BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Help-Toyo R888
Extreme Powerhouse
      02-18-2014, 01:41 PM   #1
M-terkait
M-terkait's Avatar
Kuwait
209
Drives: F30 335i 3/13
Help-Toyo R888
Hi
not sure if it's about the tire or something wrong with fitment.
i had potenza S0001 replaced.
got my new apex EC-7
front: 18x9 ET42
rear: 18x9.5 ET43
i equipped all tires with 245/40/18 *Toyo R888*.
the car is vibrating while moving from 20-35mph.
moving from 0-20mph && from 40mph++ is fine and there is no vibration.
Docrace 6266
      02-19-2014, 12:04 AM   #2
reedo302
Estorilblau Member
reedo302's Avatar
Drives: Dinan Estoril 328i M Sport
Have the installer re-check the balance on the wheels.
If that doesn't do it, check all of your tire pressures and inspect the tires for flat spots or damage.
If that doesn't do it, you may have an issue with a bad tire. Occasionally, companies do put out a bad tire. If it's bad, it'll be replaced under manufacturer warranty.
      02-19-2014, 08:05 AM   #3
M-terkait
M-terkait's Avatar
Kuwait
209
it seems to be the way the tire is made, it handles so well that you won't lose control..ever .
if any1 had R888 on any car can you confirm please
Docrace 6266
      02-19-2014, 09:02 AM   #4
Dippydo
Drives: 2023 M8 Comp
2012 BMW  [1.00]
Check two things. Check the balance as the other poster said and also check to make sure the wheels are round and balanced without the tire on. But before ripping the tires off, check balancing with tires on first.
apex, ec-7, r888, tires, toyo
