05-25-2021, 11:54 AM | #1 |
Rep 41
does bmw 435i fbo E30 require 1-step colder plugs?
Hi, I have a 435i 8AT with the following mods...
Wagner tuning catless DP & evo intercooler supersprint cat-back exhaust Quaiffe LSD bms air intake (mostly for the dramatic sound) alu chargepipe Im running those mods with a wedge performance E30 tune. Would it make a difference for the better or worse (and why) for me to go with for example link 1 or link 2 Car goes great as is, I'm just asking preemptively. |
05-25-2021, 12:35 PM | #3 |
Rep 41
05-25-2021, 02:16 PM | #4 | |
Rep 7,613
I run OEM plugs with E30 on MHD stage 2+ with FBO (and more) mods with no problems. |
05-25-2021, 03:35 PM | #5 | |
Rep 41
I have looked through a couple forums, without really finding out why to get the or why you shouldn't get the spark plugs (the pros and cons with them). Which is why I asked again. But no worries, thanks for clarifying again. |
05-25-2021, 03:55 PM | #6 | |
Rep 7,613
Pros: Potential to eliminate misfires / "spark blowout" at very high boost levels with smaller gap, but again, 99% of people don't need this. Pros of stock plugs stock gap: You want the biggest gap possible (without issues) so you start here. That gives you the best combustion. Cons: None, unless you start getting misfires. |
05-26-2021, 11:08 PM | #7 | |
Rep 75
2014 335i xdrive Luxury |VRSF 5" HD FMIC|AA catted DP|FTP Charge & Boost pipe|GFB DV+|BM3 STG 2|XHP STG 2|Afe Scoop|Match UP 7BMW amp|NGK 2 Step Colder(.024gap)|Dinan Ignition Coils|Weichers Steel Strut Bar|Michelin A/S 3+
05-27-2021, 12:26 AM | #8 | |
Rep 7,613
05-28-2021, 09:07 AM | #9 |
24307
Rep 191,021
if the stock spark plugs are new, you'll be fine. As they get older they start misfiring and that's when you need to upgrade to the NGK colder plugs
435i, e30, fbo, plugs |
