Go Back   6Post.com | BMW 6-Series Forum > BMW 6 Series Forum > General 6-Series Coupe, Convertible, and Gran Coupe Forum
      08-05-2020, 04:21 AM   #1
maron
maron's Avatar
74
Drives: E60&F06
BMW F12/F13/F06 DIY LCI Adaptive LED Headlights Retrofit
I have retrofitted for a total of $900.
It was completed by changing the PIN of the FRM and headlight connector respectively
and changing the power supply of 15A and added CAN3 from ZGW
Appreciate 3
      08-05-2020, 12:19 PM   #2
shine775
Scott
shine775's Avatar
Drives: BMW 640i
2013 BMW 640i  [0.00]
How did you do this?
Scott
      08-05-2020, 01:33 PM   #3
M340LCI
Drives: 2023 M340i LCI
From where did you source the LCI headlights?
My passenger side Pre LCI LED has conked off.
Planning to upgrade to the LCI LEDs.
Any help will be appreciated.
      08-05-2020, 03:19 PM   #4
elvisisdog
34
Drives: F06 MSport 2013/09
That is very cool, did you have led adaptive before the LCI lights?
      08-05-2020, 04:35 PM   #5
khoa@x-ph.com
khoa@x-ph.com's Avatar
Drives: F83
Good info.
      08-05-2020, 06:13 PM   #6
patchesj
patchesj's Avatar
71
Drives: BMW M6
Uh... What are those fog lights you have??
      08-05-2020, 08:06 PM   #7
maron
maron's Avatar
74
Drives: E60&F06
Wiring and coding
It was easier than you can imagine
      08-05-2020, 08:08 PM   #8
maron
maron's Avatar
74
Drives: E60&F06
I can get used parts cheaply in my country (JAPAN).
If you are planning an LCI headlight
I recommend that you use esys to perform program operations.
Change the LCI year of manufacture and type code.
If the HWEL of the FRM is not black, the FRM needs to be replaced.
      08-05-2020, 08:09 PM   #9
maron
maron's Avatar
74
Drives: E60&F06
Yes. I had Pre-LCI LED adaptive headlights
      08-05-2020, 08:11 PM   #10
maron
maron's Avatar
74
Drives: E60&F06
Fog lights are from the factory
      08-06-2020, 07:50 AM   #11
patchesj
patchesj's Avatar
71
Drives: BMW M6
Wow. I totally didn't even know this was an option... Might be an interesting retrofit on my M6.
      08-06-2020, 09:04 AM   #12
maron
maron's Avatar
74
Drives: E60&F06
Oh. I understood.
There is no fog lights option on the M6.
      08-06-2020, 03:52 PM   #13
elvisisdog
34
This is very much on my list to do, could you provide the pin connector changes for the FRM to the headlights and where did you connect for CAN3?
      08-07-2020, 04:17 AM   #14
maron
maron's Avatar
74
Drives: E60&F06
Here is a simple wiring diagram on the left.
iamvanja167.00
      08-13-2020, 09:52 AM   #15
NytWolf
22
Drives: 2016 F10, 2015 F30, 2008 E60
Can you post before (pre-LCI) and after (LCI) pics? TIA I'd also like to know your opinion on the differences between the two.
      08-18-2020, 01:31 AM   #16
garethm
Drives: bmw
Nice work! I envy you for having awesome headlights!
      10-31-2020, 11:50 AM   #17
823
9
Drives: 635d M
Hi,
my 640d is flooded, I would like to repair it and change also healights.
Can you explain me better how to install the new led into my car (2013 led).
Thank you very much
      11-01-2020, 06:00 AM   #18
maron
maron's Avatar
74
Drives: E60&F06
Originally Posted by 823 View Post
Hi,
Thank you very much
This is what you are posting in the thread.
If you have any questions, please ask each time.
      11-01-2020, 07:35 PM   #19
maron
maron's Avatar
74
Drives: E60&F06
Before and after
HeyKC101.50
NDAzone13.50
      11-06-2020, 03:17 AM   #20
zedgaras
Drives: F06 M6
Hello,
I am doing the same retrofit from PRE LCI LED -> LCI LED
Few questions:
1.When you change from old to new FRM, do you need only to change few pins for headlight function? All other pins remain the same?
2. Could you give more details on how to code new FRM and headlights? I have esys, however my experience is limited
I need to change Vehicle FA? If yes, then which FA function i need to change?
As i understand, i will need to inject new CAFD into new FRM?
What else I need to do beside this and in the last stage "teaching" new headlights with ISTA+ ?
      11-06-2020, 02:40 PM   #21
radj411
Drives: BMW 3 series
Please, let me know how you added CAN3 network from ZGW ?
I'm currently working to retrofit LED headlights on my 2016 F55 and it seems there is no CAN3 on my FEM or BDC module.
if you can help me on this topic, please ?
Thanks.
RAdj'
      11-07-2020, 02:52 AM   #22
maron
maron's Avatar
74
Drives: E60&F06
Originally Posted by zedgaras View Post
Hello,
Few questions:
① Replacing the old FRM with the new FRM (106D CAFD) is plug and play
* VO code only
②The year of manufacture was changed from (ex 0315 or 0717) and the type key (ex 6D02) was changed.
I did not need ISTA (+).
6post.com
