BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > Steering Lock Faulty (Red) Error Code A116
      08-24-2013, 08:27 AM   #1
AFF
31
Drives: G11 7 Series - Sapphire Black
Hi Guys,
I had the common 'Steering Lock Faulty' (Red) with a steering and padlock sign come up on the dash a few years ago. It also mentioned
'Electronic steering lock is not disabled one engine has been switched off. Engine can not be restarted'
However the engine could still be restarted, at the time I fortunately had a friend working at the local BMW dealership or reset/reflashed the CAS module. The car has been perfect since up until a few days ago when the error messege came back. The car started for the first few days at which point I thought I would leave it till the weekend. Unfortunately come this morning the car would not start! It is now sat on my drive
I have read up on a few forums that the best starting point is to reset/reflash/update the CAS module once again. Is there any way I can do this myself... If so what equipment/software do I require.
Any help will be much appreciated
Many Thanks
Aff
E92 335d - Matt Black
AFF
      08-24-2013, 10:20 AM   #2
Josh1a1h
170
Drives: AzuriteBlack 335i E92
Good luck mate... I am having this issue as well mate.
I heard it happens when a battery begins to weaken or has low charge.
I heard new cars don't come with steering lock. The lock itself is the auto tranny, so they removed them altogether...
      08-24-2013, 11:31 AM   #3
makkan00
makkan00's Avatar
886
Drives: F83 and F36
Just finished with updating CAS module of the car which had this error.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play
      08-24-2013, 11:32 AM   #4
makkan00
makkan00's Avatar
886
Drives: F83 and F36
When you sit in the car and when you insert the key, does that symbol some straight on the dashboard?
      08-24-2013, 11:57 AM   #5
Josh1a1h
170
My steering lock symbol comes on the minute I unlock and sit in the car.
But my car still starts and drives...
Mate can you code this out for me please?
It happened because of a low battery my car was sitting in the workshop for a long time waiting to get painted
      08-24-2013, 12:01 PM   #6
AWBimmer
AWBimmer's Avatar
344
Drives: E92 335D Pre-LCI | E63 M6 V10
I had that recently. Had my car coded and a new battery put in.... Tbh for the price you may as well look into a new steering column from an Indy )
      08-24-2013, 12:11 PM   #7
makkan00
makkan00's Avatar
886
Drives: F83 and F36
Always silly comments.
I'd like to know how changing the whole steering column, fitting + coding works out cheaper than just flashing the module?
      08-24-2013, 12:13 PM   #8
makkan00
makkan00's Avatar
886
Drives: F83 and F36
Josh
Ask somebody to read the codes from your car and send it to me.
If its typical steering wheel error, I will flash it for you.
And its defo cheaper than buying a brand new steering column from the stealer.
Not speaking about the junk on fleabay, hit and miss stuff.
      08-24-2013, 01:14 PM   #9
AFF
31
Thanks for the feedback guys, the red steering wheel error comes up as soon as I unlock the car, makkan00 whats involved in updating the CAS module if you don't mind me asking. A possible DIY? Only problem I have is its sitting on my drive and im guessing your not in Hampshire area...
      08-24-2013, 01:20 PM   #10
makkan00
makkan00's Avatar
886
Drives: F83 and F36
No,
I'm not in that area. Call out the local indy to get it done.
Its not DIY. If it was coding, I could have said, go ahead.
A decent indy would charge you £70-90 max.
      08-24-2013, 01:26 PM   #11
AFF
31
Okay will give a local indy a call on Tuesday, is A116 a typical steering wheel error? Should flashing resolve the problem.
      08-24-2013, 01:37 PM   #12
makkan00
makkan00's Avatar
886
Drives: F83 and F36
B/w how do you know that its that code?
      08-24-2013, 01:47 PM   #13
AFF
31
A friend of mine is a mechanic and he bought his snap on machine over and it threw up A116, cant remember the exact fault description but it did mention steering lock error and something about CAS. Little did I know it was not as easy as trying to clear a code!
      08-24-2013, 02:45 PM   #14
Wrighty_QPR
Drives: E90 325d M
Mine had the exact same problem last month mate. Needed a new steering col.
Took it to BMW Sunningdale and they agreed to pay for the part, just had to pay labour.
      08-24-2013, 03:05 PM   #15
AFF
31
What year is the vehicle and how did you manage to get the part our of them! Good on you budd!
AFF
      08-25-2013, 08:07 AM   #16
Josh1a1h
170
How much does it cost to have done?
      08-25-2013, 01:20 PM   #17
Sheepy
Sheepy's Avatar
181
Drives: F82 M4 Competition
I had the same fault with it fixed under warranty, as my receipt only stated my excess fee I asked how much it would have cost & was told in the region of £800!
      08-25-2013, 01:37 PM   #18
Josh1a1h
170
Hmmmm
I still have warranty... Just wondering if my mods would mean I can no longer have this replaced under it
      03-22-2014, 04:18 PM   #19
kiteboy
kiteboy's Avatar
France
Drives: E92 Stage 2 BR Performance
i had this red flad with steering, i think it was due to my previous batery (7 year old)
i put a new batery but also it will stay red ??
i tried to erase all default with my bavarian but unsucess , my car don't start ???
what can i do ??
335i Pack M Stage 2 BR Performance 403,5 hp 582n.m/Bilstein B14 pss/R&B PVC2 valve/K&N air filter/Spearco FMIC/pre cata empty/EBC Redstuff,aviation hose, BMW Performance exhaust, Charge pipe Evolution Racewerks, Forge DVs
      03-22-2014, 04:25 PM   #20
M4rius
Lithuania
23
Drives: e92
2007 bmw e92  [9.00]
Originally Posted by makkan00 View Post
No,
well it's diy if you have right tools and know how to use them
      03-22-2014, 04:30 PM   #21
Robin330i
Drives: E90 330i M Sport
Anyone know how much a steering column is to buy from BMW? I am dreading this fault occurring on mine however I would change the column myself to save a few quid.
      03-22-2014, 11:15 PM   #22
makkan00
makkan00's Avatar
886
Drives: F83 and F36
No,
A decent indy would charge you 70-90 max.
If its diy for you, it does not mean that its diy for others
