BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30 328i 335i Front Kidney Grill / Grille removal and replacement DIY
Studio RSR
      11-29-2012, 03:03 PM   #45
Joshhleee
///M Enthusiast
Joshhleee's Avatar
Drives: '12 F30, '15 x5 5.0, '15 M4,M5
Originally Posted by TTyza View Post
Anyone know of a good site to purchase matte black kidney grills for the F30? Also would prefer the full plastic ones not painted so that they dont chip!
Thanks
buy it from europeanauto source or you can buy it from ind directly but its more expensive.
      12-18-2012, 08:18 AM   #46
j.c
Hong Kong
36
Drives: F30 328i
thanks for sharing it!
      12-25-2012, 08:14 PM   #47
Hoody335
Drives: Black 335i xDrive '13
This was awesome, well done changed my grills in 10-12 minutes easily my first time doing it!!
Black on Black we call that murder
      12-26-2012, 03:43 AM   #48
AWMSPORT
1ST CLASS AWMSPORT
AWMSPORT's Avatar
Drives: 13' 328 MSPORT
Originally Posted by 1.fresh.f30.335
Hey guys,
This is a quick guide to removing and replacing your kidney grills.
Estimated Time: 15-20 minutes
Tools Necessary:
T20 Torx
T30 Torx
small flat head or pick tool
Steps:
1. Locate the rubber hood seal at the front of the engine bay.
Attachment 703162
Attachment 703163
2. Remove the seal, starting at a side will make it easier.
Attachment 703164
3. There are going to be 8 screws (6) T30 torx and (2) T20 torx which need to be removed. A T20 torx screw is located over each headlight
Attachment 703165
Attachment 703166
Attachment 703167
4. Now that all 8 screws are removed, the bumper cover should slide forward. Be careful and make sure to pull straight forward rather than up as there are 4 metal clips which hold the bumper in place which would break.
Attachment 703168
Attachment 703169
5. The bumper cover is flexible to a reasonable extent, allowing for a hand or tool too fit behind the grills. Moving away from the center of the bumper allows for more flex, anyone with big hands would probably find it easiest to start on the outside and work inward.
Attachment 703170
Attachment 703171
6. Now using the flat head or pick tool press the release tabs on the grill while gently pulling on the grill from the outside, there are 3 clips on both the top and bottom of the grill as well as 1 clip on each side.
Attachment 703172
Attachment 703173
Attachment 703174
Attachment 703175
Note: the bottom clips are going to require using your hand rather than the screw-driver because they face the ground.
Attachment 703176
7. Once the first grill is free of the bumper you can easily access the other grill... Don't be impatient and pop a new grill in before having both sides removed, it makes more work for yourself.
Attachment 703177
Attachment 703178
8. Now just gently push the new grills into place, run your hand around the gloss black trim piece to ensure all the clips are secured
*use a microfiber cloth if you don't want fingerprints*
Attachment 703179
9. After the new grills are in place, line the metal clips up with the bumper cover, and then slide it back into place.
Attachment 703180
Attachment 703181
Attachment 703182
10. Once in place replace all 8 screws and prior to tightening them ensure that the bumper cover is even, I did this by comparing two of the outermost points.
Attachment 703183
Attachment 703184
I also repeated this procedure on the rubber seal using the outermost T30 screws as reference points, its not necessary but always helps to keep the car looking it's best.
Attachment 703185
Attachment 703186
I hope this helps answer any questions and Good-luck!
Works like a charm...but the only small issue I came across was that when putting back the front bumper if you don't align them exactly , you can see either more or less, or completely uneven gap.
My suggestion is to take a picture, or mark the exact spot with a small dot (sharpie) and of the gap for the hood line before you start..
great DIY !!
'13 328i MSport, AW, Black Dakota leather, Premium Pkg, xenons, ///M Perf, side skirts,Front Lip, Fully coded, CF roundels, Matt Black Grillz, Painted reflectors (front & rear) Smoked tail lights, Plazma l.E.D White PY27W front turn signal,trunk spoiler, Matt Black roof, 8K D1S HID,Custom Exhaust,!
Soon:
JB4,DP,H&R sports,rear diff,!
      01-05-2013, 07:28 AM   #49
BJWDekker
BJWDekker's Avatar
Netherlands
Drives: BMW F30 320dA
Thank you for this excelent photo guide!
      01-09-2013, 01:14 PM   #50
1.fresh.f30.335
Drives: 2014 535xdrive M-Sport
Thanks for all the appreciation guy! I'm glad I could help. I'm going to throw up a DIY on springs, a 335i downpipe, wheel fitment and a how-to on vinyl wrapping by the end of May... Sorry for the delay but she's in storage for the winter, and yes I'm very sad, very very sad.
'12 335i Sport Apline White w/black... Totaled
'14 535i xdrive M-Sport Carbon Black w/Mocha Nappa
      01-09-2013, 05:18 PM   #51
lokito
lokito's Avatar
Puerto Rico
Drives: 335i ///M Sport
I'm definitely looking forward for these DIY threads....
