Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Do you set pressure on tyres........?
View Poll Results: Warm or Cold
Warm 1 5.00%
Cold 19 95.00%
Voters: 20. You may not vote on this poll
      12-12-2006, 03:31 PM   #1
- Paul -
- Paul -'s Avatar
England
712
Drives: see above.
2005 320D SE  [10.00]
2005 645  [9.00]
when they are Cold or Warmed up.
I have always set them with cold tyres but according to this board, a few people set them with warm tyres.
      12-12-2006, 03:33 PM   #2
Carnage
Carnage's Avatar
Drives: people insane
cold. always.
      12-12-2006, 03:51 PM   #3
Fokusracing
Drives: Alpine '17 M2
Manufacturers recommendations are always cold. Set by NHTSA.
      12-12-2006, 03:52 PM   #4
gos
Drives: E90 330xi
plus, I believe the max pressure on the sidewall is the maximum cold pressure
330xi SG/Terra/Burl -- ZPP, ZSP, ZCW, CA, Sirius, PDC
      12-12-2006, 04:06 PM   #5
HRC
MAUI BUILT
HRC's Avatar
Drives: 2006 330i MT
2002 E46 325i  [0.00]
2012 E70 35i  [0.00]
When the tires gets warm, the air inside heats up and you won't get an accurate reading.
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
      12-12-2006, 07:28 PM   #6
Fokusracing
The max pressure on the sidewall is obviously the max cold pressure, but not often is it the manufacturers recommended air pressure. Generally, it is ok to go higher than the manufacturers recommended (up to max recd) , but not lower. Best to just stay the same.
      12-13-2006, 10:58 AM   #7
- Paul -
- Paul -'s Avatar
England
712
Drives: see above.
2005 645  [9.00]
I just follow what it says on the door jamb. I set them when cold. I figured that the manufacturer must allow for expansion when warm when they set the cold figures.
