Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Wheel and tire fitment input
      07-23-2013, 10:05 PM   #1
*DAN*
Drives: 325i E90
Just wondering if these specs would fit my pre-lci e90
fronts:
18x9.5 +34
rears:
18x10.5 +34
Looking to run Neova AD08's or something similar , nothing stretched, prefer a functional setup
Thinking of 245/40/18 for the fronts and 275/35/18 for the rears but ive got a feeling that i'd be scrubbing on this set up
      07-23-2013, 11:01 PM   #2
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
Drives: 06 330i 6MT
You'll probably have problems with suspension clearance with that front offset. Spacers will be needed.
245/275 is too wide, and I'm not sure how wide Advan Neovas run.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit
M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear
      07-24-2013, 12:57 AM   #3
*DAN*
Drives: 325i E90
Ah damn, would I need to go down a tire size? From memory, the sidewall of the Neova are slightly wider than most tires. For reference, I was thinking of running these rims:
http://www.varrstoen.com.au/shop/2-2...ims-wheels-18i
      07-24-2013, 09:46 AM   #4
MonacoBlueE90
MonacoBlueE90's Avatar
Finland
163
Drives: BMW E90 320D Half-LCI
fronts:
18x9.5 +34
rears:
18x10.5 +34
18x9.5 et34 will fit to front if you have stock shocks and lowering springs it will leave about 2-3mm gap, but with coilovers you need spacers, since those are thicker. Also you need 235/40/18 tyre. It really isn't that stretched on 9.5 wide wheel. Last summer i had 18x9.5 et35 with 235/40 at front
View post on imgur.com
I now have 18x9.5 et30 at front with 235/40/18 Here is how it looks
http://www.e90post.com/forums/showpo...3&postcount=39
You can't have 10.5 et34, because they only offer offsets 0, 15, 22, and 30 for 18x10.5 wheel. Atleast in this link.
http://varrstoen.com/products/es-2/
What i would recommend is to get
18x9.5 et30 to front with 235/40/18
18x10.5 et22 to rear with 265/35/18 and rolled fenders.
Example of 265/35 on 10.5
http://www.e90post.com/forums/showpo...69&postcount=1
Other solution would be 10.5 et30 with 275/35 but then it would look little bit funny, because front tyre would be more stretched and the front wheel pokes out more than rear.
In fact i have ordered those exact wheels with polished finish to my pre-lci e90. But i went with 18x9.5 et22 front with 225/40/18 and 18x10.5 et15 rear with 255/35/18. I will be doing fender roll and camber adjustments too.
      07-24-2013, 12:26 PM   #5
VMRWheels
VMRWheels's Avatar
2052
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
I wouldn't recommend those wheel and tire specs. People have fit similar fitments up front, but use narrower tires. Also, the rear is likely going to need a fender roll. Lastly, the AD08 runs VERY wide, so if you're going up in size it's going to fit even bigger than most other brands/models.
      08-05-2013, 08:03 PM   #6
*DAN*
Drives: 325i E90
Ah man, what about 18x9.5 +22 all around?
planning to use 235/40 on the fronts and 265/35 on the rears? Thinking I might need a spacer on the rear but Im a tad concerned about the fronts, don't mind doing fender adjustments but as long as it isnt too extreme
otherwise I'll go with a safer fitment and stick 8.5 +35 on the fronts but then i wont get that concave at the front
      08-05-2013, 09:21 PM   #7
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
Drives: 06 330i 6MT
You will need spacers in the rear or it will look weird. And if you're running square wheels, run a square tire setup.
      08-05-2013, 09:38 PM   #8
*DAN*
Drives: 325i E90
out of curiosity, can i ask why? sorry, first time hearing that
      08-05-2013, 11:51 PM   #9
MonacoBlueE90
Finland
163
Probably because aesthetic reasons. If you have 9.5 with 235/40 and 9.5 with 265/35. The front and rear tyre look different. Front is little bit stretched and rear isn't.
I would recommend 225/40/18 with 18x9.5 et22. That's what i was told and looked around web that's what most have. Also i was told to roll the fenders at front just to be safe.