2013 335i ///M-Sport |6MT|Mineral Grey|DHP|PDC|HK|
      01-11-2013, 06:33 AM   #52
hav2flynow
Drives: 2013 Mineral White 328i Sport
Awesome man.. That was easy.. Thanks for the detailed info.
      01-11-2013, 07:49 PM   #53
Travel4surf
Travel4surf's Avatar
13
Drives: code F10
This is crazy! Just peal the sides with your finger tips and pull out!
It literally only took me 30 seconds to replace each one....
      01-13-2013, 10:56 AM   #54
1.fresh.f30.335
yeah, there are a dozen ways to skin a cat... I didn't pull them out like you did because I was afraid to break a clip, don't get me wrong its diffidently faster but idk if I would do it.
      01-13-2013, 12:42 PM   #55
hav2flynow
I agree.. I was afraid to break a clip. And i did not see a good way to put my fingers in there.. My E90 was easy like that but this is very different. But I enjoyed the task of taking off the front end anyway.. Only took 15 Min and i was not in a hurry.
      01-21-2013, 06:54 AM   #56
Who?
Who?'s Avatar
Australia
485
Drives: F87 LCI
that was alot harder than expected, lol you guys make it out to be a walk in the park lol
its not difficult per say, its just really time consuming, and took alot more force than expected. Also for future modders, the bottom clamps are impossible to get to with a tool, just use your hands
but here is the result!
I think it goes great with my black number plates too
itll do me well until I get my m-sport bumper retrofit!
thanks guys and good luck
So far: 200cell downpipe, custom exhaust, lifhtweight splitter, m4 comp seats
      01-21-2013, 03:41 PM   #57
1.fresh.f30.335
was it really that hard or are you just not very handy, haha just kidding. I like the look
and even though I wrote the thread I used my fingers to pop the lower clips, I agree that there is some finesse necessary.
      01-21-2013, 03:59 PM   #58
Who?
Who?'s Avatar
Australia
485
Drives: F87 LCI
Not handy at all, it's literally my third time with a screw driver and my first using a torx(?) screw
It doesn't help that my fingers are short and fat lol
      01-21-2013, 08:45 PM   #59
willibn
Drives: 2013 335i 4dr Sport Red/Black
I managed to do this without detaching the bumper... small hands, patience, and a bit of creative juice and the job was complete.
      01-28-2013, 05:45 AM   #60
KellerKiller
KellerKiller's Avatar
Drives: 335i M, EBII, mit alles
I would suggest against trying this in the cold. It's been in the 20s for a few weeks here, and I couldn't get the bumper to pull away nearly as far as in the guide... Barely able to wedge a flat head screwdriver down on the outside edge, and then the damn tab was too stiff to get it out. lol I'm just going to cut my losses and have the dealer do it. Then, if they dork it up it's on them and not me!
      01-28-2013, 06:05 AM   #61
mikew2069
mikew2069's Avatar
413
Drives: F30 335i MSport
I had this same problem and it wasn't cold outside at all. I endedup using this metal tool I have that was included when Santa brought my kid's trampoline. It has a little hook on the end to stetch the springs. I reached in from the front of the grill and pulled each of the tabs. It was so easy - no need to undo the top of the front bumper if you have a tool like this one.
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
2016 F15 50i ///M-Sport
BM3/H&R/Borla
      01-30-2013, 01:15 PM   #62
UhhItsANT
Drives: 2013 BMW 335i
2013 BMW 335i  [0.00]
what was the weather when you did it. I am in california. I tried then morning... wont budge... fingers hurt now... its about 55 deg F. outside.
      01-30-2013, 02:49 PM   #63
mikew2069
mikew2069's Avatar
413
It was probably about the same - 55-60ish. I'm tellying you, you just need to get some sort of a tool that has a little hook on the end and reach in from the front of the grill and just pull on each of the clips from the front.
BM3/H&R/Borla
      01-30-2013, 04:00 PM   #64
UhhItsANT
i bought a mini pry bar thats fits in there but man it still hard...
      02-08-2013, 05:13 AM   #65
btinl
Drives: '15 F32, '14 F25
Has anyone had a problem just pulling the grills out? The e90 grill swap was so easy that way.
      02-08-2013, 07:27 AM   #66
Who?
Who?'s Avatar
Australia
485
Drives: F87 LCI
youll snap something, its adjusted top, side and bottom..
3 series f30, 3 series f30 forum, 3 series forum, 3-series forum, bmw 3 series f30, bmw 3 series forum, bmw 3-series f30, bmw 3-series forum, bmw f30, bmw f30 3 series, bmw f30 3-series, bmw f30 forum, diy f30, diy guides f30, f30 3 series, f30 3 series diy, f30 3 series diy guide, f30 3 series forum, f30 3 series grille, f30 3 series grilles, f30 3-series, f30 3-series forum, f30 diy, f30 diy guides, f30 forum, f30 forums, f30 grill, f30 grill diy, f30 grille, f30 grilles, f30 grills, f30 kidney grille, f30 kidney grilles
