11-24-2019, 11:39 PM | #23 |
Rep 10
The phone pairs, everything works. It just doesn’t show on the list, it just says connecting forever when you click “add new phone” even though it’s already connected. That’s my issue, not that I don’t know how to pair a phone to the car.
11-24-2019, 11:57 PM | #24 | |
Rep 10,473
11-25-2019, 08:00 AM | #25 | |
Rep 1,934
11-28-2019, 01:26 PM | #26 |
Rep 10
well since I bought the car used, if there was phone with an emoji in the name from the previous owner that caused this, I don’t have access to it, so I guess I’m stuck I’ve tried looking up a factory reset for the entire computer but there doesn’t seem to be one. Guess I’ll have to take it in
12-14-2019, 10:09 AM | #27 |
Rep 10
Just as an update. After weeks of research and forum hopping, I found out the only way you CAN delete the Bluetooth data and basically start over via ISTA. I’ve never used the software and I’m hesitant cuz I don’t want to mess anything else up. But at least I know there’s a DIY solution
12-21-2019, 06:14 PM | #28 |
Rep 16
You saved my life!
Had same issue with a f30 320i (Latin America vehicle) we don’t have much support here and after pairing with my daughter’s iPhone I had the same issue. Phone worked for streaming music but not for phone calls from the car. List usen telephone showed 4 empty slots but phone showed under BT music streaming. Asked my daughter if she had any emojis on her phone name and SHE DID!!! 2 of them!. After removing them and re-pairing her phone everything went back to normal and recover my car’s phone capabilities!!!!!
At the dealer they had no idea about the issue and I thought I was never gettting phone capabilities back, this thread saved me! marmit2017 You saved me!!! Thank you!!!! |
04-10-2020, 11:33 AM | #29 |
Rep 1
It worked, never would have figured it out without this post!
OK, kudos to marmit2017! - as I believe that is where credit is due from what I can see from this post anyway.
We had a small group (just immediate family) that would have been able to connect their phone to the car. After asking what the phone names were for everyone, we found one of the phones had three teardrop emoji's in the phone name. We renamed that phone and we just went out to the car and all problems were resolved. Nice catch, would have NEVER thought to think this was traceable back to a phone name. |
05-02-2021, 12:40 PM | #30 |
Rep 13
Hi All, Has anyone found a solution if you are unable to connect the phone with the emoji in the name as I don't have access to that phone.
Thanks James |
05-08-2021, 12:58 AM | #31 | |
2014 F30 320d. Photographer, Videographer.
Rep 5
I'm also having a similar issue. My phone (Samsung Note10+ 5G) and car (2014 F30 320d) are doing the same thing; my car says 'Connecting...' but my phone says it is fully connected, my car recognises my signal, if I go into 'Contacts' it displays them with the BT symbol next to them, but if I go to into the phone bit it tells me to connect. How is this a thing in 2021?? Thankfully, if this is the only issue I have with the car, I'll still be at a 15/10 level of happiness with it. |
05-08-2021, 01:13 AM | #32 | |
18
Rep 138
I myself have been having issues with my iPhone 11 Pro on iOS 14: Phone is connected playing music fine. Music suddenly stops. Car says it's connected and no issues. I have to turn bluetooth on the CAR off and on and it'll work. Doesn't happen on my older iPhone 6S. Sucks! |
05-08-2021, 01:43 AM | #33 | |
Rep 5
I had to buy this so that I could charge via a USB and have audio at the same time. It's great, but fuck, I wish the BT worked/had the right functionality. I'll just mod that when my sales warranty runs out |
05-08-2021, 04:26 AM | #34 | ||
18
Rep 138
TaoTronics Bluetooth Car Kit, Bluetooth Receiver, Bluetooth 4.2 Hands-Free Audio Adapter (Built-in Microphone, CVC 6.0 Noise Cancellation, 3M Magnetic Base, Air Vent Clip, Dual 2.1A USB Car Charger) https://smile.amazon.com/dp/B0769DXZ...C6ZR1PQH3Q0NPM Or get the MMI, would be a quick removal if you needed to take it out |
05-08-2021, 10:04 AM | #35 | |
Rep 540
If you don't have NBT then it's probably best to find someone with an NBT unit to try pairing up to so you can test first though |
05-09-2021, 12:59 AM | #36 | |
Rep 5
It is highly, highly likely that when my sales warranty runs out in 3 months I'll be modding in a better infotainment system to remedy this. Bigger screen with Android Auto/Apple CarPlay is top of my list of mods. |
05-09-2021, 12:45 PM | #37 | ||
18
Rep 138
thatmikeyouknow0.00 |
05-10-2021, 12:37 AM | #38 | |
Rep 5
So, sod it, it can't hurt to try! I'll let you know how it goes. |
05-13-2021, 01:34 AM | #39 | |
Rep 5
My phone is connected to the TaoTronics, which is aux'd into the car. I can use this to skip tracks, adjust the volume, and answer/decline/end calls. It's dead simple. However, I still need to use the phone (physically while stationary and engine off, Google assistant whilst moving) to initiate calls or change my playlists etc. What this device does do is dramatically improve the quality of the calls, which is cool. I still wish the damn car would work with the phone though! 😂 Definitely gonna mod that shit up ASAP. |
bluetooth, phone, reset, telephone |
