BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Tyres for 19" Alloys
      10-23-2010, 12:20 PM   #1
sow
Drives: 3 Series Coupe 320d Black
Hi all
I'm new here but have been lurking for a while. I generally find what i'm looking for, unfortunately on this occasion I cant!!
I drive a 320d coupe M Sport with 19" M Sport Alloys on a 58 plate
I am looking for 4 new tyres Yes 4!!
I have got some really bad wear on all 4 tyres on the inside rims. I believe that the tracking must be out so i'm in the process of getting it re tracked.
I went to see a good friend who is in the tyre trade and he priced 4 new tyres up I need two 225 35 19 and two 255 30 19
the 225's were coming in at £168 each which were Bridgestones
The 255's were coming at £209 which were also Bridgestones.
Both of these are Runflats
I would like to put non runflats on but my friend said that the 255's only come in Runflats is this true?
Also anyone got any ideas on how to get the price down?
Many thanks in advance for all of your help
Cheers
Sow
      10-23-2010, 12:25 PM   #2
E92Fan
Moderator
E92Fan's Avatar
322
Drives: .
Originally Posted by sow View Post
Hi all
Cheers
Sow
What a load of tosh. 255 section tyres are available in normal tyres as well as runflats.
You can also look at 235/35/19 and 265/30/19 tyres - it's called a "plus one" size but works very well on the 3 series.
Why don't you look at www.mytyres.co.uk and also www.elitedirect.com
The tyres below have all been recommended by various forum members -
Continental 5P
Michelin 5P
Vredestein Ultrac Sessanta
Falken 452
Continentals will be around £820 a set
Vreds around £620 I think
Falkens around £450
      10-23-2010, 12:36 PM   #3
Hotcoupe
Hotcoupe's Avatar
192
Drives: Don't know yet!
Not much to add to Tony's excellent advice apart from you perhaps finding another friend who knows a bit more about tyres and won't try and tuck you up!
      10-23-2010, 01:44 PM   #4
toxicnerve
97
Drives: E92 335d M-Sport
Does doing the "plus one" thing throw out your speedo readings?
      10-23-2010, 02:00 PM   #5
Jeff123
Jeff
318
Drives: 330d M Sport x-drive F30
The inner edge wear seems to be the norm on most cars with runflats. All of mine were buggered when I bought the car (BMW AUC) and I had to change the full set within 3000 miles. It was all down to inner edge wear that I (stupidly) did not realise would be a problem. Many people find that changing to non-RFT cures it, but personally I would also have a 4-wheel laser alignment once the tyres are fitted. I have Falken FK 452's and they are fine. IMO, expensive tyres are just not worth the extra money. OK, on a "track" day, an experienced driver may (or may not) feel a difference - but where can you actually use the performance of the car/tyres during typical driving these days?
      10-23-2010, 02:09 PM   #6
E92Fan
Moderator
E92Fan's Avatar
322
Drives: .
No - actually makes it more accurate (tiny tiny bit) as the OEM sizes (225/255) overread slightly on the speedo
      10-23-2010, 02:20 PM   #7
Jules6
Jules6's Avatar
Drives: F31 330d M Sport
Love my Contis CS3s. 225 & 255 on 19" standard rims. No more crazy inner edge wear, better ride, cheaper, just all round better. Happy days
F31 330d M Sport
Previous Cars: E36 318is Coupe, E46 323ci, E46 M3, E92 325d M Sport
      10-23-2010, 02:38 PM   #8
sow
Thanks for your respones guys, really informative. so just to clear up are the Falkens the best alrounder i.e cost to performance to mileage ratio. I do quite a few miles per year probably around 15k.
If I go "plus one" does that mean I go plus one on the fronts and backs or can I just do EITHER the fronts or the backs. Hope this makes sense!!
Once again thanks
      10-23-2010, 02:48 PM   #9
E92Fan
Moderator
E92Fan's Avatar
322
Drives: .
Once again thanks
Plus one is both front and back
Some people will say the Falkens are the best because they offer cheap price with good performance.
Personally I would go for a higher performance tyre, even though the cost/performance ratio will increase. Those four black rubber circles are the only thing keeping the car glued to tarmac....
That's not to say the Falkens aren't good though - a lot of members on here swear by them so they must be ok, right?
      12-21-2010, 03:58 PM   #10
sow
Hi all
Thanks for all the great advice I ended up buying the plus ones on the Falken 452.
I had them fitted today but what I did notice was the strange wear on the tyres that came off. I took a picture so i'll try and attach it to this post to see what you guys think. I spoke to someone from the service department at BMW and they said it would be more than likely due to incorrect tyre pressure. It just seems a bit extreme for incorrect tyre pressure??
What do you all think?
