Helix Innovations in Intercooler Design
06-29-2012, 07:27 AM | #23 |
16
Rep 217
06-29-2012, 07:58 AM | #24 | |
Rep 1,568
06-29-2012, 08:08 AM | #25 |
16
Rep 217
I'll post one later today when I get to the shop. I have 100 intercoolers to QA, box, and ship. Not looking forward to the 100* 100%RH today. It will require liberal use of powder.
06-29-2012, 08:28 AM | #26 |
Rep 3,262
I was supposing that you intend to use the same car, and only switch the intercoolers for testing, right ? Because otherwise the comparison wouldn't really make sense. In this case, the wastegate duty cycle differences can only be attributed to the intercooler.
06-29-2012, 10:19 AM | #27 |
Rep 1,903
Drives: e92 335i 6MT
I would like to see WGDC logged as well. I typically see ~50% WGDC on my ETS 5", averaged throughout a single gear pull. From the logs that I have seen of others running the Helix, it is usually ~10% higher (for example). I'm not sure if this increase is large enough to be concerned about?
Otherwise, when it comes to IAT suppression, the Helix appears to be one of the best out there. It's amazing that IATs actually DROP at the start of a pull. |
06-29-2012, 10:35 AM | #28 | |
Rep 1,283
On the n54/n55 engine management system there is more power to be made via low AIT which has submaps that alter the tune/power, then boost level(lower wgdc) which is an arbitrary measure of restriction in the entire system which have no submaps to alter the tune, Shiv and Terry and any other tuner will attest to this, and have commented on this in other threads. This is the reason that fmics that have better temperature reduction have higher dyno deltas than those that are not very good at controlling temperature rise, anyone that loses power on a hot vs cold day can easily understand this Last edited by TurboBullett@Ambient Thermal Management; 06-29-2012 at 10:57 AM.. |
06-29-2012, 05:53 PM | #29 | |
Rep 1,708
For someone targeting max boost with meth, I would NOT recommend the Helix. For someone wanting the most consistent, lowest IATs I would recommend Helix. I'd love to see some actual pressure test data. |
06-29-2012, 06:26 PM | #30 |
2 cars, 3 turbos
Rep 29
thanks for this...I really want to change my intercooler out and deciding on the right one is a tough decision
'09 - alpine white 335i - JB4, DCI, ...looking for an exhaust
'95 - Cobra- 336ci & Comp HP7679 on E85 |
06-30-2012, 10:59 AM | #32 | |
16
Rep 217
Take a cubic foot of air @ 210F inlet temperature and a molar weight of 1.26414494, the pressure will be 20.029psi (intercooler inlet). Reduce the temperature of the same air values to 74F, the pressure will be reduced to 15.9psi (More thermal efficient intercooler outlet). Now use the same values again for 84F, the result is 16.26psi. Close to a half a pound of pressure and 10 degrees hotter (Less thermal efficient intercooler outlet). The result of the more thermal efficient intercooler over the less efficient intercooler is an ECU adaptive increase of wastegate duty cycle to:
An increase of ignition timing is also a result of lower IAT. |
06-30-2012, 12:53 PM | #33 |
46
Rep 337
It being a blistering hot summer I was wondering...Is there another Helix FMIC Group Buy still going? Because I live in Alabama and yesterday it hit 107F...I need this haha!
08 335i Alpine White/Coral Red Interior With A PROcede Tune!! 09 Yamaha R6!!
06-30-2012, 01:00 PM | #34 |
16
Rep 217
06-30-2012, 02:04 PM | #36 |
Rep 2,396
Drives: '08 E90 335i
Helix FTMFW
07-01-2012, 09:12 AM | #37 |
46
Rep 337
[QUOTE=Helix Wildebeest]Sweet, will do!!
07-01-2012, 10:35 AM | #38 |
15
Rep 329
Drives: 08' 335i, ZHP 330i
I must be missing something in the translation. I have the 'other' FMIC that is being crucified here and I cannot find the fault. Absolute plug and play <30min start to finish install.
What are the real world performance differences that will be realized and noticed (not laboratory measured) between the two? You know I can go out and spend $130 on some new Nike Vomero 6's or I can go get the other guys brand for 20% less. You can present to me the laboratory tests that show the differences but while running around the block am I going to notice or care? See attached. Stock COBB Stg 1+ FMIC Aggressive v4.01 ST What am I missing? How would this log look different with the Helix? What would I notice different with the Helix? I live in the world of Consulting. If you cannot show the value in the difference it doesn't matter. I cannot find the 'value' in the difference. T |
07-01-2012, 12:02 PM | #39 | |
Rep 557
07-01-2012, 12:23 PM | #40 | |
15
Rep 329
And to your second point, have you looked around at every single product in the market today? Value value value, comes in second only to location location location. Which inter cooler performs better? Probably the Helix. Which intercoer provides the best value to me? The one I purchased. T |
07-01-2012, 02:01 PM | #41 | ||
Rep 30
07-01-2012, 05:28 PM | #42 | |||
15
Rep 329
T |
07-01-2012, 05:53 PM | #43 | |
15
Rep 298
2018 BMW M3 ZCP
1999 BMW Z3 M Coupe Turbo 2017 Ram Rebel 2015 Porsche Cayman S |
07-01-2012, 06:51 PM | #44 |
Rep 557
Wanger strolled onto the scene with a copy of the Helix intercooler and to this day is still pretending they did no wrong. They need to man up and address their breach of respect to the tuners who pour their time, money, and all the risk involved in new product development into innovation. And that's the truth.
forge, helix, intercooler, stepped core, wagner |
