Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Tyres for 19" Alloys
      12-22-2010, 04:16 AM   #23
Mike in Hampshire
Drives: None at present!
Originally Posted by AlanQS View Post
Get the tyre pressures correct and you should have no problems.
The same will also apply to your new tyres as the rear wheels have negative camber built in and this punishes under inflated tyres.
AlanQS, do you know where to find authoritative tyre pressures for non-RFT's? I'm guessing that the plate on the car door applies only to the OEM Bridgestones?
I've replaced the OEM's with Conti 5P's, and am running 34 front 36 rear after much faffing about - but I've no clue if this is best for longevity (the tyres, not mine!). This is on 19 inch 225/35 and 255/30's.
Mike.
      12-22-2010, 06:12 AM   #24
gaza01
gaza01's Avatar
105
Drives: E92 335i
...thinking about getting the plus 1 size for my 19" rims...you got any pics of them on your car now..do they look any different from the OEM sizes?
      12-22-2010, 07:12 AM   #25
BIGTIME
Drives: E92 M3 DCT - Mineral White
What is the benefit of putting +1 bigger tyres on?
      12-22-2010, 07:19 AM   #26
chris_s1
36
Drives: M235i 6MT
2012 E92 335d  [8.66]
Its hard to say because I went from Bridgestones to Falkens, which will look different anyway, even if they were the same size.
But I would say the going from 255 to 265 does not make much if any visual difference to the tyre on the wheel.
      12-22-2010, 07:20 AM   #27
chris_s1
36
Drives: M235i 6MT
Well the benefit is slightly more rubber on the road.
But the main reason it is discussed here is that Falken do not make a 255/30/19 - so you have to go for 265/30/19 on the rear if you want to switch
      12-22-2010, 11:25 AM   #28
leeadam
leeadam's Avatar
468
Drives: F90 M5 Comp (Evolve Tune)
i currently use bridgestone RFT but will prob get Falkens next i ran them for 5 years on couple of 330 e46 cars i had with 19 inch alloys. they ran great and great value never had any probs with quality of them. and does not throw speedos out on the e46 or e90s.
      12-22-2010, 12:22 PM   #29
SID335
Drives: E92 335I M SPORT
I have just switched to non run flats(yokohama),and they are available in the 19" oem sizes.
19" wheels, run flat, tyres
