Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > 335d evolve tuned 1st in the US
      03-20-2012, 11:20 PM   #45
neovb
9
Drives: 2011 BMW 335d
For comparison purposes, here are the dyno graphs from my two sessions. The first one couldnt pull an RPM signal, so HP only. The second has HP and TQ. To those that may wonder, the first chart is not of a supercharged M3, the dyno operator forgot to change the run names!
First session max HP was 328.61, no TQ numbers. STD correction.
Second session max HP was 299.59, max TQ was 474.31. STD correction. Changing these results to Smoothing 3 instead of 5 bumps HP and TQ by about 1 each (not much of a difference). I can post that up too if anyone cares, just have to go back into WinPep and print/convert into JPG.
Both sessions were run on Dynojets (although different Dynojets in different shops). Car had JBD set to 100% and an open element intake with heatshield.
I wont get involved in the dyno debate but overall, I'm really impressed with your tune. Great numbers overall and the power/torque curves look awesome. Now someone needs to get on the DPF delete!
      03-21-2012, 06:24 AM   #46
hotrod2448
grand poobah
hotrod2448's Avatar
Drives: F80 M3, F10 535i
2011 335d  [0.00]
It would be nice if they could plot boost too. Not that we have much if any info to compare that to but, we are only in the early stages of gathering data. The dyno dynamics dyno I used to go to was able to plot boost an AFR.
      03-21-2012, 07:41 AM   #47
maswastage
Resident Diesel Junkie
maswastage's Avatar
56
Drives: 2010 AW 335d
I love how flat that power curve is. Looks like the D, even in stock configuration, is making at least 90% of its peak power from just over 3K rpm.
      03-21-2012, 09:04 PM   #48
crazyinp
crazyinp's Avatar
Drives: BMW
2022 BMW X5e  [0.00]
2023 BMW X5M  [0.00]
So who should we send the money to?
      03-24-2012, 01:00 PM   #49
taibanl
taibanl's Avatar
281
Drives: BMW
My gloss from this without plotting is that the JBD and the Evolve tune are quite comparable in terms of results. You might be able to squeeze a few more drops of juice out of the tune, PLUS no check engine light...but thats a tradeoff for having to flash.
      03-29-2012, 12:21 PM   #50
Bowser330
Drives: i3 REX
true, but you can't unflash and reflash yourself when you have to go into the stealership for warranty work...with the JBD you can take it off and clear all codes and you are good to go...essentially its a huge amount of convenience vs. ~20whp...
I am more excited about the methanol injection testing and future nitrous applications to this motor...
      04-04-2012, 11:45 PM   #51
Antoans4
Antoans4's Avatar
Drives: 2012 X5Diesel & 2011 335is
Whats the stock boost on this cars? Whats the boost with evolve or jbd?
      04-05-2012, 02:38 AM   #52
Ron1n
Speed Demon
Ron1n's Avatar
Drives: 2021 M5C
2021 M5 Competition  [0.00]
2016 BMW 550i  [0.00]
2011 335is  [0.00]
2009 E93 M3  [10.00]
2010 335d  [9.50]
Stock boost is around 28PSI (although I've heard pushes up to 31-32). JBD doesn't touch the boost, since it only hooks into the ECU (there is a separate boost sensor further back, towards the firewall).
Current: '21 M5C, '15 X6 50i Previous: '18 M550i, '16 550i, '11 335is, '09 E93 M3 DCT, '10 E90 335d, '07 E90 328i
      04-05-2012, 07:52 AM   #53
cssnms
cssnms's Avatar
Fyi The jbd connects to the rail pressure sensor.
      04-05-2012, 12:27 PM   #54
Antoans4
Antoans4's Avatar
Thanks guys
      04-06-2012, 08:18 AM   #55
Coolieman1220
Trinidad_and_tobago
73
Drives: 2010 335d
Originally Posted by Antoans4 View Post
Thanks guys
diesel tuning, more fuel more power.
gas tuning, more air & fuel more power
      04-07-2012, 09:20 PM   #56
BK-Diesel
Drives: 2011 335d
You gotta love the buck-forty vid.
      04-07-2012, 10:26 PM   #57
Antoans4
Antoans4's Avatar
I know thats mostly how it works on diesel, but also if u make more boost u make more power?
      05-18-2012, 09:40 AM   #58
Concentric190
Drives: 335d
1997 BMW M3  [0.00]
2009 BMW 335d  [0.00]
1995 BMW M3  [0.00]
Well car is flashed back to stock so that I can go to service and get the recall performed.
If anyone is interested in throwing down some money for a stock pull on dean's performance dynojet I'm willing to drive out there and do it. You can probably just paypal the shop directly.
///Andres
09 335d evolve tuned - 327whp / 490wtq -- 13.0@105
95 M3 Turbo - Built 3.0l s52, PTE74GTQ, AEM EMS & CDI
97 M3 NASA TTB build for 2014!
      05-19-2012, 07:53 AM   #59
crazyinp
crazyinp's Avatar
Drives: BMW
2022 BMW X5e  [0.00]
2023 BMW X5M  [0.00]
I will contribute. Anyone else?
      05-20-2012, 08:22 AM   #60
DieselDiner
DieselDiner's Avatar
486
Drives: 335d
I'm in, I owe Andres some support!
      05-20-2012, 08:24 AM   #61
taibanl
taibanl's Avatar
281
Drives: BMW
Ive already promised $25. I will promise $50 if youre willing to dyno before and after the recall work as well.
      05-21-2012, 09:25 AM   #62
Concentric190
Drives: 335d
1997 BMW M3  [0.00]
1995 BMW M3  [0.00]
Doubt the recall will do anything. I can dyno it before or after the recall whatever you guys want, but I'd prefer after the recall. It's a 60 mile trip to the shop.
I'm going to call later today and set an appointment with the dealer.
///Andres
      05-21-2012, 12:26 PM   #63
hotrod2448
grand poobah
hotrod2448's Avatar
2011 335d  [0.00]
Not to open up a can of worms but... have you confirmed with Evolve that they will be able to reflash the car after the recall? It would suck if they changed something as part of the recall that put the flash tuners back to square one.
I really doubt that is the case but, I'm sure someone will bring it up sooner or later.
      05-21-2012, 01:17 PM   #64
Concentric190
Drives: 335d
1997 BMW M3  [0.00]
1995 BMW M3  [0.00]
there is no reason why they wouldn't be able to. I'll let them chime in on that though.
///Andres
      05-21-2012, 03:42 PM   #65
hotrod2448
grand poobah
hotrod2448's Avatar
2011 335d  [0.00]
I don't know why but, there is something sticking in my mind regarding an update to the 335i software that was a bit of a set back for flash tuners when they were getting going and I can't remember what exactly it was. It may have been related to flashing through OBD, which obviously wouldn't be an issue for us since we unfortunately can't do that currently.
Either way I hope it's not a concern as I would prefer a reflash to piggyback setup.
      08-28-2012, 09:29 PM   #66
rogerdiaz
Drives: 2015 335i
Where can i get this done near durham,nc?
335d, diesel, evolve, tune, tuned
