Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > 19x10 ET20 rear on LCI - will it work?
      01-29-2013, 05:32 PM   #1
- maciek -
Germany
Drives: E91 320d LCI / E39 M5
hey guys
I own a 2009 LCI E91 (facelift) and would like to know if any of you had an opportunity to run 19x10 wheels on the rear?
I do not have coilovers, I will go with Eibach Pro Kit. the offset on the 19x10 wheels is ET20. they are BBS CH.
will I require a lot of fender work to make this work? compared to a 19x9.5 ET40 wheel which BBS recommends, the 19x10 ET20 will poke 26 mm (outside).
I am guessing that the 19x9.5 ET40 has about 10 mm clearance to the fender. so rolling the fender 16 mm is a lot in my opinion.
what are your thoughts?
please keep in mind my car is an LCI (facelift) model
thank you
      01-29-2013, 05:39 PM   #2
SeanS54
SeanS54's Avatar
168
Drives: F82 M4 ZCP
19x10 wheels is ET20 on an LCI is too aggressive... ET30 is already pushing it...
it can be done w/ super stretched tire, fender work, and crazy camber....
      01-30-2013, 09:07 AM   #3
MonacoBlueE90
MonacoBlueE90's Avatar
Finland
163
Drives: BMW E90 320D Half-LCI
As said above it's possible, but not without work.
10X19 offset 25 rear with 235/35/19 The fenders are rolled.
http://www.e90post.com/forums/showthread.php?t=258714
http://www.e90post.com/forums/showpo...92&postcount=7
      01-30-2013, 05:08 PM   #4
- maciek -
Germany
Originally Posted by MonacoBlueE90 View Post
thanks
      01-30-2013, 05:43 PM   #5
FormerRotor
FormerRotor's Avatar
96
Drives: 2011 335d, M-Sport
These are 19x10 ET25 on stock m-sport ride height and camber w/265s to give you some idea (on stock ride height, the 265s seem to work, but I will be dialing in the camber and doing a fender roll for safety's sake)...
http://www.e90post.com/forums/showthread.php?t=786191
...but et20 on a drop i think would be pushing it unless you really want to ramp up the negative camber and maybe allow some poke.
My Picture Threads (Oldest to Newest): 1 2 3
Join BMW CCA! (Use my link and I get credit )
      02-01-2013, 12:25 AM   #6
hawaiianeze
Major Pain
hawaiianeze's Avatar
Drives: LCI E92 335i
excuse me for getting a little off topic here, but considering I have a pre lci I cannot help you out too much here, but I know that the lci less space in the fender but with a good fender roll couldn't you easily fit 19x10 et 20? I've seen 19x12 on a lci with some camber of course but still.. I run 19x11 et 20 on my pre lci with stock camber so i'd have to think that with an lci 19x10 et 20 should fit fine
close enough to what your looking for
http://www.e90post.com/forums/showthread.php?t=723664
      02-01-2013, 01:58 PM   #7
PSUSMU
Drives: 2008 Porsche 911 Carrera S
It's easily done. e90post is full of clowns that don't know what they're posting.
      04-13-2013, 05:07 PM   #8
flossen20
Drives: M4
Long shot, but would it be possible for 19x10 et20 to fit on the front with M-sport suspension? I don't plan to lower my car. I'm looking at a set of used wheels that have a squared setup. Just curious. Anyone?
      08-02-2013, 08:28 AM   #9
starbai
PPRSWCE
starbai's Avatar
Guyana
654
Drives: 18 Tanzanite Blue F80 ZCP
Did you ever end up doing this? I'd love to see it as I'm looking to do a 19x9.5 +20... w/245/35 tire... so not as aggressive but similar. I dont mind rolling/pulling the heck outta the fender.. its just the camber i dont wanna go nuts with
