2+ supercharger | Quaife ATB LSD | Brembo/BMW performance BBK front/rear | Schrick FI cams | Schmiedmann headers+cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers/KW camber plates | Sachs race engineering clutch | tons of custom sh#t
02-26-2018, 07:13 AM | #30 | |
Rep 870
Salty
02-26-2018, 09:12 AM | #31 |
Rep 1,107
Mine is going in to my indy for bearings tomorrow at 68.5K miles. Just not willing to roll the dice anymore every time I drive it.
For sh#ts and grins I called the dealer to get a quote from them. The service advisor called me back and told me $9300. I said "thank you for your time". Even if they assumed a crank replacement as part of the service I don't know if it would have come to that much $$. I didn't want to spend any add'l time on the phone with them investigating what work the quote covered. |
02-26-2018, 11:29 AM | #32 | |
Rep 3,004
What is costs for rod bearing replacement??
Racerbruce
02-26-2018, 02:02 PM | #33 |
Rep 431
For just my rod bearing service last week at TYSpeed in NJ, it was 10 hours of labor for a total of $1,050. ECS tuning WPC rod bearing kit was an additional $675. Hope this helps and I highly recommend this shop if anyone is in the area!
1995 E36 M3 | BMW CCA Club Racer - IP #34 | Gray / Blue / Orange | 261WHP | 2,700lbs
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red | 2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo |
03-01-2018, 02:38 AM | #36 | |
Dog Listener
707
Rep 7,850
That dealer must have been replacing the flux capacitor and blinker fluid in addition to the bearings. |
03-05-2018, 09:50 AM | #37 |
Rep 1,107
My indy must be better than yours, he charged $2,300. Only guy near me I trust though. 68K miles and glad to have it done in time for top-down season to start (any day now). My last Blackstone reported 34ppm Lead but zero Copper (I got lazy and missed two oil changes/two years of having it analyzed though). From my pics I would have thought I'd have non-zero Copper.
03-05-2018, 09:58 AM | #38 | |
1156
Rep 2,880
Drives: Anything
03-05-2018, 10:26 AM | #39 |
Rep 1,107
Still, they're not looking good. Here's my use info:
- Live in NorthEast (New York City suburb) - Car not tracked or auto-crossed, enthusiast driven - Drive the car all year round (down to 20 deg. F) - Annual oil changes at 7.5K miles or less (always in Fall, before cold weather) - Castrol TWS - No cold engine drives shorter than 20 minutes - Engine run period of 2 mins before driving on cold start - No engine revs over 3K until engine is at 165 deg. F - No "fun" driving until engine is fully warmed up. It is what it is. So happy to be driving it again. Now I just need to avoid the melting snow/salted road water runoff in March. Would be nice if we had a warm, dry March like we did last year. After this Wednesday's snow storm that is. |
03-05-2018, 09:47 PM | #40 | |
Rep 870
Agree, your bearings look good in comparison to others. I'll be doing mine very soon. I've been honing my mechanical abilities on my son's 330Ci. Salty
03-06-2018, 12:37 AM | #41 | ||
Dog Listener
707
Rep 7,850
03-06-2018, 09:43 AM | #42 |
1156
Rep 2,880
Drives: Anything
This is the quote I got from Blackstone when I asked the same question about copper:
"We would expect copper to start rising too once the lead layer has worn away. The pictures of the bearings you sent clearly have reached the copper layer in some of them, but maybe your engine was making metal that's bigger than our machines can read (we look at the microscopic metal). Hopefully, lead will stay low going forward now that you've replaced the rod bearings."What I got from their response is that copper might be wearing away in larger chunks and therefore gets trapped in the oil filter and thus doesn't show up in their machine that only looks at things at a microscopic level? Does this make sense? Last edited by XMetal; 03-06-2018 at 09:49 AM.. |
03-06-2018, 02:29 PM | #43 |
Rep 3,286
Drives: 2002 M5;2007 M Coupe;2020 M2C
Wow.
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel 2007 E86 Z4M Coupe Silver Gray/Black 2021 Kia Telluride (hauler) |
03-06-2018, 03:28 PM | #44 |
#buildnotbought
11057
Rep 4,924
Especially if you think about that changing rodbearings is about 1 day of work tops for a trained mechanic. Add in about $900 on parts (1 half of a bearing is $37,-, which is pretty excessive), but even then they thus charge $1000,-/hour....
For $9300 you can almost expect a new engine....