Anyhow thanks again for your great advice.
      12-21-2010, 04:05 PM   #11
jordylad
Drives: 2007 E93 335i
What a load of bollocks
      12-21-2010, 04:10 PM   #12
sow
Why?
      12-21-2010, 04:19 PM   #13
vblanche
vblanche's Avatar
17
Drives: 2006 E91 330xi auto
wheel alignment?
      12-21-2010, 04:20 PM   #14
jimmylad
jimmylad's Avatar
England
44
Drives: e92 335d sapphire black
my runflats (currently on my other alloys in the garage due to my winter set up) have worn similar although not as bad as yours.
FOR THE LIFE OF ME, I cannot get my head around how a tyre like in the pic you posted could wear like that & keep the car on the road without it feeling or handling strange. Cant be good for rolling resistance to wear like that,
      12-21-2010, 04:32 PM   #15
sow
Tell me about it, I havent noticed any problems in the handling or drifting when going in a straight line. I failed to mention that this was the front tyre. I did attemt to get it laser tracked but the local garage didnt have the tow/toe in tow/toe out readings? for my year car (58 plate). And my local BMW dealer arent that helpfull as anyone from Hull will know all about!!
Do you think it will be worth while getting it tracked?
      12-21-2010, 04:38 PM   #16
chris_s1
36
Drives: M235i 6MT
2012 E92 335d  [8.66]
I switched from 19" Bridgestone RFTs to Falkens, just as you have.
My tyres were similarly badly worn on the edges. I had a full Hunter alignment done at the time as the tyre place (Micheldever - so a well respected place) were convinced the alignment must be shot.
However, they tested it and it was all perfect. The new non-RFT have worn normally since then and are due for replacement soon. They have pretty even wear right across.
So I am sure the edge wear is a property of the RFT. The side walls are so incredibly stiff, I think the rest of the tyre must flex inwards during normal use and the sidewall stays pressed into the tarmac and this causes the wear.
      12-21-2010, 04:43 PM   #17
sow
The guys who fitted the new falkens said they see it all the time just never as bad as mine, to be fair I hardly ever check the tyre presure, this will have to change in the future. BMW recommend checking them every week!
How have you found the Falkens?
      12-21-2010, 04:44 PM   #18
jimmylad
jimmylad's Avatar
England
44
had mine 4 wheel aligned & most of my settings were in tolerance so I asked him to take as much camber out as poss but still leave it in tolerance.
I agreed to go back after 2000 miles to see how they were wearing but 2 weeks after having it done I put my winters on & not checked tyre wear but I doubt I have done enough miles for anything to show.
I will put the runflats back on come the better weather but once they are worn they are being replaced with standard tyres.
search "alignmycar" & see what comes up. Thats what I did.
      12-21-2010, 04:49 PM   #19
chris_s1
36
Drives: M235i 6MT
At first I found them much more spongey and lacking feel compared to the RFTs to be honest. But the increase in comfort and keeping my fillings in place was worth the trade off.
I drive pretty hard and have done a few Nurburgring laps on the Falkens and in the dry they are pretty good. In the wet they are not as good as Conti's. They do lack the feel and precision edge of the RFT's but on a day to day car, the ride is just too harsh to live with.
I still believe they are the best price/performance tyre I've ever used. So I would definately recommend them to anyone.
I'm going Conti's this time because I found a cracking price online, but if I hadn't found that deal, I would definately buy the Falkens again and will probably use them in the future also.
      12-21-2010, 05:07 PM   #20
AlanQS
AlanQS's Avatar
Scotland
243
Drives: Jaguar XE P250 HSE
I still have the 19" Bridgestone run-flats on my car and there is no premature wear on the outside of the tyres, mainly because I keep the tyre pressures correct. Get the tyre pressures correct and you should have no problems.
The same will also apply to your new tyres as the rear wheels have negative camber built in and this punishes under inflated tyres.
      12-21-2010, 05:13 PM   #21
chris_s1
36
Drives: M235i 6MT
Well maybe its different per car or per driving style because I check the pressures at least a couple of times a month and they rarely need adjusting. And the wear we are talking about here is the inner edge and is very hard to see without taking the wheel off.
      12-22-2010, 03:37 AM   #22
m1bjr
LSD - No, you're not seeing things
m1bjr's Avatar
72
Drives: Baby F36 Gran Coupe
You are one of just a few I'm afraid.
As per many others, I'm meticulous with geo and pressures and have experienced very bad inner wear issues.
Owners evidence all over this board proves there is an inner wear issue with these E9x cars on RFT Bridgstones.
I switched to Falken452 and so far cannot fault them. They are ok in wet and very good in the dry and on track.
19" wheels, run flat, tyres
