Go Back   6Post.com | BMW 6-Series Forum > BMW 6 Series Forum > BMW M6 Forum (F12 / F13)
      03-09-2014, 07:30 PM   #45
mr-karim
mr-karim's Avatar
62
Drives: F13 M6 (Fully Modded)
Originally Posted by M6-Coupe View Post
Sounds good
Buddy believe me your car has much more power than most of the cars!
As I told you the other day I could get 0-60 in 3.7-3.8 with stock spec.
I can beat most of the rear wheel drive cars! yours is much faster to avoid you being bored
M6 keeps me interested for now
I should receive this tomorrow
I'll do a few tests to see some real numbers
"The best things in life are free. The second best are very expensive." - Coco Chanel.
      03-09-2014, 07:57 PM   #46
gmd2003
gmd2003's Avatar
352
Drives: 2014 CP M6 and 2006 VT 525 Z4M
Sounds good
Excellent, be sure to get some 60-130mph numbers if possible, it will be nice real world data , which I much prefer over dyno numbers . 60-130 is a great indicator of how fast a car is bc it takes traction out of the picture . Just make sure the slope is as little as possible (flat) and def less than 3% Have fun !
      03-09-2014, 07:57 PM   #47
badblack550xi
badblack550xi's Avatar
Drives: F10 550i 2011 F90 2020 COMP
ADD MS109 BUMP it to +4PSI and hit 650WHP =D
2011 550i RWD 60-130 7.35
      03-09-2014, 10:03 PM   #48
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
Can't wait to see the real numbers! Just make sure to test in a wide area for 0-60 and PLEASE DO NOT TURN OFF DSC!
      03-09-2014, 11:35 PM   #49
mr-karim
mr-karim's Avatar
62
What about MDM?
To be honest we still have a bit of snow on a ground, and most roads are cracked. I'll try to find a good area to test my car 0-60, not sure if I'll be able to find something for 60-130
      03-09-2014, 11:56 PM   #50
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
What about MDM?
I know that horrible weather (I used to live over there for 5 years) and that's why I asked you not to turn off DSC.
In fact you cannot get a good number if the DSC is ON because it cuts the engine and applies brake due to too much power and torque release at hard acceleration. Turning the DSC off and using launch control is so dangerous in the area you live. DON'T DO IT PLEASE. I highly recommend you to wait until the weather getting better and test it with MDM first in a wide area and nobody around!
      03-11-2014, 06:05 PM   #51
Boss330
Boss330's Avatar
1715
Drives: BMW
Ya man, too bad I couldn't get an exact number
But it's still a little higher number than Manhart's 700hp crank m6, and that thing dominates; overall, I'm pretty happy.
I'll show off some new stuff I got installed yesterday, very soon
M-bituous did 660whp on his Manhart M5...
      03-11-2014, 06:42 PM   #52
gmd2003
gmd2003's Avatar
352
Bc Manhart has a tune to allow more fueling and less timing to go along with the higher boost . The BMS is essentially just the Manhart boost control unit for a lot less money . Crude but effective to a point . The OP will end up making ~ 630 whp on 94 octane when he turns his boost back down to 2.5 psi . The extra 30 whp is not worth what Manhart is charging for almost the same tech with a dev file .
      03-12-2014, 02:43 AM   #53
Boss330
Boss330's Avatar
1715
Drives: BMW
So I dynoed my car. The car did show over 600WHP with no problems, but after 6000rpm a computer in my car started thinking that it was doing a burnout, therefore it didn't spin any further (fuel cut early).
To get an exact number, I'll have to bring it to AWD dyno... Estimate is 650WHP.
Yes the traction control was off.
I am using 94 octane.
Charts: (1tun with pedalbox off, 2 runs with pedalbox on)
Looking at your graphs it really seems to have serious issues in the midrange especially...
Your engine makes 475lbs.ft at 4600rpm. The stock engine in post #21 makes a nice and steady 500lbs.ft from 3k to 5k and then gradually drops to 400lbs.ft at 7300rpm http://www.6post.com/forums/showpost...5&postcount=21
A Manhart M5 on the dyno here: http://f10.m5post.com/forums/showthread.php?t=830347
It has 650ft.lbs at 3k and drops slightly to 630ft.lbs at 5k and falls gradually to 460ft.lbs at 7200rpm.
In the midrange the Manhart makes a whopping 150-175lb.ft MORE than you do (35% more)... Your engine even makes less torque than a stock engine (although comparing results from different dynos doesn't provide a definite answer on this). Anyway, the shape of your torque curve is not right for the S63 engine...
Here is how the dyno graph is on a BMS Stage 1 M5 (and how it is supposed to be...):
http://www.n54tech.com/forums/showthread.php?t=22393
Please listen to gmd2003 and others that have pointed out a possible knock situation. Something really isn't right in the midrange there... Don't risk your engine!!!
      03-12-2014, 03:30 AM   #54
Boss330
Boss330's Avatar
1715
Drives: BMW
Originally Posted by gmd2003 View Post
Bc Manhart has a tune to allow more fueling and less timing to go along with the higher boost.
