BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > General M3 Forum (E90 + E92 + E93)
BPM
      04-13-2024, 11:32 AM   #1
Hololand
Drives: E92 M3
E92 M3 2011 30k Mile: Electrical Issues?!
Hello everyone, Firstly I would like to apologise if this is being posted in the incorrect location, If so please do point me in the right direction!
I have had my E92 M3 for just around a year now, It's been a dream to daily, But a couple weeks ago I stumbled into my first problem(s).
Some Context
Car Model: E92 M3
Year: 2011
Mileage: 34,000 Miles
Mods: Suspension Lowered to Comp Spec / Otherwise Stock.
Service History: FBMWSH
Last Full Service: (04/2023 - Oil, Filters, Spark Plugs)
Last Service (04/2024 - Oil, Filters) (Issues started before this)
Storage: For the majority of its life, the Car has been stored in a climate-controlled Garage, Except for the last year, where it has been stored in a multi-storey car park.
The Problem
A couple weeks ago I was driving and an "FTM System error" popped up accompanied by the ABS light.
The first guy that looked at it just cleared the faults and told me nothing was wrong with the car.
1 week later the same light popped up, Alongside the other orange warnings seen pictured below. Then not long after, whilst driving the red Safety / Restraint System warning popped up. See the attached images. Turning the car off and on again clears the read restraint / safety system warning and it usually doesn't pop up again for a couple days.
I also occasionally am getting the engine start fault? Idk what that is, but the car starts just fine.
Diagnostics
I took the Car to BMW to get diagnostics they reported the following issues:
- Restraint System Fault (Intermittent and not present for them during diagnosis)
- Remaining Warnings they say are due to a faulty wheel speed sensor
- They also had reported misfires but the Spark Plugs are a 1 year & 4k miles old. And the car Starts / Idles and Drives just fine, No change in driving. (They recommended new spark plugs until they found out it was under "parts" warranty and suddenly changed their tune suggesting I don't need them......
What Have I tried?
Clearing the faults, but they all returned within a week.
Well, considering all issues popped up in a short space of time and the battery was old, Compounded with the new Dashcam I had just installed. I figured the Voltage might be too low and got a new battery fitted.
This does not seem to have solved the problem, and the faults still persist.
Next Steps?
Not really sure, Which is why I am coming here for help.
I think the next logical thing to do, Is replace the wheel speed sensor BMW things is causing the problem.
Following that, I can only think that it might be some bad wiring somewhere?
Any suggestions?
      04-14-2024, 02:10 AM   #2
gillara
gillara's Avatar
Drives: 2011 E90 M3 Comp
May be TAs on their way out.
      04-14-2024, 08:00 AM   #3
nick3753
nick3753's Avatar
1020
Drives: 2012 e92 M3 DCT ZCP
2017 Audi S6  [0.00]
1997 BMW 328i Touring  [0.00]
2012 BMW M3  [0.00]
Without the actual codes pulled, it’s all complete and utter speculation. Sounds like your best bet is to just let the shop do their thing.
BP709230.00
      04-14-2024, 09:00 AM   #4
Ajolives
Ajolives's Avatar
922
Drives: E90 M3
2019 Audi SQ5  [0.00]
2008 BMW M3  [0.00]
This happened to mine a couple years back, the wheel speed ABS sensor did the trick.
It’s a very easy install if you have time and some basic tools.
      04-14-2024, 09:05 AM   #5
UPSROD
Drives: 2013 E92 M3
2013 BMW M3  [10.00]
Many times multiple error codes are a battery going bad!
DRLane3990.00
      04-15-2024, 11:19 PM   #6
BP709
BP709's Avatar
230
Drives: BMW F97 X3m, Harrop E90 M3
Post the actual fault codes. Nobody can even begin to assist you without them.
      04-16-2024, 01:43 AM   #7
omgzirra_exe
omgzirra_exe's Avatar
Drives: 4.4L M3, IS300
FRM took a shit. couple gbp to repair if you have some one in the UK that can do it.
Build: ZillaSpec M3 N1 Build
M3Post Track General Discussion: Discord
#fakeGTS
m3post
