Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Procede v5 User Maintained Owners Manual
      12-22-2010, 11:19 AM   #23
secretsquirrel
secretsquirrel's Avatar
130
Drives: f80
This is great guys. Can we add an accompanied page for documentation requests? For instance; I'd love to know what the different color lights on the dash mean when I start up my car. I'm sure others would have other requests. I could see something like this building into an FAQ. This would allow Shiv and company to stop responding to petty questions and focus on making the product better.
      12-22-2010, 11:25 AM   #24
AltecBX
AltecBX's Avatar
Drives: BMW 335xi Sedan; BMW M3 ZCP
2018 BMW M3 ZCP  [0.00]
2007 BMW 335Xi  [0.00]
That's why I started this - PROcede v4|v5 / User software Wish List
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps)
†Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec
AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS
      12-25-2010, 01:34 PM   #25
Joshboody
Drives: pickemuptruck
sometimes, but not all the time, the car will beep beep (similar to shift notification) on start up and only once so far when turning the ignition off. Anyone notice this? What does it mean? Thanks
      12-27-2010, 07:24 PM   #26
Presidio335xi
Drives: 335xi coupe
This is the best x-mas gift. so straight forward. thank you
2017 F82
      12-27-2010, 09:50 PM   #27
azwillnj
318
Drives: 2023 M340i xDrive
EDIT 12/27/10: New PDF outputted, added google spreadsheets for n54 and n55 CAN DME Codes. Note, the n55 CAN DME Code list is currently being populated, please check back for updates.
See OP for new links and PDF.
Current: 2023 G20 LCI M340i xDrive
History: 2005 E90 325i > 2008 E90 328xi > 2011 E90 LCI 335i xDrive > 2013 F30 328i xDrive > 2016 F30 LCI 340i xDrive > 2020 G20 M340i xDrive
WE ARE!
      12-28-2010, 12:29 AM   #28
usc335
Drives: '21 M2C, '08 E92 335
Please add the following information to the users guide:
(1) General Command Center Descripition:
http://www.e90post.com/forums/showthread.php?t=427976
(2) Boost Response:
http://www.e90post.com/forums/showthread.php?t=435393
(3) Autotuning Basics:
http://www.e90post.com/forums/showthread.php?t=419045
(3a) Autotuning Logic Overview (Shiv wrote this in some post somewhere):
AUTOTUNING BOOST & IGNITION CORRECTION EXPLAINED:
Traditional tuning involves finding the right compromise of ignition advance and boost. Basic engine theory suggests that you want to have maximum air/fuel charge expansion (during combustion stroke) at approx 14deg after TDC. So that involves initiating the spark at the right time (correct advance value). However, in the case of a turbo engine running on pump gas, the ideal spark advance isn't possible due to octane limitations (ie, running the "correct" advance will cause detonation).
Another way to look at it is recognizing that turbo engine tuning is all about managing the trade off between thermal efficiency (timing) and volumetric efficiency (boost). You can have one very high and the other very low and get poor results/low power. The key is to get them both in their respective sweet spots. In doing so, you get the most power with the greatest safety margin.
In the case of Procede AutoTuning, ignition timing changes are first applied to see how efficienty the engine is burning. The Procede calculates this by seeing what timing values are needed to achieve a knock-free combustion. If the max-load timing value is deemed too low (inefficient combustion), boost is gradually lowered. Conversely, if the engine is running a high knock-free ignition advance value, the Procede attempts to bump up boost (and raise volumetric efficiency) and make more power. While under boost, the Procede is always monitoring the ignition trims that the DME is applying. And it bases its decision on their dynamics. Same stuff I would do when custom tuning a car for any given condition. But the Procede is always doing it.
The AutoTune learning conditions have changed. There is no lower RPM limit however. It will activate at any time, regardless of RPM. But there are several over conditions that need to get satisfied. And there are a bunch of "dynamic" conditions implemented as well. Which means that it will not learn to run higher boost (at higher engine speeds) until the engine actually sees and "tests" those higher engine speeds. So simply doing at 3000-4000 pulls on, say race gas, will not get it to ramp up boost to high boost levels. Instead, the car will actually have to drive through the engine speeds that have the higher boost targets. It's exceptionally cool and way more advanced than the ignition correction-only AutoTune logic we had introduced earlier. It needed to be since boost was not in the mix.
(4) AFR Display Info:
This value displays on the oil temp gauge (when this display mode is selected). The minimum reading indicates 20:1. The maximum is 10:1. Which means the middle reading is 15:1 or approx stoich. Very simple and self-explanatory. This gauge displays the leaner of either bank1 or bank2 AFR readings. So it's very helpful in diagnosing a bad or flaky o2 sensor. Or a failing fuel pump. Or, in the case of upgraded turbos operating at high boost, running beyond the limits of the stock fuel system.
Question: Why does AFR appear to go lean sometimes when transitioning from cruise to full throttle?
Answer: Those lean spikes are caused by the voltage bias the procede applies to the wideband sensors. It is, in effect, telling the DME that the engine is operating leaner than it really is. Which makes the DME add the desired fuel enrichment. The period between this perceived condition and the DME response can take a second in some cars/software with certain DME software versions. You'll see this effect most obvious in the 3500-4500 rpm range where we apply the biggest bias/fuel correction. If you put an actual wideband on the car, you wouldn't see the same lean spike at boost onset. Hope that helps clear things up.
