10-19-2023, 05:43 PM | #1 |
204
Rep 175
Door Panel Insert
How easy/difficult is it to remove the leather insert portion of the door panels? I'd like to switch mine out to alcantara if it's not a huge pain in the ass.
10-26-2023, 07:32 PM | #2 |
103
Rep 258
Isn't it glued on or something? I've never tried to disassemble it, just swap the whole thing.
Might be better to use a peel n stick type of product?
-Thumbie
2011 Jerez E90 M3 6-speed Competition Package |
10-27-2023, 12:37 PM | #3 |
204
Rep 175
The leather is probably glued, but the piece it's glued to should be able to come out somehow. It's probably a bunch of plastic welds similar to how the pull handle is attached. The armrest would probably need to come out too, so it's probably more trouble than it's worth. I still might try it though lol
02-29-2024, 12:36 PM | #5 |
13
Rep 30
Bought a door panel to give this a try, and... I'm stuck.
So the door card structure is nothing more than a huge piece of molded cardboard. The insert is leather and padding wrapped around its own piece of cardboard. The board of the insert is flatly adhered to the board of the door card itself. This is where I'm stuck. How do you unglue two pieces of paper product that's been flat glued without destroying one or the other? I've been using a heatgun and trim tools to pry around the edges (which will lift) but not sure how to get them unstuck in the center where I assume the glue is. Now obviously lots of example here of custom inserts so there's a way. I don't know what it is though. Now this is a non-M e90 rear door with leather, but I doubt it's any different on the M. Attached pic show through the speaker hole shows the two boards, adhered together. Last edited by HairTooLongToo; 02-29-2024 at 12:42 PM.. |
