BMW M3 Forum (E90 E92)
  TireRack
      10-13-2023, 10:19 PM   #1101
North.E92
60
Drives: .
Originally Posted by rated_m3 View Post
Does anyone know if 19x10 et18/ 19x11.5 et23 will fit with no issues such as rubbing assuming the tires sizes are 255/35/19 & 295/30/19?? Also, is -2.0 camber all around enough? I’m lowered on swift springs with competition pack suspension. May need slicer for this one! ����
im almost certain u will rub in the rear
the front may clear but honestly you're probably going to rub front and back
      10-14-2023, 11:21 AM   #1102
slicer
slicer's Avatar
2741
Drives: 'E46 M3 Race Car, '23 X7
Does anyone know if 19x10 et18/ 19x11.5 et23 will fit with no issues such as rubbing assuming the tires sizes are 255/35/19 & 295/30/19?? Also, is -2.0 camber all around enough? I’m lowered on swift springs with competition pack suspension. May need slicer for this one! 🙏🏽
Front will work
Rear most likely will rub but I honestly have not tested that specific rear spec because the manufacturer’s max recommended rim width for 295/30/19 is 11”.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc.
INSTAGRAM - @Slicer_M
DrFerry6730.00
      10-17-2023, 07:54 AM   #1103
rated_m3
29
Drives: 2011 BMW E92 M3 ZCP
Originally Posted by slicer View Post
Front will work
Hmm, but Porsche runs a 305 tire on a 12 inch wheel for their GT3. Also, here’s a pic of a 295/30/19 tire on a 11.5 inch wheel.
DrFerry6730.00
      10-18-2023, 10:39 AM   #1104
slicer
slicer's Avatar
2741
Yes, Porsche has exceeded manufacturer's published recommendations a few times. That being said, I would presume that they designed the tires to accommodate (considering that N-spec tires are create in collaboration with Porsche).
You wouldn't be the first person to stretch a tire beyond the recommended limit. That's up to you. The tire in pics looks to be pushed beyond ideal rim width but will you die? No. It just might not perform as well as it could.
'23 X7
      10-18-2023, 11:44 AM   #1105
TigerM3
21
Drives: BMW M3
I second this. I've been running a 305/30 on a 12.5 on my other car for the last 4.5 years with no issues but I drive that car SLOW. I was even worse with the setup before that was a 255/35 on an 11. I'm not doing that when I get wheels for the M3, probably will run a 295 on a 10.5 or 11. In fact it's the exact opposite at the moment since the previous owner slapped 295/35's on the ZCP wheels. Man I'm getting old....
      10-18-2023, 11:45 AM   #1106
omgzirra_exe
omgzirra_exe's Avatar
Drives: 4.4L M3, IS300
yeah the Porsche N0 spec tires are different than what most people on here buy, so it's not really a similar comparison.
in fact, a little stretch is preferred in some cases.
i think the G8X run 285/30/20 on a 10.5 wheel on PS4S star which gives a little stretch.
Build: ZillaSpec M3 N1 Build
M3Post Track General Discussion: Discord
#fakeGTS
      10-18-2023, 03:04 PM   #1107
slicer
slicer's Avatar
2741
I agree with what you are saying. I generally run tires on the max recommended rim width to maximize sidewall support and tread width. For example, 10.5" with a 265/35/18, while many people run that same tire on a 9.5 or a 10. The example you gave with the G8x still falls within the manufacturer's recommended max rim width. But, again, 295 is not meant for a 11.5 wheel (according to the tire manufacturers spec).
'23 X7
      10-18-2023, 04:24 PM   #1108
omgzirra_exe
yah, like im on a V730 275/35/18 on a 10.5 but it's the most efficient tire size too lol and the V730 is narrow.
#fakeGTS
      10-24-2023, 10:22 AM   #1109
M3atman
M3atman's Avatar
69
Drives: 2009 E92 M3
I'm currently running the Essex AP Racing BBK CP9561 caliper/380mm disc
Does anyone know if the Front 19x9.5, ET25 BBS LM-Rs will clear this bbk?
Before I pull the trigger i'm hoping to confirm fitment. I reached out to Essex and they said they "don't know" as LMRs are not on their confirmed fitment list.
TTFS Tune | DINAN Exhaust | Bimmerworld Xpipe | OHLINS Coilovers | Challenge Carbon Trunk | Eventuri Intake | APEX Wheels | AP Racing BBK | Turner Monoball
      11-30-2023, 04:54 AM   #1110
Brandon.E93M3
Drives: Bmw E93 m3 & E36 M3
FORGESTAR f14
Someone pls help
I have a set of Forgestars F14 and I'm trying to get perfect fitment. I would prefer staying on Oem height. I have a BMW E93 M3 08.
19×9.5 et22
19×10 et28
      11-30-2023, 04:55 AM   #1111
Brandon.E93M3
Forgestar f14
Originally Posted by Vegas_Sirk View Post
hey guys I was looking for a aggressive fitment thread, but couldnt find one. If there is already one of these can someone please post a link.
If not lets get this started. Post up photos and specs of the most aggressive offset wheels you have seen
Someone pls help
19×9.5 et22
19×10 et28
      11-30-2023, 01:22 PM   #1112
MineralWhiteF80
Dont listen to me
Drives: F82, E92 M3, G30 M550i, E46
Originally Posted by Brandon.E93M3 View Post
Someone pls help
19×9.5 et22
19×10 et28
It would be easiest to simply install those wheels without guessing on what spacers you would need and just see how they fit. You could probably eyeball the amount that you want to them stick out more.
Also to get a good ball park of 'perfectly flush' without doing it the mathematical way, you can take a 4 foot construction level and place it vertically (90° to the ground) next to your fenders, and then put a ruler horizontally where the top of the rim edge and the tire sidewall meet and measure from the tire to the edge of the level. That will give you the thickness of the spacer that will be required to get the tire in line with the fender. Depending on your tolerance of aggressive stance, you can deviate a little more or little less if your measurement is within the standardized sizes that spacers come in.
Instagram: @thatwhitem4
DrFerry6730.00
      12-07-2023, 01:52 AM   #1113
StripclubDJ
StripclubDJ's Avatar
4100
Drives: e92 m3
JobanM73.50
DrFerry6730.00
      01-20-2024, 02:19 AM   #1114
mnnguy
Drives: 2012 e92 m3
Would anyone know what size tires I would be able to run? Im getting a set of custom LM-Rs from friend of mine. Im currently on stock ZCP suspension, will eventually move to coilovers later on down the line.
19x9.5 +13
19x11 +19
Would it be possible to run 275/30/19 front and 295/30/19 in the rear? Or what tire sizes would be recommended for this setup?
      01-20-2024, 06:35 PM   #1115
omgzirra_exe
19x9.5 +13
19x11 +19
with out coil overs / cambers plates you are not running that comfortably and look "good"
#fakeGTS
m3post
