BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > "Connect USB device with correct activation code to start guidance"
Extreme Powerhouse
      11-30-2020, 03:06 AM   #1
adeelhussain1987
Drives: BMW 330e 2016
Hey all
Bit of help please?.
I got a 2016 330e. The Navagation year was 2016 so was never updated, regardless was working absolutely fine.
I was coding it using Bimmer-Code (wanted the mirrors to fold when i lock the car) which the nav worked fine after so I dont think the coding it corrupted it.
At the same time i got BMW connected drive to de-register the car of the previous person and register it to myself so I can use the BMW app. I believe once they done this the Nav stopped working, it now gives the error "Connect USB device with correct activation code to start guidance".
So I spoke to connected drive several times and they said they will try to send a map update but nothing came through, then they said they will speak to BMW in Germany to see what they can do and then lastly they just resorted to take it to a dealership to have a look at.
I didnt have time to take it to a dealership as I was moving houses. So one night i had a few hours free so paid for the newest version of the maps from ConnectedDrive (£99), downloaded this and put on a FAT32 USB stick with hope that this will fix it. I go the Activation Code for the maps as well.
When I put the USB into the car i get the following screens:
https://imgbb.com/zWdn6GW
https://imgbb.com/thhbgBF
https://imgbb.com/51WbTq5
https://imgbb.com/bbBhLyp
Any ideas on what I can do now?.
I dont have the activation code on the USB disc as i read in the forums it asks for it and you key it in when it does the update.
Any help would be appreciated.
      12-07-2020, 06:28 AM   #2
Rick4345
Rick4345's Avatar
473
Drives: 2022 WRX World Rally Blue
I'm surprised your activation code wasn't attached to your download.
I would contact connected drive and ask them about it.
Rick
      12-08-2020, 05:16 AM   #3
adeelhussain1987
Hi, would that be why its not working?. the activation code was sent to me by sms.
      12-11-2020, 12:55 AM   #4
steve@codemybimmer
steve@codemybimmer's Avatar
Hong Kong
671
Drives: 2020 G20 320i M Sport
Were you playing around with the HMI settings on HU_NBT2? Looks like you coded it to ID5 Plus Plus or ID6 Lite so it changed the map activation scheme.
CMB Solutions Limited |codemybimmer.ca
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming
steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca
Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs
      12-24-2020, 10:01 AM   #5
adeelhussain1987
Hey Steve
I was messing about with the ID5 and ID6 about a week or so prior to it not working, so thought it might not have been relevant.
I will restore it and see if i can update it then.
Adeel.
      10-19-2021, 12:01 AM   #6
devan_le
Drives: BMW M2
[QUOTE=adeelhussain1987;26962355]Hey all
Hey I am having the same problem with a 2016 BMW 340i and was wondering if you fixed it?
      10-19-2021, 07:16 AM   #7
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Note to devan_le: you didn't put [/quote] at the end of the quoted text, so it doesn't show up as a quote.
      10-19-2021, 11:32 AM   #8
jofri900
jofri900's Avatar
Netherlands
Drives: BMW 3series F31 2016
same here
Same Issue here as @adeelhussain1987. I've been looking around but no solution yet.
Jofri
      10-29-2021, 01:22 AM   #9
teymur88
Azerbaijan
Drives: BMW F30 LCI
Hello. Anyone found a solution?
      11-04-2021, 05:37 PM   #10
Ace Rimmer
Ace Rimmer's Avatar
23
Drives: BMW F32
I believe this comes on the screen due to the internal FSC folder being deleted off the idrive, which can happen after coding, remapping, retrofitting, and ui upgrading.
I think if you contact Gerry at nav codes he could sort this out for you at a price though or course.
Shawn Sheridan would be a good guy to contact on here about it, and he can certainly point you in Gerry's direction, but he would be the man for this job.
By the way, don't bother wasting any money on BMW helping with this, they don't have a clue when it comes down to problems like this, and them sending a map update on usb to you wont solve it.
