BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Photo, Video, Media Gallery, Journals > M4 carbon fiber strut brace and other stiffening parts on F32 4 series !!
proTUNING Freaks
      03-10-2016, 04:44 AM   #23
F30_335
Ukraine
32
Drives: 335ix
2014 335i  [0.00]
Originally Posted by Steve_Jr View Post
Hello. There are 4 stages if you want to install M4 carbon strut brace on F32 4 series.
It is awsome upgrade.
I hope it will not fit on F30. It will safe me lots money
Tr0y118.00
      03-10-2016, 07:28 AM   #24
Steve_Jr
457
Drives: M340i
2014 BMW 428i  [0.00]
F32 and F30 have the same engine room .. Why not on F30 ? haha
      03-10-2016, 08:40 AM   #25
613Bimmer
613Bimmer's Avatar
106
Drives: One car with good steering ;)
Aaaannd there goes his wallet.
      03-10-2016, 10:36 AM   #26
F30_CH
F30_CH's Avatar
Drives: 2014 F30 335i 8AT
Wow, Looks great man! Nice write up
      03-11-2016, 05:25 AM   #27
F30_335
Ukraine
32
Drives: 335ix
2014 335i  [0.00]
M3 and M4 has longer hood than F30. Maybe there is some diferent in engine room?
Not sure if N55 will fit with carbon strut.
      03-11-2016, 06:43 AM   #28
Steve_Jr
457
Drives: M340i
Engine room size exactly same ... no interference .. Only thing why M4 has loger hood than F30/F32 is that front bumper is expanded 30~40mm more than F30/F32 ...
      03-11-2016, 07:27 AM   #29
Steve_Jr
457
Drives: M340i
Mount covering finished ...
      03-11-2016, 08:05 AM   #30
G30 B58
Pace Car Driver
1548
Drives: '22 AW G30 B58 M-Sport
Well done.
Shame this DIY is buried in here though.
      03-11-2016, 06:03 PM   #31
JV973
JV973's Avatar
Drives: 2021 M2C HS DCT/MPE
Awesome
2021 F87 M2C HS DCT/MPE (Nov 2020 - Present)
2018 F32 440i MR/CR MPPSK (Mar 2018 - Nov 2020)
2014 F32 435i EB/CR (May 2014 - May 2017)
2011 E92 335is AW/CR (Nov 2010 - Nov 2013)
2008 E92 328i JB/BL (Feb 2008 - Nov 2010)
      03-12-2016, 07:44 PM   #32
Steve_Jr
457
Drives: M340i
[Quick update]
When you try installing alloy strut brace, you couldn't find any tightened nut assembled with the strut through the edge hole .. (Only M4 has this blind rivet nut)
I found yesterday what I need to add for tightening. You need to order below screw and rivet nut
Fillister head screw M10 (alloy SB - edge) 34Nm 2EA : 07147162464
Blind rivet nut, flat headed 2EA : 51718065070
      03-17-2016, 09:16 AM   #33
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Stage 1 M4 Support bearing reinforcement ring
Stage 2 M4 Alloy center strut brace + M4 support bearing
Stage 3 M4 Carbon (CFRP) strut front end
Stage 4 M4 Extension suspension cross brace + Diagonal strut
My 2014 428i (N26) already has Ohlins R&T MP00 suspension and M4 genuine 437M wheel + PSS 235 / 265 tire. Currently Stage 3 completed .. Enjoy !!
Steve
Great write up and photos.
How much disassembly of engine bulkhead plastic trims and fittings was required to install stage 2 alloy brace ?
Thanks,
BP
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI..
      03-17-2016, 05:18 PM   #34
EYC.M3
Drives: ///M
Never expect that will fits, wonder if aftermarket intake will fit in there without any clearance issue.
      03-17-2016, 05:38 PM   #35
GetYourWheels
Drives: F10
That looks badass!! Great job with the retrofit, love it!
      03-17-2016, 07:22 PM   #36
Steve_Jr
457
Drives: M340i
Originally Posted by Bee Pee View Post
Steve
Thanks,
BP
Yes you need to change plastic trim ... not too much ...
below items must be moved to stage 2 .. It's my bad ..
Cover, windsheild panel, Left : 51718059699
Cover, windsheild panel, Right : 64318059697
Engine hood sealing, Left : 51768058561
Engine hood sealing, Right : 51768058562
Expanding rivet 6EA : 51118174185
      03-17-2016, 07:27 PM   #37
Steve_Jr
457
Drives: M340i
If you remove original holder ... it looks fine ...
      05-09-2016, 05:55 AM   #38
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Hi Steve,
For stage 1 - What bolt torques for 3 x m10 bolts into top mounts ?
Cheers,
BP
      07-06-2016, 02:41 PM   #39
tvaliullin
Drives: F30 328iX
Hi Steve!
Can you please post a photo of Stage 4 you did?
I can not realize where must 31122284857 and 31122284859 be placed? (3 and 4 on the picture)
      07-09-2016, 10:30 AM   #40
Steve_Jr
457
Drives: M340i
Originally Posted by tvaliullin View Post
Hi Steve!
If you want to tighten 3,4 into body, you need to drill your body what you wouldn't do that. So, I used rubber bushing to body side for absorbing shock from strut .. ^^
      07-23-2016, 08:44 AM   #41
Lancelot
France
568
Drives: 2017 m550i
Hi
Thanks for this tutorial, I think I'm going to give it a try too.
Was the replacement of the struts support with 31302284702 absolutely necessary? I can't see where this would be a problem to use the original F30 part?
This seems to be the most annoying part to manage with the necessity to remove the shocks etc. if I can skip it I'll go ahead.
Thanks!!
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i
      07-24-2016, 02:01 AM   #42
Lancelot
France
568
Drives: 2017 m550i
Got it now, required to bolt the alloy strut brace on.
I need to understand if I can change these without dismounting the entire wheel etc, first time for me.
      08-16-2016, 06:43 AM   #43
sdjro
Romania
27
Drives: BMW F82
I was quoted:
stage 1 : 212 euros
stage 2 : 601 euros
stage 3 : 995 euros
Maybe i will make stage 1 and 2, because Engine hood sealing left and right are not available.
Can you please tell us more about handling, how is it now, after installing the cfrp strut what is the difference?
      08-17-2016, 07:53 AM   #44
Stlthnmrdrd
1-800-STOCKAF
Drives: G30 520i (Stock)
Is stage 3 possible on f30? I feel like intake will get in the way