Thanks!
      12-28-2010, 01:27 AM   #29
OpenFlash
Drives: A Lot
I made a few edits in the user manual today. Few more to come over the next few days.
      12-28-2010, 05:02 PM   #30
Ulrich
Ulrich's Avatar
Mexico
Drives: BMW 328i 2014 8AT
Great. Is there a place where it describes in detail How to operate Launch/Traction Control in the V5?
      12-28-2010, 06:36 PM   #31
azwillnj
318
Not yet, I am planning on adding that as soon as I have time to go through the multi-page thread about it... hopefully by the end of the week.
Alex.
WE ARE!
      12-29-2010, 06:41 AM   #32
yitbos1
Drives: 2013 E92 M3 Le Mans Blue
Removed. I asked to add something that was already there.
      01-05-2011, 03:24 PM   #33
**335i**
**335i**'s Avatar
Switzerland
185
Drives: TOYOTA & 2008 E92 335i 6MT
2008 335i  [9.00]
codes taken from here http://www.vishnutuningforum.com/viewtopic.php?f=2&t=22 ???
E92 335i Black Saphire 6MT PROcede V5, BMS DCI, Big Tom IC, AR CL-DP's 3", AR Design OC, Forge DV's, OEM M3 side skirts, BMW Performance Wheels 19 inch 269 Black Gloss+Continental ContiSportContact 5P (400hp and 550nm) https://www.youtube.com/user/aistis7..._as=subscriber
      01-08-2011, 03:44 AM   #34
shockin330i
shockin330i's Avatar
798
Drives: 2016 ZCP M3
I hear this too....
ERnie
2016 BSM/f80/ZCP
      01-09-2011, 05:09 PM   #35
adrianBMW99
adrianBMW99's Avatar
Drives: BMW
So does anyone have an N55 DME code listing? Or at least more codes than are listed in the user manual? In addition, if you trigger some sort of serious code and accidentally clear it, would it return to signify a potential problem with the vehicle?
      01-09-2011, 05:20 PM   #36
shockin330i
798
Drives: 2016 ZCP M3
What code have you been getting?
ERnie
2016 BSM/f80/ZCP
      01-09-2011, 06:03 PM   #37
adrianBMW99
Drives: BMW
Well none right now, but I did have a certain issue. I was driving at a higher rate of speed with V5, full throttle and all of a sudden the car showed the half engine light, transmission limp mode, traction light, brake light and went into limp mode. I restarted and everything was fine, so maybe I just overheated the transmission or something. Then I had an SES light that remained on which I had cleared. I returned home to read codes and none showed up, maybe nothing was wrong or maybe I accidentally cleared the bad codes. But you would think that any bad codes would return, right?
      01-09-2011, 06:24 PM   #38
shockin330i
798
Drives: 2016 ZCP M3
This happened to me today as well. I was going from 3rd to 4th, shifted around 6krpm and Bing, dong, christmas tree lol. Pulled over cleared the codes, but the service engine soon light stayed on for awhile. Damn thing wouldn't clear. I finally pumped the gas pedal twice and it went away..
ERnie
2016 BSM/f80/ZCP
      01-10-2011, 12:17 AM   #39
Tzu
29
Drives: 335i
^ it seems like most of the time that people have the half engine light with the procede, they turn off the car and turn it back on and the problem disappears. As to why the problem occurs in the first place is up to Shiv to enlighten us.
      01-10-2011, 12:34 AM   #40
shockin330i
798
Drives: 2016 ZCP M3
Its already been fixed Well at least it has been so far
ERnie
2016 BSM/f80/ZCP
      01-10-2011, 01:44 AM   #41
**335i**
**335i**'s Avatar
Switzerland
185
2008 335i  [9.00]
its with all n54 and n55?
      03-24-2011, 07:59 PM   #42
Glowin
Glowin's Avatar
Drives: X3 35 & 335i now - M2/M4 next?
Is there any reason Launch Control documentation was left out?
This is all I've found on it so far, and I'm not clear which maps it's active on:
Originally Posted by shiv@vishnu View Post
To trigger the timing retard during brake torquing (pressing both brake and accelerator at the same time), just press and hold the volume down button on the steering wheel. You will hear the engine/exhaust note go deeper and you will build more boost. A second or two later, let go of the brake and you will take off. When you let go of the volume-down button, the ignition advance will be ramped back in and you will pick up another 50-60lbft of torque over the next 1/2 second. You better have traction when you do this.
shiv
      04-20-2011, 12:43 AM   #43
jvxbimmer
Drives: bmw 335i
nice
      05-20-2011, 05:46 PM   #44
firechicken99
Drives: Black '07 335i
This happened a month or so ago a couple of times while in the same situation, prob around 4th gear or so between 100-130mph would redline and shift gears and then limp mode and engine light. Apparently it was a "Misfire"......
however turn the car off and back on and Viola! SMH
regardless i love my procede, and just got back my v5., wheres my beer, time to install
