Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Did I screw up with 16" Winter Tires?
      11-10-2011, 01:01 PM   #1
Faceofboe
Drives: 328xi Sport Wagon
I have an 2011 E91 328xi Sport Wagon which came with 225/45R17 Run Flats.
I ordered off of Tire Rack smaller rims, 205/55R16 (w/Michelin Primacy Alpin PA3 tires), for my Winter Set for use in Germany and Austria mostly.
Should I have gone with 17" rims like the ones that came with my car? I ask because I can't find anyone on this site that seem to use less that 17" snow tires with their BMW's. Did I screw up my driving experience or make driving in snow worse?
Plus, the guy at a local garage (in Germany) wondered if putting smaller wheels was legal on a wagon with a large engine. (I thought that very strange, but he was an OPEL mech...). He said something about my car registration having to note that I could use smaller tires.
Would appreciate your thoughts.
      11-10-2011, 01:07 PM   #2
Tom K.
Tom K.'s Avatar
Drives: '07 328iT, '13 Boxster
No problem. My '07 328i wagon came with OEM 16" A/S wheels and tires. And 16" winter tires are cheaper and will give better snow/ice performance.
Tom
      11-10-2011, 03:51 PM   #3
Faceofboe
Thanks. That's what I've always thought, go down one size in winter. But, between the posts I've read here and the mechanic weirding me out, I started to get worried.
      11-11-2011, 09:12 AM   #4
wiseweasel
The wisest of weasels!
Drives: Fast!
I am also running 16" winters... just about to go on the car today. Should be fine! BTW, mine came stock with 16's. I am using my factory rims for my winter set.
      11-11-2011, 10:11 AM   #5
Gary@TireRack
Moderator
Gary@TireRack's Avatar
Drives: Formerly 1995 M3
205/55R16 is actually a very common way to go for winter use on 325i and 328i cars. If you'd like to shoot me an email with your Tire Rack order # I would be happy to double check the fitment for you.
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp
Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum.
      11-13-2011, 04:50 AM   #6
Faceofboe
Gary, thank you. I have to say that the TireRack was great. I received all the tires, mounted and balanced within days. They even put the BMW center caps on! I wish I had ordered from them a long time ago. The fitting is perfect, right down to the TPM sensors. I'm just confused about why the mechanic was so odd about having smaller tires.
      11-13-2011, 12:14 PM   #7
Tom K.
Tom K.'s Avatar
I would think that the only issue might be with the speed rating as most of the "studless" winters carry a rating which is well below your car's maximum speed. But since your Michelins are performance snows with a V rating, I'd simply try to avoid that mechanic in the future.
Tom
      11-13-2011, 12:41 PM   #8
merchomini
merchomini's Avatar
Drives: 2011 Touareg VR6
i want to run 16s with snow tires......thats a better setup for winter......i am wondering if 16s will fit over 335i brakes......anyone know about that?
      11-13-2011, 06:28 PM   #9
catch
catch's Avatar
668
Drives: F80 M3
The reason most people on here run 17+ is likely becasue the 335 cant fit anything smaller over the brakes (and some 17s done even fit)
2016 F80 M3 Mineral White/Sakhir Orange
2013 BMW S1000RR Flat Silver <stolen>
2007 BMW E92 335i Jet Black/Jade Grey <sold>
      11-13-2011, 06:42 PM   #10
remmib
General
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
Nope, won't fit.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      11-13-2011, 06:47 PM   #11
ceb
NHTSA Nazi
28
Drives: 335ix
I assume you are military or otherwise under the SOFA (the ordering from Tirerack was a dead giveaway.)
Accordingly, your car does not need to meet the technical requirements in the Fahrzeugbrief for your car (assuming it is Euro spec - you wouldn't have that document if it is US spec.)
The Fahrzeugbrief (the German equivalent of a US title) spells out not only things like tire size but in some cases even approved manufacturers. Any deviation (aftermarket wheels for example) must be tested for that application and an entry made in the document if approved. Some manufacturers will get pre-approvals for certain applications so that no separate entry needs to be made - but the manufacturer's approval document needs to be kept with the car.
It is quite possible that a 16" wheel might require a supplemental authorization if the 328 doesn't come with 16" wheels fitted as standard in Germany. However, the 328 comes fitted with 205/55 R 16 H tires, so your Opel mechanic was wrong.
Long story short - you're perfectly fine on the 16's. The smaller tires will give you superior winter performance and would be the appropriate size for that car in Germany and in the US.
      11-14-2011, 03:20 PM   #12
merchomini
merchomini's Avatar
Originally Posted by remmib View Post
Nope, won't fit.
thats what i figured.....thanks for clearing it up and the quick response tho...
      11-15-2011, 09:47 AM   #13
Gary@TireRack
Moderator
Nope, won't fit.
+1 , no 16"ers will clear the 335i brakes.
      11-23-2011, 09:59 AM   #14
Faceofboe
@Ceb - you got me, I am driving an American spec car. Thanks for clearing up what he was talking about. He did mention the Fahrzeugbrief and I said I didn't have one since it was US spec. It still concerned me though since I had never heard of an issue like that before. Later on I went through the manual ( LOL) and saw the 16" mentioned, with the only difference being an H rating noted in the manual vs. the V on the Michelin Pilot Alpin PA3 XL that I bought.
Thanks again for clearing up the Fahrzeugbrief issue and thanks to the other posters for their responses.
      11-23-2011, 11:58 AM   #15
asus389
asus389's Avatar
Drives: 11 E90 328i
2011 BMW 328i  [0.00]
How do you like the PA3 so far?
      11-28-2011, 03:38 PM   #16
Faceofboe
So far they seem to handle quite well on dry/wet roads. No snow, so I can't speak for that yet. I have noticed that the ride is a lot more cushy than with the all-season run flats that came with the car. The car bounces more on some types of bumps at higher speeds.
      11-28-2011, 07:08 PM   #17
Fatty Duckets
69
Drives: 335is
I ran 16's on my 06 325i in the winter vs. 19's in the summer. The winter 16's were awesome (stock 16's plus general artimax snows).
16", rims, snow, tires, winter