Which I believe ACS also has via their piggyback. It connects to the ECU connectors on each ECU and intercepts several sensors and circuits. I know they do ignition and fuelling mapping on other models via their piggyback.
http://preisliste.ac-schnitzer.de/ac.../121410710.pdf
http://preisliste.ac-schnitzer.de/ac...10&ID_NR=11548
Not sure what the BMS does? Only boost manipulation?
EDIT:
The BMS connects ONLY to the TMAP sensors and has no control over other sensors/circuits (unlike the ACS piggyback). I would be extremely cautious running more boost on a tune that does NOT control timing and fuelling at all. Keep in mind that the ECU still believes it runs stock boost as well... (the whole point of the piggyback is to manipulate signals to and from the ECU so that the ECU still reads 17Psi even though it has 20Psi boost).
http://www.burgertuning.com/instruct...e1_install.pdf
      03-12-2014, 08:43 AM   #55
mr-karim
mr-karim's Avatar
62
EDIT:
I'll try dynojet soon...
Here's BMS dyno with a high octane
      03-12-2014, 09:29 AM   #56
Boss330
Boss330's Avatar
1715
Drives: BMW
That dyno graph looks more like the BMS dyno graph I also posted. It has a much more consistent torque curve and shows a consistent increase in power over stock due to a slight boost increase and high octane.
Your dyno graph was "all over the place". Either the dyno operator did something wrong, or the ECU was correcting for knock or some other fault it detected. I would suspect the latter explanation as the ECU also shut off at 6000rpm (if it hadn't done so, you might have ended up with a blown engine...).
Did the dyno operator datalog via the OBD port and measure AFR via exhaust etc?
      03-12-2014, 11:41 AM   #57
mr-karim
mr-karim's Avatar
62
To be honest I don't even know this dyno, it's different from others, I think they remove rims before starting the process.
I really wanna try Dynojet.
Also, lowered my PSI to 2.5
      03-12-2014, 11:59 AM   #58
Boss330
Boss330's Avatar
1715
Drives: BMW
Then it's a Dynapack. One of the key advantages is that you eliminate wheel slip as the dyno attaches to the wheel hub. But it can't measure transmission losses, the operator can use a factor to calculate crank hp though.
http://www.dynapack.com/
This shows some of the pitfalls with improper use of a Dynapack and how numbers can be manipulated (not saying any of that happened with you, just posting it as infomation):
http://www.s2ki.com/s2000/topic/6490...e-should-know/
      03-12-2014, 12:38 PM   #59
LSM
LSM's Avatar
1118
Drives: 2024 Porsche 911 GTS Cab
I would turn that boost down. That curve looks messed up. You only made 10 more HP than me but all through the middle of your curve I made much more hp and torque than you. As you know my car is basically stock with all you have on there should be way more than 10hp more I would think. Be careful
Lou
2024 Porsche 911 GTS Cabriolet
      03-12-2014, 05:33 PM   #60
Boss330
Boss330's Avatar
1715
Drives: BMW
Did you do the runs in 5th gear? Then you hit the 155Mph limiter at around 6000rpm...
And according to a thread on the M5 forum, +3 PSI setting on the BMS in reality equals +4 PSI on the S63 due to different TMAP sensors on the S63 compared to the N63 that the BMS was developed for...
So if you were told it's ok to add 3PSI of boost that isn't the same as choosing +3 on the BMS interface!!!
      03-12-2014, 05:53 PM   #61
AlphaAlpineM6
AlphaAlpineM6's Avatar
Drives: 2014 BMW M6 & 2012 AMG CLS63
do you have any literature on the "pedal box" ?
2008 M3 Sedan + catless + Tune
2012 CLS63 AMG
2014 M6 Coupe + catless + KW V3
2015 Porsche GT3
, 2015 M3, all stock, 1/1 Space Grey
      03-12-2014, 05:54 PM   #62
AlphaAlpineM6
Lou
Totally against tuning..
2012 CLS63 AMG
2015 Porsche GT3
      03-12-2014, 11:00 PM   #63
mr-karim
mr-karim's Avatar
62
Yup 5th gear, might be the limiter. Definitely need to do more tests to find the perfect PSI level.
To be honest man, don't get it for m6, your pedal will become WAY too sensitive, very hard to drive with the pedalbox on. It was fun on 750i, as it had a less sensitive pedal...
Pedalbox is something like spring booster.
      03-13-2014, 08:27 AM   #64
mr-karim
mr-karim's Avatar
62
A little tease
Should be done later today
      03-13-2014, 11:33 AM   #65
RichardP
51
Drives: E39 M5 & M6 Gran Coupe
2013 BMW M6 Gran Coupe  [10.00]
1980 E26  [10.00]
2003 BMW M5  [10.00]
No love for Sakhir Orange then.
      03-13-2014, 01:12 PM   #66
mr-karim
mr-karim's Avatar
62
I get bored fast, maybe I'll rewrap it in blue later on
akrapovic, ams downpipes, bms tune, m6 dyno
6post.com
